    Choosing a Z axis style
    3D Printing General Chat
    5.2k
    • RSundefined
      RS
      So here's a quick mock-up of the kind of flexible mount I was thinking about:
      One of the two mounts on the slides would stay unchanged; let's say the left one. Then the right one would be replaced by this flexible mount. This would allow the print frame's right side to move in the X direction, while not allowing any flexibility in the Y directions.
      I would also replace the lead screw mounts with this. The lead screws only need to restrict Z; with the slot in the mount, they wouldn't be able to interfere with X and Y movements.
      Does this make sense? Or is this just massive overkill?
      • mrehorstdmdundefined
        mrehorstdmd
        In my printer, the frame and bed support are all made of 4040 t-slot. I made the assumption that they'd heat up together and it seems to be working fine without any special gizmos to allow differential expansion. The bed is on a kinematic mount that allows it to expand more and separately from the much cooler bed support. If you are worried about it, one of the bed supports could also be on a sliding kinematic mount.
        • RSundefined
          RS
          If it's working for you, @mrehorstdmd, then I'll start with that as well. Should it ever cause problems, then I can still replace it with a more fancy mount.
          The bed itself will definitely need a kinematic mount. I also plan to add thermal decoupling using PTFE blocks, just to be sure that the bed won't heat the bed frame to a point where it will melt its mounts.
          • RSundefined
            RS
            One more thought/question: should the lead screws be fixed only at the bottom (or top?), or on both ends? I think only fixing one end would be better (don't want them overconstrained), but I'm not sure.
              Phaedrux Moderator @RS
              @RS said in Choosing a Z axis style:
              but I'm not sure.
              You can be sure now. Overconstraint is bad. For the loads and sizes we're using in printers it's best to leave one end free to prevent any curve in the screw to be transferred to the bed platform as an XY shift.
              • fcwiltundefined
                fcwilt @RS
                What I'm quite sure about is that I want to avoid guide rods, and use linear guides instead. It seems those tend to be more precise than rods, and I've got the budget for linear guides.
                Linear guides are fine.
                I've used both rods and guides and have found no noticeable difference in the finished printed products.
                Good luck.
                • RSundefined
                  RS
                  @Phaedrux said in Choosing a Z axis style:
                  Ok, thanks for confirming this. Then I'll leave one end "floating".
                  I wonder if it matters whether they are fixed at the top or the bottom. But most likely, I'll mount them at the bottom, as that's easier.
                  @fcwilt said in Choosing a Z axis style:
                  That's interesting, as I've read alot about bad print quality due to rods. Where those high-precision rods, or the standard, cheap stuff that's found in budget printers?
                  Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    It's easier to carry the weight on a thrust bearing at the bottom than dangle it from a motor coupler.
                    RSundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    • RSundefined
                      RS @Phaedrux
                      Good point; haven't thought of that.
                      I'll definitely learn a lot about all the intricate details of a 3D printer during this project.
                      • fcwiltundefined
                        fcwilt @RS
                        They were in the middle, price wise. I don't recall the brand but they might be Misumi as I've used them often.
                          If you're into book learning, this one is great for printer design basics
                          http://www.sublimepublications.com/
                          • fcwiltundefined
                            fcwilt @Phaedrux
                            Having great faith in your advice I have ordered the book.
                            It should be interesting to find out what I know and don't know.
                            Thanks for the reference.
                            • RSundefined
                              RS
                              The book looks promising.
                              I'll have to sleep a night over the decision to order it, as shipping to Germany is about as much as the book itself...
                              • fcwiltundefined
                                fcwilt @Phaedrux
                                I've got thrust bearings but the lead screws are threaded over the entire length whereas I should have a section where the thrust bearing is that is solid, not threaded.
                                Is there some place where I can order custom lead screws with ends that are not threaded?
                                Or is there another solution?
                                • RSundefined
                                  RS
                                  Have a look at the first post in this thread: https://forum.duet3d.com/topic/10260/best-way-to-manage-vertical-forces-on-lead-screw
                                  Using a rigid coupler seems to be one way to handle this.
                                  EDIT: It's probably best to use a coupler that has different bore sizes on each side. For example, if the lead screw has a diameter of 8mm, you could use a 8mm-to-5mm coupler. This way the coupler itself would carry the weight, instead of relying on the set screws.
                                  Of course, there may be other ways.
                                    The book is by @RCarlyle. I'm still hoping the other volumes come out.
                                    • fcwiltundefined
                                      fcwilt @RS
                                      I certainly could try using a coupler. I currently have 350mm of working height and could afford to give up some to the coupler.
                                      It would mean printing some new parts for mounting the stepper and idler pulleys but that's not a show stopper.
                                      Hopefully someone has a source for custom lead screws.
                                        Phaedrux Moderator @fcwilt
                                        There's lots out there from googling, but definitely more the commercial industrial side. Probably not cheap. s
                                        https://nollinc.com/
                                        • fcwiltundefined
                                          fcwilt @Phaedrux
                                          This whole 3D printing hobby (for me it's a hobby) is "not cheap". It's kind of like ink jet printers, before long you've spent more on filament than you did on the printer.
                                          • RSundefined
                                            RS
                                            Now that I got an idea how I want the Z axis to be constructed, I thought a bit about mounting the bed to the bed frame.
                                            I want kinematic mount (like what @mrehorstdmd did on his printers), including PTFE blocks for thermal decoupling. However, I do not have access to a mill or basically any machine tools except a drill press. This made one of the three reference points (the one with the groove, only allowing lateral movement in one direction) a bit non-obvious.
                                            One idea I came up with is using 10x10x1mm square tubing, as that's something I can easily buy locally. Those are shown in blue in the following images.
                                            (Springs are still missing)
                                            After I finished that sketch, I realized that two M4 or M5 nuts (either hex or square), with a well-chosen distance between them, would probably serve the same purpose, but with less height being lost.
                                            If someone has another idea, using easily availble standard parts, I'm all ears 🙂
