    PrusaSlicer cannot upload to DWC 2.04/RRF 3
    Duet Web Control
    12
    27
    3.0k
    • blt3dpundefined
      blt3dp @SIam
      @SIam said in PrusaSlicer cannot upload to DWC 2.04/RRF 3:
      i have installed rrf3 over rrf2.05 with the update function
      I think we’re dealing more with Duet Web Control, I’m guessing you upgraded from the 1.xx.x version and still have on your SD card. Take a look under the www folder on it and you probably have reprap.html
      My 3D Printing YouTube Channel
      Better Living Through 3D Printing
      Follow me on Instagram and Twitter
      Instagram
      Twitter
      SIamundefined 1 Reply Last reply Reply Quote 0
      • blt3dpundefined
        blt3dp @Garfield
        @Garfield said in PrusaSlicer cannot upload to DWC 2.04/RRF 3:
        Mine was a clean out of the box install ....
        Mine too, no traces of old DWC
        Instagram
        Twitter
        • SIamundefined
          SIam @blt3dp
          yes i have dcw1 still on the sd card
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          • chas2706undefined
            chas2706
            Hi I have a brand new install. Duet3 running RRF3 and can't get prusaslicer to upload.
            I also have a Duet Wifi freshly upgraded from RRF2.04 to RRF3.
            Prusaslicer used to work on RRF2.04 but not on RRF3.
            It could well be a DWC2.04 issue.
            In prusaslicer it just says "prusaslicer has encountered an error" when trying to upload or even connect.
            I have recently upgraded prusaslicer from version 2.11 to 2.12 but the problem existed on both versions.
              The version of DWC is irrelevant because uploading files from a slicer doesn't involve DWC. What I suspect is that those of you experiencing this issue are using Duet 3 with an attached RPi, and the web server on the Pi isn't quite mimicking the one in RRF.
              • chas2706undefined
                chas2706
                Yes at one point I suspected that but I cancelled it out after updating my DuetWifi and getting the same issue.
                TBH I'm not particularly bothered because I personally think it is more reliable to upload the file from the DWC rather than uploading to the DWC.
                  dc42 administrators @chas2706
                  @chas2706 said in PrusaSlicer cannot upload to DWC 2.04/RRF 3:
                  To confirm: you have the same issue uploading to Duet WiFi? Which firmware version(s)?
                  • chas2706undefined
                    chas2706
                    It worked on RRF2.04 but not since I upgraded to RRF3.
                    I have tried deleting the connection details in prusaslicer and re-entering them but the slicer just reports an internal error.
                    • Garfieldundefined
                      Garfield
                      Had a look at the network request from Prusa and it is GET /rr_connect?password=reprap&time=
                      I'm not sure how this works - no username ??
                      the js code shows async connect(hostname, username, password) - one of the three is missing.
                      This is the text from syslog on the rPi for IP request
                      Jan 11 18:14:11 duet3 DuetWebServer[403]:       Request starting HTTP/1.1 GET http://10.100.2.243/rr_connect?password=reprap&time=2020-01-11T18:14:11
                      Jan 11 18:14:11 duet3 DuetWebServer[403]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                      Jan 11 18:14:11 duet3 DuetWebServer[403]:       Request finished in 11.0556ms 404
                      This is the response using hostname - no difference - the pi is reporting the target rr_connect as inaccessible or unavailable
                      Jan 11 19:51:41 duet3 DuetWebServer[403]:       Request starting HTTP/1.1 GET http://duet3.local/rr_connect?password=reprap&time=2020-01-11T19:51:41
                      Jan 11 19:51:41 duet3 DuetWebServer[403]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                      Jan 11 19:51:41 duet3 DuetWebServer[403]:       Request finished in 6.801900000000001ms 404
                      • chas2706undefined
                        chas2706
                        David, please ignore the part reporting Duet Wifi and RRF3. I have found the issue.
                        In config.g I have set up a static ip but it is not actually the one in use!
                        Using the correct ip address I can confirm that you can upload from prusaslicer to Duet wifi running RRF3.0.
                        I think there is a problem though if you using Duet3 and raspberry pi.
                          @Garfield, thanks for that. I have logged this issue at https://github.com/chrishamm/DuetSoftwareFramework/issues/99.
                          dc42 created this issue in chrishamm/DuetSoftwareFramework
                          closed Can't upload files from PrusaSlicer #99
                          • chrishammundefined
                            chrishamm administrators
                            DSF uses a different HTTP API than RRF and it looks like PrusaSlicer does not support the new API yet. It may be worth getting back to this once authentification has been fully implemented in DSF. I see no reason to send a PR to PrusaSlicer before that part is complete.
                            Duet software engineer
                            • Armontroutundefined
                              Armontrout
                              Any updates to this?> I have a brand new Duet3 setup and it is getting a 404 error when I try to upload from Slic3r. Is there a setup guide, do I need an API key? If so where do i find it?
                              • Garfieldundefined
                                Garfield
                                None that I know of. There's nothing you can do to resolve this short of getting into the code and building your own, unless you know both code bases intimately I wouldn't recommend it.
                                • Williamundefined
                                  William
                                  On my Mac, the only way I can get slic3r to upload g-code is to have DWC opened in the background.
                                  mendenmhundefined 1 Reply Last reply Reply Quote 0
                                  • mendenmhundefined
                                    mendenmh @William
                                    @William That is true with slic3r, at least on the Mac, but PrusaSlicer has fixed that issue. I can upload from PrusaSlicer without keeping an open connection in a browser.
                                    • Thaliosundefined
                                      Thalios
                                      I have Prusaslicer, on Mac, uploading direct to Duet 3 with latest firmware. Works as intended.
                                      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                                      Heavily modified Ender 3 Pro (Duet 3 6HC)
                                      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                                      CR-10S Pro V2 (Duet 3 Mini 5+)
                                      and a bunch of SLA printers..
                                      blt3dpundefined 1 Reply Last reply Reply Quote 0
                                      • blt3dpundefined
                                        blt3dp @Thalios
                                        @Thalios
                                        Are you using stand alone or SBC? I believe the issue doesn't occur with stand alone.
                                        Instagram
                                        Twitter
                                        • zaptaundefined
                                          zapta @chrishamm
                                          @chrishamm said in PrusaSlicer cannot upload to DWC 2.04/RRF 3:
                                          @chrishamm, while you interacting with Prusa, can you also ask to increase the PrusaSlicer's timeout for Duet's uploads? Last time I checked it was 10 secs which cause the upload to fail on large prints. A minute or two should be fine.
                                          (my upload speed from DWC is ~200KB/s. Using RRF 2)
