    First layer after remachining delta parts
    1.5k
      Have a good read of these?
      https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
      https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
      gpermanundefined 1 Reply Last reply Reply Quote 0
      • gpermanundefined
        gperman
        I can't get this delta printer to operate even halfway correctly and I've already spent 3x the pricetag. I've run G32, G29, G29 S-1. Manually compensated Z probe trigger heights at all probe points.
        I've taken the arms off and remeasured and aligned all the magballs. Every dimension is within .002" to eachother.
        I really don't understand what's going on and how precise this needs to be to get a halfway decent print. Every time I change something, the first layer test is bad in a different way.
        • gpermanundefined
          gperman @Phaedrux
          @Phaedrux and yes, I've read and followed both of those pages word for word over 5 times now.
          • gpermanundefined
            gperman
              Share all your config files and slicer start gcode?
              Firmware version? what duet board?
                jay_s_uk
                @gperman
                Do you have a predator by any chance?
                • fcwiltundefined
                  fcwilt
                  I worked and worked on my 3 delta's trying to get really good results.
                  Then I got an FolgerTech FT-5.
                  That worked so well with so little effort I scrapped the delta's for parts.
                  • gpermanundefined
                    gperman @jay_s_uk
                    @jay_s_uk yes I do.
                    • gpermanundefined
                      gperman @Phaedrux
                      @Phaedrux homedelta.g heightmap.csv config.g config-override.g bed.g
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Apr 05 2020 18:40:43 GMT-0400 (Eastern Daylight Time)
                      G90                                                ; send absolute coordinates...
                      M83                                                ; ...but relative extruder moves
                      M550 P"Anycubic Predator"                          ; set printer name
                      M665 R211.7 L440 B185 H433.0                      ; Set delta radius, diagonal rod length, printable radius and homed height
                      M666 X0 Y0 Z0                                      ; put your endstop adjustments here, or let auto calibration find them
                      M552 S1                                            ; enable network
                      M586 P0 S1                                         ; enable HTTP
                      M586 P1 S0                                         ; disable FTP
                      M586 P2 S0                                         ; disable Telnet
                      M569 P0 S1                                         ; physical drive 0 goes forwards
                      M569 P1 S1                                         ; physical drive 1 goes forwards
                      M569 P2 S1                                         ; physical drive 2 goes forwards
                      M569 P3 S1                                         ; physical drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                                   ; set drive mapping
                      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z80.00 E406.90                   ; set steps per mm
                      M566 X1200.00 Y1200.00 Z1200.00 E1200.00           ; set maximum instantaneous speed changes (mm/min)
                      M203 X18000.00 Y18000.00 Z18000.00 E1200.00        ; set maximum speeds (mm/min)
                      M201 X1000.00 Y1000.00 Z1000.00 E1000.00           ; set accelerations (mm/s^2)
                      M906 X1000 Y1000 Z1000 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                            ; Set idle timeout
                      M208 Z0 S1                                         ; set minimum Z
                      M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
                      M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
                      M574 Z2 S1 P"zstop"                                ; configure active-high endstop for high end on Z via pin zstop
                      M558 P5 C"zprobe.in" H2 F100 T15000                 ; set Z probe type to switch and the dive height + speeds
                      G31 P1000 X0 Y0 Z16.819                            ; set Z probe trigger value, offset and trigger height
                      M557 R170 S17                                      ; define mesh grid
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                            ; map heated bed to heater 0
                      M308 S1 P"e0temp" Y"thermistor" T100000 B3950      ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                      M563 P0 D0 H1 F0                                   ; define tool 0
                      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                      M501						   ; Allows stored parameters to be read
                      PrusaSlicer start G-code:
                      G28 ; home all axes
                      G1 Z5 F5000 ; lift nozzle
                      Carloundefined 1 Reply Last reply Reply Quote 0
                      • Carloundefined
                        Carlo @gperman
                        @gperman
                        Take G28 out of your start Gcode
                        Are you calibrating before every print attempt them loading your print file?
                          When you send G28 to home it's calling homedelta which is moving all the carriages to the endstops. This is clearing your calibration.
                          When are you running G32 to call your bed.g file?
