    Need help installing ustreamer
    135
    10.8k
      A Former User
      if you're building something you probaby need sudo apt install libevent-dev ?
      also could you be running into ipv6 issues, every now and then my pi or debian systems insist on using ipv6 mirrors but it usually looks different. long shot, but might help someone else stumbling onto the thread https://www.vultr.com/docs/force-apt-get-to-ipv4-or-ipv6-on-ubuntu-or-debian
      • luckyflyerundefined
        luckyflyer
        @bearer
        That worked and is now installed.
          A Former User @luckyflyer
          @luckyflyer said in Need help installing ustreamer:
          That worked
          which one? >D
            luckyflyer
            @bearer
              A Former User
              confused; thats what you started with after having not just skimmed the thread. gtj0 was right then
                luckyflyer
                No one is more confused than I am, lol.
                I think the difference is I tried this complete line
                sudo apt-get install libevent libjpeg8-dev uuid-dev libbsd-dev
                I did not specify -dev and also yours did not have this at the end
                Man I appreciate the fact that linux is compact and efficient. But it's a real challenge to figure it out. Its very unforgiving.
                  luckyflyer
                  So my question now is have I left anything incomplete by not having this bit of code included
                    just add them with sudo apt install libjpeg8-dev uuid-dev libbsd-dev if you don't worst thing that happens is that make fails
                      luckyflyer
                      I ran
                      sudo apt-get install libjpeg8-dev uuid-dev libbsd-dev
                      and got this,
                      The following NEW packages will be installed:
                        libbsd-dev libjpeg8 libjpeg8-dev
                      Finally I think I'm getting there.
                        luckyflyer
                        Succuss, Got ustreamer to compile.
                          luckyflyer
                          I've got ustreamer compiled and it is supposed to default broadcast on http://127.0.0.1:8080
                          I get,
                          This site can’t be reached 127.0.0.1 refused to connect.
                          This is on chrome and edge doesn't connect either. I have temporarily disabled the firewall but still no connect.
                          When I try a different ip address with the start script for example 192.168.0.116:8080 I get
                          ERROR [127.103 main] -- Can't bind HTTP on [192.168.0.116]:80: Cannot assign requested address
                          I've tried other address's also with the same result.
                          Ustreamer doesn't show anything wrong on http://127.0.0.1:8080
                          below is its startup.
                          pi@raspberrypi:~/ustreamer $ ./ustreamer
                          -- INFO [2804.103 main] -- Installing SIGINT handler ...
                          -- INFO [2804.103 main] -- Installing SIGTERM handler ...
                          -- INFO [2804.103 main] -- Ignoring SIGPIPE ...
                          -- INFO [2804.104 main] -- Using internal blank placeholder
                          -- INFO [2804.104 main] -- Listening HTTP on [127.0.0.1]:8080
                          -- INFO [2804.105 stream] -- Using V4L2 device: /dev/video0
                          -- INFO [2804.105 stream] -- Using desired FPS: 0
                          -- INFO [2804.105 http] -- Starting HTTP eventloop ...
                          -- INFO [2804.190 stream] -- Device fd=8 opened
                          -- INFO [2804.191 stream] -- Using input channel: 0
                          -- INFO [2804.191 stream] -- Using TV standard: DEFAULT
                          -- INFO [2804.193 stream] -- Using resolution: 640x480
                          -- INFO [2804.193 stream] -- Using pixelformat: YUYV
                          -- INFO [2804.195 stream] -- Using HW FPS: 0 -> 15 (coerced)
                          -- INFO [2804.198 stream] -- Requested 5 HW buffers, got 5
                          -- INFO [2804.202 stream] -- Capturing started
                          -- INFO [2804.202 stream] -- Using JPEG quality: 80%
                          -- INFO [2804.202 stream] -- Creating pool with 4 workers ...
                          -- INFO [2804.202 stream] -- Capturing ...
                          Help please.
                            only works on the pi, not from any other computer/device.
                            dwc is probably already using port 80 so (for unknowna and unrealated reasons the script) is ignoring your :8080 somehow, should probably specify it as --host=0.0.0.0 --port=8080 to bind to all available ip addresses and port 8080?
                            • gtj0undefined
                              gtj0
                              Here's the command line I use...
                              /usr/local/bin/ustreamer -r 640x480 --static /tmp/ -m JPEG -d /dev/video0 --host=0.0.0.0 --port=8080
                                luckyflyer
                                I tried chrome that's on pi (this is a standalone pi not the Duet pi) @ http://0.0.0.0:8080 and ustreamer works perfectly both snapshots and stream look good.
                                I just need to figure out why I can't get to that address with my pc.
                                  @luckyflyer 0.0.0.0 isn't a valid IP address - won't work on your pc, surprised it works on your pi tbh.
                                  but if you used --host=0.0.0.0 it would bind to all ip addresses on that host, incl 192.168.0.116, so try http://192.168.0.116:8080/ ?
                                    luckyflyer
                                    I tried http://192.168.0.116:8080/ and a couple of other address's within the same range ie ending in 116, 140 and 180 on both the pc and pi and neither could connect, made sure nothing else is on that addr.
                                      @luckyflyer what does netstat -lt4n say on the pi?
                                      sudo netstat -lt4np more usefull for future ref.
                                        luckyflyer
                                        @bearer said in Need help installing ustreamer:
                                        netstat -lt4n
                                        Active Internet connections (only servers)
                                        Proto Recv-Q Send-Q Local Address Foreign Address State
                                        tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN
                                        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
                                          @luckyflyer would appear ustreamer isn't bound to any ports?
                                          pgrep ustreamer?
                                            luckyflyer
                                            pgrep ustreamer
                                            Run that command?
