    Constant errors
    Duet Web Control
    1.9k
      A Former User
      No luck, have none of those.
        A Former User
        What option do i have left, was able to aquire a laptop from my niece and even powering the duet with the PSU and trying with the laptop results in the same thing.
          @Torppa said in Constant errors:
          Verify failed
          Page errors:1114
          Byte errors:563942
          And now the board is compleatly useless...
          This is almost exactly what I get when i use Bossa without removing the Erase jumper first. I am flashing version 3.1.1 so I get slightly different results:
          After removing the Erase jumper, pressing Write again and then Verify, it works:
          So please double check that you have removed the correct jumper:
            A Former User
            I did not have the jumpper on, still did the reset and erase again and no luck
              Looks like the MCU is not coming out of Erase mode. Try the following:
              • Put the Erase jumper on
              • Press the Reset button on the Duet
              • Remove the jumper
              • Press Reset again
              • Reconnect Bossa (you can normally just click on the COM port dropdown and select the same COM port again)
              • Ensure that Erase All, Lock and Boot to Flash are checked (but not the other boxes)
              • Press Write
              • Press Verify
              The Write operation should display a progress bar and take 15 seconds or longer.
                A Former User @dc42
                Does not work
                  Are you using VIN power to the Duet, USB power, or powering it some other way?
                    A Former User
                    BOSSA just wont write.
                    And USB power
                      USB power alone may be insufficient. Please read the notes on avoiding USB ground loop problems at https://duet3d.dozuki.com/Wiki/USB_ground_loops and try again with VIN power. I assume that you have the 5V regulator on the Duet enabled.
                        A Former User
                        Running on VIN and a laptop results in the same problem.
                          Make sure that the PC and the Duet PSU are plugged into the same power distribution block then. Usually it's not a problem if they are not, but occasionally a home has faulty mains wiring.
                            A Former User
                            Not gonna risk it, unless duet waranty cowers a 5000€ pc.
                              A Former User
                              What i have tried so far.
                              USB power only: Does not work
                              USB power only nothing connected exept the USB: Does not work
                              VIN and USB via a laptop: Does not work
                              Used the jumppers and reset multiple times.
                              Nothing works just like i expected.
                                A Former User
                                Found the real problem, its a bad solder joint in the sd card slot, multimeter temp probe reads 67C.
                                  A Former User @A Former User
                                  Found the real problem, its a bad soder joint in the sd card slot, multimeter temp probe reads 67C.
                                  What does "soder" mean ?
                                    @CaLviNx
                                    https://dictionary.cambridge.org/dictionary/english/nitpicker
                                    Thanks now the world is saved.
                                    English is not my first nor my second language.
