    Need help installing ustreamer
    135
    11.1k
      A Former User @luckyflyer
      @luckyflyer said in Need help installing ustreamer:
      That worked
      which one? >D
      • luckyflyerundefined
        luckyflyer
        @bearer
        sudo apt install libevent-dev
          A Former User
          confused; thats what you started with after having not just skimmed the thread. gtj0 was right then
            luckyflyer
            No one is more confused than I am, lol.
            I think the difference is I tried this complete line
            sudo apt-get install libevent libjpeg8-dev uuid-dev libbsd-dev
            I did not specify -dev and also yours did not have this at the end
            Man I appreciate the fact that linux is compact and efficient. But it's a real challenge to figure it out. Its very unforgiving.
              luckyflyer
              So my question now is have I left anything incomplete by not having this bit of code included
                just add them with sudo apt install libjpeg8-dev uuid-dev libbsd-dev if you don't worst thing that happens is that make fails
                  luckyflyer
                  I ran
                  sudo apt-get install libjpeg8-dev uuid-dev libbsd-dev
                  and got this,
                  The following NEW packages will be installed:
                    libbsd-dev libjpeg8 libjpeg8-dev
                  Finally I think I'm getting there.
                    luckyflyer
                    Succuss, Got ustreamer to compile.
                      luckyflyer
                      I've got ustreamer compiled and it is supposed to default broadcast on http://127.0.0.1:8080
                      I get,
                      This site can’t be reached 127.0.0.1 refused to connect.
                      This is on chrome and edge doesn't connect either. I have temporarily disabled the firewall but still no connect.
                      When I try a different ip address with the start script for example 192.168.0.116:8080 I get
                      ERROR [127.103 main] -- Can't bind HTTP on [192.168.0.116]:80: Cannot assign requested address
                      I've tried other address's also with the same result.
                      Ustreamer doesn't show anything wrong on http://127.0.0.1:8080
                      below is its startup.
                      pi@raspberrypi:~/ustreamer $ ./ustreamer
                      -- INFO [2804.103 main] -- Installing SIGINT handler ...
                      -- INFO [2804.103 main] -- Installing SIGTERM handler ...
                      -- INFO [2804.103 main] -- Ignoring SIGPIPE ...
                      -- INFO [2804.104 main] -- Using internal blank placeholder
                      -- INFO [2804.104 main] -- Listening HTTP on [127.0.0.1]:8080
                      -- INFO [2804.105 stream] -- Using V4L2 device: /dev/video0
                      -- INFO [2804.105 stream] -- Using desired FPS: 0
                      -- INFO [2804.105 http] -- Starting HTTP eventloop ...
                      -- INFO [2804.190 stream] -- Device fd=8 opened
                      -- INFO [2804.191 stream] -- Using input channel: 0
                      -- INFO [2804.191 stream] -- Using TV standard: DEFAULT
                      -- INFO [2804.193 stream] -- Using resolution: 640x480
                      -- INFO [2804.193 stream] -- Using pixelformat: YUYV
                      -- INFO [2804.195 stream] -- Using HW FPS: 0 -> 15 (coerced)
                      -- INFO [2804.198 stream] -- Requested 5 HW buffers, got 5
                      -- INFO [2804.202 stream] -- Capturing started
                      -- INFO [2804.202 stream] -- Using JPEG quality: 80%
                      -- INFO [2804.202 stream] -- Creating pool with 4 workers ...
                      -- INFO [2804.202 stream] -- Capturing ...
                      Help please.
                        only works on the pi, not from any other computer/device.
                        dwc is probably already using port 80 so (for unknowna and unrealated reasons the script) is ignoring your :8080 somehow, should probably specify it as --host=0.0.0.0 --port=8080 to bind to all available ip addresses and port 8080?
                        • gtj0undefined
                          gtj0
                          Here's the command line I use...
                          /usr/local/bin/ustreamer -r 640x480 --static /tmp/ -m JPEG -d /dev/video0 --host=0.0.0.0 --port=8080
                            luckyflyer
                            I tried chrome that's on pi (this is a standalone pi not the Duet pi) @ http://0.0.0.0:8080 and ustreamer works perfectly both snapshots and stream look good.
                            I just need to figure out why I can't get to that address with my pc.
                              @luckyflyer 0.0.0.0 isn't a valid IP address - won't work on your pc, surprised it works on your pi tbh.
                              but if you used --host=0.0.0.0 it would bind to all ip addresses on that host, incl 192.168.0.116, so try http://192.168.0.116:8080/ ?
                                luckyflyer
                                I tried http://192.168.0.116:8080/ and a couple of other address's within the same range ie ending in 116, 140 and 180 on both the pc and pi and neither could connect, made sure nothing else is on that addr.
                                  @luckyflyer what does netstat -lt4n say on the pi?
                                  sudo netstat -lt4np more usefull for future ref.
                                    luckyflyer
                                    @bearer said in Need help installing ustreamer:
                                    netstat -lt4n
                                    Active Internet connections (only servers)
                                    Proto Recv-Q Send-Q Local Address Foreign Address State
                                    tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN
                                    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
                                      @luckyflyer would appear ustreamer isn't bound to any ports?
                                      pgrep ustreamer?
                                        luckyflyer
                                        pgrep ustreamer
                                        Run that command?
                                          @luckyflyer yeah, it'll return the PID for ustreamer if its running.
                                            luckyflyer
                                            I believe I'll have a problem doing that because when ustreamer is running terminal is locked until a cont C .
