    3.1.0 firmware reboots periodically
    1.7k
    • Thaliosundefined
      Thalios
      One weird thing though, it did it right after the firmware upgrade, but hasn't since it seems.
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0
      Board ID: 08DJM-956L2-G43S4-6J9D0-3SD6Q-9U5GF
      Used output buffers: 1 of 40 (24 max)
      Static ram: 154524
      Dynamic ram: 163148 of which 44 recycled
      Exception stack ram used: 568
      Never used ram: 74932
      Tasks: NETWORK(ready,148) ETHERNET(blocked,436) HEAT(blocked,1112) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1424) TMC(blocked,68) MAIN(running,4464) IDLE(ready,76)
      Owned mutexes:
      Last reset 01:30:48 ago, cause: software
      Last software reset at 2020-05-16 15:58, reason: Stack overflow, spinning module Platform, available RAM 74648 bytes (slot 2)
      Software reset code 0x4100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443780e BFAR 0x00000000 SP 0x2045ffb4 Task NETW
      Stack: 204120c0 204120f4 00463465 00000000 00000000 204121f0 00000000 a0000000 00462a89 204120fc 20417e30
      Error status: 0
      MCU temperature: min 45.6, current 47.4, max 47.4
      Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Driver 0: ok, reads 28162, writes 8 timeouts 0, SG min/max 0/976
      Driver 1: ok, reads 28161, writes 8 timeouts 0, SG min/max 0/332
      Driver 2: ok, reads 28163, writes 8 timeouts 0, SG min/max 0/140
      Driver 3: ok, reads 28166, writes 4 timeouts 0, SG min/max 0/1023
      Driver 4: standstill, reads 28170, writes 0 timeouts 0, SG min/max not available
      Driver 5: standstill, reads 28170, writes 0 timeouts 0, SG min/max not available
      Date/time: 2020-05-18 13:36:34
      Slowest loop: 113.03ms; fastest: 0.15ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 3.5ms, write time 40.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 351, MinFreeDm: 301, MaxWait: 846322ms
      === MainDDARing ===
      Scheduled moves: 7273, completed moves: 7214, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.4
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X104.142 Y97.383 E0.00889" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 40.45ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      Socket states: 2 2 2 2 2 0 0 0
      === Filament sensors ===
      Extruder 0: pos 4.70, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages sent 5662, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 5448813ms ago
      RX/TX seq numbers: 0/1
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
      Heavily modified Ender 3 Pro (Duet 3 6HC)
      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
      CR-10S Pro V2 (Duet 3 Mini 5+)
      and a bunch of SLA printers..
        What's most noticeable to me in that report is that it gives the Network task stack remaining (when the M122 report was run, not when the reboot occurred) as 148 bytes. Whereas with that firmware version, the lowest I had was 212 bytes.
        • Thaliosundefined
          Thalios
          I'm running in standalone. Does that help?
            dc42 administrators @Thalios
            @Thalios said in 3.1.0 firmware reboots periodically:
            Thanks, so am I.
              The firmware build date on dropbox now -18b8 because we added a fix for an unrelated problem.
              • Thaliosundefined
                Thalios
                I just updated to b8.
                After install, i ran m122 and it gave me this:
                m122
                RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                Used output buffers: 1 of 40 (12 max)
                Static ram: 154604
                Exception stack ram used: 328
                Never used ram: 75092
                Tasks: NETWORK(ready,308) ETHERNET(blocked,436) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76)
                Owned mutexes:
                Last reset 00:00:39 ago, cause: software
                Error status: 0
                MCU temperature: min 45.9, current 46.3, max 46.5
                Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, reads 62009, writes 15 timeouts 0, SG min/max 0/0
                Driver 1: standstill, reads 62010, writes 15 timeouts 0, SG min/max 0/0
                Driver 2: standstill, reads 62010, writes 15 timeouts 0, SG min/max 0/0
                Driver 3: standstill, reads 62012, writes 14 timeouts 0, SG min/max 0/0
                Driver 4: standstill, reads 62015, writes 11 timeouts 0, SG min/max 0/0
                Driver 5: standstill, reads 62016, writes 11 timeouts 0, SG min/max 0/0
                Date/time: 2020-05-18 17:03:48
                Slowest loop: 6.32ms; fastest: 0.21ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 3.3ms, write time 0.0ms, max retries 0
                === MainDDARing ===
                === AuxDDARing ===
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                File is idle in state(s) 0
                === Network ===
                Slowest loop: 13.76ms; fastest: 0.03ms
                - Ethernet -
                State: active
                Extruder 0: pos 3.07, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                === CAN ===
                Messages sent 156, longest wait 0ms for type 0
                Last transfer: 39247ms ago
                Buffer RX/TX: 0/0-0
                It is now 308 instead of 148. It also states a stack overflow, but the timestamp coincides with the reboot of the update.
