    Logic Level shifter for 12864 display on Duet 2 Wifi
    200
    16.8k
    • Schmartundefined
      Schmart @antlob
      @antlob Certainly not a stupid question. If you have a regular RepRapDiscount graphics display, with a ST7920 on it (or a BigTreeTech TFT24 with ST7920 emulation) then the pinout I'm showing you is very likely completely different, so wiring like in my schematic will not work. I think the pinout should instead be similar or identical to the connectors of the Maestro (shameless grab from the schematic):
      Do you have some pictures of the front and back of your display?
      Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
      • Schmartundefined
        Schmart @dc42
        @dc42 I know the 12864 changes were a tight fit for the Duet Wifi/Ethernet already and that you were really looking to shave those last bytes off.
        Is there a way I can determine which functions or constructs primarily contribute to the firmware size growth?
        I haven't looked at optimizing my code (or any code actually) yet, but I also noticed that functions like DrawCircle() and ReadPixel() are not used at the moment. We can probably disable these with a #define. And I wanted to optimize the Flush() routine even more anyway because there are still enough similarities between the ST7920 and ST7565 with respect to flushing logic. I'm just not certain in how many bytes I can save there.
        To your idea of making a ST7565 specific build; in the existing code, a fair number of functions use the display buffer directly, so using the buffer with a rotated orientation would require careful checking and possibly abstracting these functions from accessing the buffer directly. That's some work, but still feasible, and perhaps something to do anyway because I have a hunch this might even save some code.
        • Schmartundefined
          Schmart
          I updated the schematic of how I hooked up my MiniPanel display to the Maestro. See a couple of posts above.
            dc42 administrators @Schmart
            @Schmart said in Logic Level shifter for 12864 display on Duet 2 Wifi:
            The linker eliminates any non-virtual functions that are not referenced, so no need to disable them using #define.
              dc42 administrators @dc42
              I've been working on the code in RRF 3.2 to vary the number of drivers depending on whether a display is configured or not. In the process, I finalised the pin assignments for Duet WiFi to the Fysetc mini 12864 display, as follows.
              constexpr Pin EncoderPinB = PortCPin(7);		// connlcd.3	-> exp2.6
              constexpr Pin EncoderPinA = PortAPin(8);		// connlcd.4	-> exp2.8
              constexpr Pin LcdNeopixelPin = PortDPin(18);       	// connlcd.5	-> exp1.5
              constexpr Pin LcdResetPin = PortCPin(28);		// connlcd.6	-> exp1.6
              constexpr Pin LcdA0Pin = PortDPin(19);			// connlcd.7	-> exp1.7
              constexpr Pin LcdCSPin = PortAPin(25);			// connlcd.8	-> exp1.8
              constexpr Pin EncoderPinSw = PortDPin(20);		// connlcd.9	-> exp1.9
              constexpr Pin LcdBeepPin = PortDPin(21);		// connlcd.10	-> exp1.10
              // Additional spi wiring for FYSETC Mini 12864 display:
              // connlcd.2 (gnd)	-> exp1.2
              // connsd.1 (+5V)	-> exp1.1
              // connsd.2 (gnd)	-> exp2.2
              // connsd.3 (SD CS)	-> exp2.7
              // connsd.4 (sck)	-> exp2.9
              // connsd.5 (mosi)	-> exp2.5
              // connsd.6 (miso)	-> exp2.10
              Schmartundefined 1 Reply Last reply Reply Quote 1
                jay_s_uk
                Sounds promising. I have one of these displays gathering dust
                • Schmartundefined
                  Schmart @dc42
                  Hi @dc42
                  I've optimized and simplified the code further in my repo and managed to save a few hundred bytes.
                  Also, the ST7565 display now works without additional logic components, inverting the LCD_CS with a 74xx00 is not necessary anymore. I've used the exp_0 pin for DC and the exp_1 pin for CS now. My display accepts the logic levels perfectly.
                  I should be able to save another 60 bytes or so, but I have to first work out an issue that I uncovered when I start drawing columns pixel by pixel.
                  • oliofundefined
                    oliof
                    @Schmart where'd one find your patch, and what does the new wiring look like? Inquiring minds want to know ...
