    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    24.5k
    • arhiundefined
      arhi
      @Danal I added graphicsmagick to the pi and now I'm generating video that looks like this 😄
      now to find good place for the two cameras 😄
      https://youtu.be/aDZHhJkSI6E
      • luckyflyerundefined
        luckyflyer @arhi
        @arhi said in DuetLapse available for Alpha testing:
        samba is simplest way IMHO
        winscp works great too, especially if you want to access temp directory directly
        those ffmpeg parameters normally work, did you check if the images are ok? If the images are not ok then ffmpeg can't create the video. Copy the images to the PC and check them out if they are ok.
        All of the images look good. How do I copy them to the pc, copy and paste doesn't work. I haven't installed Samba yet, is that the only way?
        • arhiundefined
          arhi @luckyflyer
          @luckyflyer
          you can install samba, it's rather simple, for e.g.
          https://pimylifeup.com/raspberry-pi-samba/
          but even faster, get yourself winscp
          https://winscp.net/eng/download.php
          login with same credentials as you would ssh to the pi and copy the files
          this requires ssh to be enabled on the pi (it is not by default), to enable ssh if it's not enabled: https://www.raspberrypi.org/documentation/remote-access/ssh/
          • Danalundefined
            Danal
            Sort of.
            You can
            • sudo apt-get install samba
            • sudo smbpasswd -a pi
            • sudo nano /etc/samba/smb.conf # and change 'read only = yes' to no. It is fairly far down in the file.
            Then, on your windows machine,use a UNC like '\192.168.7.101\pi' in windows explorer, or an editor, or whatever. This is not a pure SAMBA "net share" in that there is no drive mapping. In my opinion, it actually works better...
            • Danalundefined
              Danal
              Either suggested technique will work fine.
                luckyflyer
                Ok, success finally, installed winscp, xfered the jpg's and videos to the pc, pictures look good and video's play to. There will be dancing in the streets I tell ya, thanks you guys.
                  luckyflyer
                  There was a post somewhere in this thread where someone made a macro to control Duetlapse, How would that be done, the start script is the macro?
                  Edit, wasn't a macro was a desktop entry.
                  • arhiundefined
                    arhi @luckyflyer
                    @luckyflyer said in DuetLapse available for Alpha testing:
                    I run duetlapse like this
                    create file go.sh
                    #!/bin/sh
                    while [ /bin/true ]
                    do
                      python3 DuetLapse.py -duet ender5.local.lan \
                                           -camera usb -detect layer \
                                           -pause no -two yes \
                                           -first /dev/video0 -second /dev/video2 \
                                            camparms -parms -r1280x960
                    done
                    make it executable
                    chmod a+x go.sh
                    start it (or doubleclick on it from X)
                    ./go.sh
                      jay_s_uk @arhi
                      @arhi
                      Now all we need is to be able to call that from within a print file...
                      • arhiundefined
                        arhi @jay_s_uk
                        @jay_s_uk said in DuetLapse available for Alpha testing:
                        well this script runs duetlapse over and over again so you need to start it once and forget, you could call it from rc.local so it starts when the rpi boots up and it will run till you shut it down
                        • agent0810undefined
                          agent0810
                          Hey guys, have DuetLapse running and its communicating with my Duet 2 wifi board. When it sees a layer change it pauses the print, takes the pic and then does not start the print again. Is there a setting im missing?
                          Here is some info of what im doing, at the bottom i am manually restrarting the print from my web interface.
                          ./DuetLapse.py -duet 10.1.2.xxx -camera pi -pause yes -movehead 200 200 -detect layer
                          it stops, moves the head to the corner then never starts again. any advice would be great, thank you!
                          this is a duet 2 wifi board on a Ender 5 pro using cura slicer.
                          Note "-pause yes" means this script will pause the printer when the -detect or
                          -seconds flags trigger.
                          If instead, it is desired that this script detect pauses that are already in
                          in the gcode, specify:
                          "-detect pause"
                          Attempting to connect to printer at 10.1.2.xxx
                          Connected to a Duet V2 printer at http://10.1.2.xxx
                          Options in force for this run:
                          camera = pi
                          printer = 10.1.2.xxx
                          seconds = 0
                          detect = layer
                          pause = yes
                          camparms =
                          vidparms =
                          movehead = 200.00 200.00
                          dontwait = False
                          Waiting for print to start on printer 10.1.2.xxx
                          Will take pictures when printing starts,
                          and make video when printing ends.
                          Or, press Ctrl+C one time to move directly to conversion step.
                          Print start sensed.
                          End of print will be sensed, and frames will be converted into video.
                          Requesting pause via M25
                          Moving print head to X200.00 Y200.00
                          Capturing frame 0 at X0.00 Y0.00 Z6.12 Layer 6
                          Capturing frame 1 at X103.69 Y86.69 Z1.32 Layer 7
                          Capturing frame 2 at X79.03 Y101.37 Z1.52 Layer 8
                          Capturing frame 3 at X67.97 Y145.27 Z1.72 Layer 9
                            A Former User @Danal
                            @Danal Hi, I've installed everything needed in my printer and Raspberry PI but when I start the script, as you can see, the Raspy doesn't recognize the (correct) printer IP :
                            Could you help me to solve the problem?
                            Thanks!
                              jay_s_uk @A Former User
                              @the_dragonlord @Danal passed away a few months back.
                              I'm not sure if anyone has taken this script any further
                                A Former User @jay_s_uk
                                oh my....I didn't know...so sorry for that...
                                  This post is deleted!
                                  • JohnOCFIIundefined
                                    JohnOCFII
                                    As mentioned in the GitHub ticket - I wanted to see if you could ping the printer from the Pi, just to rule out low-level IP connectivity issues.
                                    I just installed the DuetLapse about a month ago, so it is pretty fresh in my brain.
                                    John
                                    A Former User? 2 Replies Last reply Reply Quote 0
                                      A Former User @JohnOCFII
                                      @JohnOCFII said in DuetLapse available for Alpha testing:
                                      John
                                      Reading the very first messages of this thread I've seen a message of a user who suffered the exactly problem I've experienced... Both of us has setted the password and this seems to be the problem. Tomorrow I'll try to take off the password from config.g and see if it works.... I'll let you know
                                        John
                                        Good morning, I've taken off the password and now the scripts comunicate with the printer but it doesn't work for this error:
                                          JohnOCFII
                                          What the of camera do you have? Looks like a Raspberry Pi camera? I'll need to look at that tomorrow. I have a USB-type camera.
                                          A Former User? stuartofmtundefined 2 Replies Last reply Reply Quote 0
                                            Yes. i have a PI camera
                                            JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