                I'm about to start another 1-2h print, will report back after.
                • k3lagundefined
                  k3lag
                  I did a 2 hour or so print with b6 this morning with no problems and it has been idle since then with DWC connected. I usually have DWC in a separate tab in my browser. I get a lot of connection interrupted (HTTP time out) connection established pairs. Usually when DWC is not the active tab. Here is my current M122 with b6. I'll install B8 and do another print.
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-917DA-G4MSJ-6JKDJ-3S46L-TVPMB
                  Used output buffers: 3 of 24 (23 max)
                  Static ram: 27900
                  Dynamic ram: 94392 of which 60 recycled
                  Exception stack ram used: 552
                  Never used ram: 8168
                  Tasks: NETWORK(ready,188) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1632) IDLE(ready,80)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 06:25:25 ago, cause: software
                  Last software reset at 2020-05-16 12:21, reason: User, spinning module GCodes, available RAM 8496 bytes (slot 3)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0
                  MCU temperature: min 31.5, current 32.1, max 37.1
                  Supply voltage: min 24.2, current 24.6, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: standstill, SG min/max 0/1023
                  Driver 1: standstill, SG min/max 0/1023
                  Driver 3: standstill, SG min/max 0/1023
                  Driver 5: standstill, SG min/max 98/1023
                  Driver 6: standstill, SG min/max 0/265
                  Driver 7: standstill, SG min/max 0/251
                  Date/time: 2020-05-18 17:16:44
                  Slowest loop: 54.33ms; fastest: 0.14ms
                  === Storage ===
                  SD card longest read time 1.6ms, write time 0.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 109, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 101765, completed moves: 101765, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                  === AuxDDARing ===
                  Heater 0 is on, I-accum = 0.0
                  Segments left: 0
                  === Network ===
                  Slowest loop: 200.66ms; fastest: 0.09ms
                  - WiFi -
                  Network state is active
                  Failed messages: pending 0, notready 0, noresp 2
                  WiFi firmware version 1.23
                  WiFi MAC address ec:fa:bc:01:d6:19
                  WiFi Vcc 3.43, reset reason Unknown
                  WiFi flash size 4194304, free heap 23568
                  WiFi IP address 192.168.1.16
                  WiFi signal strength -31dBm, reconnections 0, sleep mode modem
                  Socket states: 4 0 0 0 0 0 0 0
                  === DueX ===
                  Read count 0, 0.00 reads/min
                  • k3lagundefined
                    k3lag
                    Just completed a 2 hour + print with b8. No issues with restarts. Here is the M122.
                    M122
                    Used output buffers: 3 of 24 (20 max)
                    Static ram: 27980
                    Never used ram: 8088
                    Tasks: NETWORK(ready,284) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1840) IDLE(ready,80)
                    Last reset 02:11:05 ago, cause: software
                    Error status: 0
                    MCU temperature: min 31.1, current 34.5, max 37.1
                    Driver 5: standstill, SG min/max 0/253
                    Driver 6: standstill, SG min/max 0/264
                    Driver 7: standstill, SG min/max 0/277
                    Date/time: 2020-05-18 19:31:35
                    Slowest loop: 55.48ms; fastest: 0.14ms
                    === Storage ===
                    SD card longest read time 1.5ms, write time 0.0ms, max retries 0
                    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 109, MaxWait: 277266ms
                    === MainDDARing ===
                    Scheduled moves: 101767, completed moves: 101767, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 59.40ms; fastest: 0.00ms
                    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                    - WiFi -
                    WiFi signal strength -33dBm, reconnections 0, sleep mode modem
                    === DueX ===
                    Read count 1, 0.01 reads/min
                    I switched back and forth between DWC 3.1.0 and DWC 1.22.6 and with 3.1.0 I get disconnects every few minutes. With 1.22.6 I do NOT get disconnects.