                    Schmartundefined 2 Replies Last reply Reply Quote 0
                    • Schmartundefined
                      Schmart
                      @dc42: I created a pull request of my changes today, and I tested:
                      • ST7920 display type 1
                      • ST7565 display type 2 that uses EXP_1 for active low CD
                      • ST7565 display type 3 which needs a NAND inverter IC to invert the LCD_CS towards the display
                      Also implemented a couple of optimizations, solved a few bugs and simplified the Flush routine.
                      I see some room for further size reduction of the firmware, but that would probably make some parts of the code a little slower. What's your stance on that?
                      • Schmartundefined
                        Schmart @oliof
                        Hi @oliof, back from fishing? 😉
                        The changes are in the following repo and branch.
                        https://github.com/SchmartMaker/RepRapFirmware/tree/ST7565
                        I have a binary firmware for the Maestro here:
                        https://1drv.ms/u/s!Au1g8fW6BaQzioADewiHDAxzQ_Adlg?e=KuNYOB
                        What's the board you're using? I'm asking, because the firmware build for the Duet Wifi and Duet Ethernet is still a little too large for the flash memory of these boards unfortunately.
                        • Schmartundefined
                          Schmart @oliof
                          @oliof I'll see if I can hack the wiring picture so that it reflects the new option that doesn't require the 74xx00.
                          • oliofundefined
                            oliof
                            I have a Duet2Wifi, but I can easily remove stuff I don't need (I did remove Hangprinter when trying the level shifter approach).
                            Schmartundefined 1 Reply Last reply Reply Quote 0
                            • Schmartundefined
                              Schmart @oliof
                              @oliof This is the wiring I used without the inverter.
                              So to be clear and safe, this is very specific wiring to connect the Duet 2 Maestro to a Creality ST7565-based MiniPanel display @3.3v logic levels.
                              The pinout of displays made vary wildly, and the connectors on display-side may need to be reversed (the plastic shroud rotated 180 degrees). Also, the firmware adaptations I made in my fork are relatively easy to change for the Duet 2 Wifi, but I believe you would need to make changes in the Pins.h specific to the board and maybe also in Display.cpp (for now).
                              Edit: Since @oliof is using the exact same Creality MiniPanel display from the CR-20, I have adjusted the diagram to match the exact orientation of the display connectors on that specific display. The tab goes on the side of pin #1.
                              • oliofundefined
                                oliof
                                I have a Creality minipanel I want to use, so we're in the clear there. I'll check how Pins.h need to be adapted if I get around to it before this lands in 3.2 or beyond.
                                • Schmartundefined
                                  Schmart @oliof
                                  @oliof That would be so cool if you'd get it working as well. I'm not at my computer anymore, but I believe I'm using ‘M918 P2 E4 F2000000‘ in my config.g.
                                    Please note, the wiring diagram posted by @Schmart above is not the wiring arrangement that will be supported in RRF 3.2. The wiring arrangement in 3.2 is listed in this post https://forum.duet3d.com/post/157139.
                                    Schmartundefined antlobundefined 2 Replies Last reply Reply Quote 1
                                    • Schmartundefined
                                      Schmart @dc42
                                      @dc42 I saw the post, it wasn't clear to me if this was for the Duet 2 Wifi/Ethernet only or also for the Maestro?
                                      oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • oliofundefined
                                        oliof @Schmart
                                        @Schmart I'd assume it will be the same for either.
                                          It's for Duet WiFi/Ethernet. For the Maestro, I chose pin exp.pa21 to connect A0 to (same as in your diagram). To avoid having to invert the CS signal in hardware, I am considering requiring CS of a 7567-based display to be connected to exp.pa22.
                                          • antlobundefined
                                            antlob @dc42
                                            @dc42 Can you please confirm if that wire arrangement ( https://forum.duet3d.com/post/157139.) will work not only for the MINI LCD 12864 but also for a standart LCD 12864, mine is a BigtreeTech. Many thanks! If that's the case from lines 11 to 17 I must connect them only if I want the LCD 12864 SD Card support, right? If I prefer the one on the panel due I only need to connect the LCD 12864 to ConnLCD on the Duet 2 Wifi, right?
                                            antlobundefined A Former User? 2 Replies Last reply Reply Quote 0
