    Constant errors
    Duet Web Control
    1.9k
      A Former User
      Windows 10
        jay_s_uk
        Windows can be a bit odd sometimes.
        It's possible to use bossa from a pi if you have one.
          A Former User @jay_s_uk
          @jay_s_uk
          Hell no im not trowing any more money at this thing, like i have stated its discusting that the product quality is so bad.
            jay_s_uk
            I'm not suggesting you spend any more money.
            I was purely stating that windows can be odd with USBs (outside of the control of the Duet team).
            I would also suggest trying connecting through a USB hub (preferably powered) as your PC may not be able to supply enough power.
            If you don't have one of those but you have a laptop, you can power the Duet 3 using 12-32v and connect the laptop via USB and try that way. Just make sure the laptop is ran off battery power only.
              A Former User
              No luck, have none of those.
                A Former User
                What option do i have left, was able to aquire a laptop from my niece and even powering the duet with the PSU and trying with the laptop results in the same thing.
                  @Torppa said in Constant errors:
                  Verify failed
                  Page errors:1114
                  Byte errors:563942
                  And now the board is compleatly useless...
                  This is almost exactly what I get when i use Bossa without removing the Erase jumper first. I am flashing version 3.1.1 so I get slightly different results:
                  After removing the Erase jumper, pressing Write again and then Verify, it works:
                  So please double check that you have removed the correct jumper:
                    A Former User
                    I did not have the jumpper on, still did the reset and erase again and no luck
                      Looks like the MCU is not coming out of Erase mode. Try the following:
                      • Put the Erase jumper on
                      • Press the Reset button on the Duet
                      • Remove the jumper
                      • Press Reset again
                      • Reconnect Bossa (you can normally just click on the COM port dropdown and select the same COM port again)
                      • Ensure that Erase All, Lock and Boot to Flash are checked (but not the other boxes)
                      • Press Write
                      • Press Verify
                      The Write operation should display a progress bar and take 15 seconds or longer.
                        A Former User @dc42
                        Does not work
                          Are you using VIN power to the Duet, USB power, or powering it some other way?
                            A Former User
                            BOSSA just wont write.
                            And USB power
                              USB power alone may be insufficient. Please read the notes on avoiding USB ground loop problems at https://duet3d.dozuki.com/Wiki/USB_ground_loops and try again with VIN power. I assume that you have the 5V regulator on the Duet enabled.
                                A Former User
                                Running on VIN and a laptop results in the same problem.
                                  Make sure that the PC and the Duet PSU are plugged into the same power distribution block then. Usually it's not a problem if they are not, but occasionally a home has faulty mains wiring.
                                    A Former User
                                    Not gonna risk it, unless duet waranty cowers a 5000€ pc.
                                      A Former User
                                      What i have tried so far.
                                      USB power only: Does not work
                                      USB power only nothing connected exept the USB: Does not work
                                      VIN and USB via a laptop: Does not work
                                      Used the jumppers and reset multiple times.
                                      Nothing works just like i expected.
                                        A Former User
                                        Found the real problem, its a bad solder joint in the sd card slot, multimeter temp probe reads 67C.
                                          A Former User @A Former User
                                          Found the real problem, its a bad soder joint in the sd card slot, multimeter temp probe reads 67C.
                                          What does "soder" mean ?
                                            @CaLviNx
                                            https://dictionary.cambridge.org/dictionary/english/nitpicker
                                            Thanks now the world is saved.
                                            English is not my first nor my second language.