                    Here is a short log example of the connects/disconnects with 3.1.0:
                    5/18/2020, 7:37:09 PM	Connection established
                    5/18/2020, 7:35:23 PM	Connection interrupted, attempting to reconnect...
                    Network error
                    5/18/2020, 7:34:53 PM	Connection established
                    5/18/2020, 7:34:53 PM	Connection interrupted, attempting to reconnect...
                    HTTP request timed out
                    5/18/2020, 7:34:29 PM	Connection established
                    5/18/2020, 7:34:29 PM	Connection interrupted, attempting to reconnect...
                    5/18/2020, 7:34:18 PM	Connection established
                    5/18/2020, 7:34:17 PM	Connection interrupted, attempting to reconnect...
                    5/18/2020, 7:34:00 PM	Connection established
                    5/18/2020, 7:34:00 PM	Connection interrupted, attempting to reconnect...
                    5/18/2020, 7:32:52 PM	Connection established
                    5/18/2020, 7:32:52 PM	Connection interrupted, attempting to reconnect...
                    5/18/2020, 7:32:37 PM	Connection established
                    5/18/2020, 7:32:36 PM	Connection interrupted, attempting to reconnect...
                    • Thaliosundefined
                      Thalios
                      I get disconnects all the time as well. I thought it was my computer... But since b8, I haven't seen any.
                      Does it on my 3 computers (MacBook Pro, iMac, Mac Mini)
                      Just been up for 6h. Ran a 4.5h print flawless.
                      m122:
                      M122
                      Used output buffers: 2 of 40 (24 max)
                      Static ram: 154604
                      Never used ram: 74852
                      Tasks: NETWORK(ready,228) ETHERNET(blocked,424) HEAT(blocked,1088) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1424) TMC(blocked,60) MAIN(running,4528) IDLE(ready,76)
                      Owned mutexes:
                      Last reset 06:22:59 ago, cause: software
                      Error status: 0
                      MCU temperature: min 45.5, current 45.6, max 48.4
                      Supply voltage: min 24.0, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                      12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                      Driver 0: standstill, reads 3557, writes 1 timeouts 0, SG min/max 0/1023
                      Driver 1: standstill, reads 3558, writes 1 timeouts 0, SG min/max 0/1023
                      Driver 2: standstill, reads 3556, writes 2 timeouts 0, SG min/max 0/0
                      Driver 3: standstill, reads 3557, writes 1 timeouts 0, SG min/max 0/1023
                      Driver 4: standstill, reads 3558, writes 0 timeouts 0, SG min/max not available
                      Driver 5: standstill, reads 3558, writes 0 timeouts 0, SG min/max not available
                      Date/time: 2020-05-18 23:26:09
                      Slowest loop: 118.73ms; fastest: 0.21ms
                      === Storage ===
                      SD card longest read time 3.9ms, write time 0.0ms, max retries 0
                      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 305, MaxWait: 0ms
                      === MainDDARing ===
                      Scheduled moves: 597399, completed moves: 597399, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                      === AuxDDARing ===
                      Heater 0 is on, I-accum = 0.5
                      Heater 1 is on, I-accum = 0.5
                      Segments left: 0
                      === Network ===
                      Slowest loop: 17.74ms; fastest: 0.03ms
                      - Ethernet -
                      State: active
                      Extruder 0: pos 3.53, errs: frame 7 parity 0 ovrun 0 pol 0 ovdue 0
                      === CAN ===
                      Messages sent 77659, longest wait 0ms for type 0
                      Last transfer: 22979991ms ago
                      Buffer RX/TX: 0/0-0
                      • luckyflyerundefined
                        luckyflyer
                        Was wondering if 3.1.1 is available for pi update? I know there are other ways to update but the command line update method is easiest for me.
                          Phaedrux Moderator @luckyflyer
                          @luckyflyer Yes it is.