                          https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Auto_calibrating_before_each_print
                          gpermanundefined 1 Reply Last reply Reply Quote 1
                          • gpermanundefined
                            gperman
                            This post is deleted!
                            • gpermanundefined
                              gperman @Phaedrux
                              @Phaedrux
                              So I was getting a lot of assistance today from Jay_s_uk which helped a little. He gave me his bed calibration file to try and I updated the firmware to the 3.1.1 zip whole package.
                              None of it really helped my issues really but it was good info.
                              Much thanks to him and everyone helping me out with this.
                              So, What I do is run Autocalibration G32 3 times than upload the results using M500. Then I run Mesh bed leveling G29 once and upload it G29 S1. Then I home the machine by hitting home all and then start the G-Code.
                              You're saying every time the machine is homed it clears the calibration? I didn't know this. Why does it clear the calibration? I suppose I will have to stop homing the machine before prints.
                              Should I just include the Bed.g code+M500 in my slicer code upon startup so It runs a calibration before every print?
                              Should I mesh bed level every print or just G32?
                              What do ya'll use for bed calibration?
                              I have a smart effector en route but it will take a while to get that up and running.
                              Also, here is the quality prints i've been dealing with:
                              First layer is too close to the bed inconstantly and has gaps between shell and infill. Dimensional stability is AWFUL. Circles are not circles, straight lines wander around. Top layer is EXTREMELY underextruded.
                              I PID calibrated the nozzle 5 times and bed the same. Changed hot end to Mosquito, no change. Changed heater cartridge to mosquito, no change. Changed thermister to filamentone high temp cartridge. Received calibration data from them for the cartridge, no change. New fans, no change. Capricorn bowden, no change. Bondtech extruder assembly, changed steps to match, no change.
                              I changed extrusion multiplier up, down and all around, no change.
                              Carloundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • Carloundefined
                                Carlo @gperman
                                @gperman
                                Hi gperman,
                                Can you delete the config_override raise the Rin your config to R231.750 then restart the board to make sure it takes effect
                                Then run G28, then heat the bed to 60c and hot end to 130c run G32 M665 M500 and check the Radius R of the new config_override see if it has changes please.
                                • Carloundefined
                                  Carlo @Carlo
                                  @Carlo
                                  Sorry run the G32 let it finish calibration then M665 from the console then M500 from the console then check the file.
                                    Phaedrux Moderator @gperman
                                    @gperman said in First layer after remachining delta parts:
                                    When you do that you're resetting the position of where the firmware thinks the bed based on the location of the endstops which are never 100% accurate. You need to establish where the bed is with G30 before starting the print and before doing the mesh.
                                    • gpermanundefined
                                      gperman @Carlo
                                      @Carlo said in First layer after remachining delta parts:
                                      M6
                                      Ok. I will try this tomorrow
                                      • Carloundefined
                                        Carlo @gperman
                                        @gperman
                                        Make sure you take G29 S1 out of your bed file and anywhere else you may have put it and delete your heightmap.cv file you will need to remake a new one when you get your probing sorted but that is probably hindering you at the moment so best get rid and remove all your start gcode from your slicer for now as its wrong we can sort that once your probing is accurate.
                                        Also are you sure your rod length is exactly 440. not 440.### something ?
                                        • gpermanundefined
                                          gperman
                                          Performed G32 -> M665 -> M500 three times. no homing. Which resulted in this:
                                          Calibrated 9 factors using 16 points, (mean, deviation) before (-0.001, 0.016) after (-0.000, 0.013)
                                          Auto calibration successful, deviation 0.013mm
                                          M665:
                                          Diagonals 440.847:440.847:440.847, delta radius 212.607, homed height 432.734, bed radius 185.0, X 0.632°, Y -0.509°, Z 0.000°
                                          All at 130 deg nozzle and 60 deg bed.
                                          No signs of G29 in any file. Deleted my heightmap.
                                          Compensation in use: none
                                          Still issues with dimensional stability and inconsistent nozzle height.
                                          • Carloundefined
                                            Carlo @gperman
                                            @gperman
                                            Thats good..now copy the height and the radius to your config one at a time click save then when asked if you want to
                                            restart click No
                                            We haven't done a height map yet which we are getting to..
