    Constant errors
    Duet Web Control
    1.9k
      Looks like the MCU is not coming out of Erase mode. Try the following:
      • Put the Erase jumper on
      • Press the Reset button on the Duet
      • Remove the jumper
      • Press Reset again
      • Reconnect Bossa (you can normally just click on the COM port dropdown and select the same COM port again)
      • Ensure that Erase All, Lock and Boot to Flash are checked (but not the other boxes)
      • Press Write
      • Press Verify
      The Write operation should display a progress bar and take 15 seconds or longer.
        A Former User @dc42
        Does not work
          Are you using VIN power to the Duet, USB power, or powering it some other way?
            A Former User
            BOSSA just wont write.
            And USB power
              USB power alone may be insufficient. Please read the notes on avoiding USB ground loop problems at https://duet3d.dozuki.com/Wiki/USB_ground_loops and try again with VIN power. I assume that you have the 5V regulator on the Duet enabled.
                A Former User
                Running on VIN and a laptop results in the same problem.
                  Make sure that the PC and the Duet PSU are plugged into the same power distribution block then. Usually it's not a problem if they are not, but occasionally a home has faulty mains wiring.
                    A Former User
                    Not gonna risk it, unless duet waranty cowers a 5000€ pc.
                      A Former User
                      What i have tried so far.
                      USB power only: Does not work
                      USB power only nothing connected exept the USB: Does not work
                      VIN and USB via a laptop: Does not work
                      Used the jumppers and reset multiple times.
                      Nothing works just like i expected.
                        A Former User
                        Found the real problem, its a bad solder joint in the sd card slot, multimeter temp probe reads 67C.
                          A Former User @A Former User
                          @Torppa said in Constant errors:
                          Found the real problem, its a bad soder joint in the sd card slot, multimeter temp probe reads 67C.
                          What does "soder" mean ?
                            @CaLviNx
                            https://dictionary.cambridge.org/dictionary/english/nitpicker
                            Thanks now the world is saved.
                            English is not my first nor my second language.
