    Duet 3 - Motors only respond properly duing the home command
    2.3k
    • Oliver3dundefined
      Oliver3d
      I'm Building a custom delta printer
      The motors and end-stop switches are connected and function as expected during the homing sequence.
      When movement commands are sent to the printer the X and Y motors move but not as they should and the z motor doesn't move at all.
      I've tried sending individual commands to each motor with no effect.
      Oliver3dundefined 1 Reply Last reply Reply Quote 0
      • Oliver3dundefined
        Oliver3d @Oliver3d
        @Oliver3d said in Duet 3 - Motors only respond properly duing the home command:
        I've now tried delta calibration and when I try and move the head down manually the motors don't move, but DWC shows movement on the Z axis DRO
        • JoergS5undefined
          JoergS5
          To help you, we should know your config.g and homing files, hardware, firmware version information and if this is all correct, the wiring. If it's a mechanical problem, then an image could be helpful.
          • Oliver3dundefined
            Oliver3d
            This is my latest config.g and homedelta.g
            ; generated by RepRapFirmware Configuration Tool v3.1.1 on Fri May 29 2020 21:07:41 GMT-0700 (Pacific Daylight Time)
            M550 P"OLIVER3DPRINTER" ; set printer name
            M665 R224.25 L573.75 B200 H600 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
            M350 X256 Y256 Z256 I0 ; configure microstepping without interpolation
            M350 E16 I1 ; configure microstepping with interpolation
            M92 X10240.00 Y10240.00 Z10240.00 E837.20 ; set steps per mm
            M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X200.00 Y200.00 Z200.00 E1000.00 ; set accelerations (mm/s^2)
            M906 X2000 Y2000 Z2000 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 Z0 S1 ; set minimum Z
            M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
            M574 Y2 S1 P"io4.in" ; configure active-high endstop for high end on Y via pin io4.in
            M574 Z2 S1 P"io3.in" ; configure active-high endstop for high end on Z via pin io3.in
            M558 P0 H5 F120 T1200 ; disable Z probe but set dive height, probe speed and travel speed
            M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
            M557 R200 S50 ; define mesh grid
            M308 S0 P"temp1" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp1
            M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
            M308 S1 P"temp2" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp2
            M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
            M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
            M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
            M563 P1 S"TITAM AQUA" D0 H1 F0 ; define tool 1
            ; Custom settings
            M575 P1 B57600 S1
            ; homedelta.g
            ; called to home all towers on a delta printer
            G91 ; relative positioning
            ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
            G1 H1 X815 Y815 Z815 F180 ; move all towers to the high end stopping at the endstops (first pass)
            G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
            ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
            G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
            G1 Z-5 F1200 ; move down a few mm so that the nozzle can be centred
            G90 ; absolute positioning
            G1 X0 Y0 F1200 ; move X+Y to the centre
            • Oliver3dundefined
              Oliver3d
              This post is deleted!
              • Oliver3dundefined
                Oliver3d @Oliver3d
                • Oliver3dundefined
                  Oliver3d @Oliver3d
                  0FC820B2-6C8C-43D5-B35C-C099E4BFEA08.jpeg 5498D768-9185-4515-BB5D-CAF9D998C7CB.jpeg
                  B7BF646B-CFB7-4FEF-8B00-6F0EBF3C4AC9.jpeg 418767B2-98B2-4EB7-9C06-E2886866F5C5.jpeg
                  • Oliver3dundefined
                    Oliver3d @Oliver3d
                    • Oliver3dundefined
                      Oliver3d
                      I have been struggling with this problem for the last two days, I’ve tried changing various different settings in the Duet setup configuration tool and always have the same result. Motors seem to work exactly as expected when the hoeing command is executed, but when I try to jog the print head in the z axis nothing happens, if I jog in the X axis the Z motor moves smoothly but only that motor, if I jog in the Y axis the X motor moves slowing and not smooth and the Y motor moves as it dose in the X axis jogging. I feel this must be a software problem because the homing cycle works perfectly.
                      Ive tried all the steps I’ve done so far on the DWC and on the Paneldue that’s connected to the Duet board with exactly the same results.
                      • Oliver3dundefined
                        Oliver3d
                        I have also tried top complete the delta configuration process but with no luck as I can’t get the head top jog down to the bed the DRO numbers are moving but the motors are not.
                        • JoergS5undefined
                          JoergS5
                          I am not sure whether your homing procedure is correct:
                          means G1 movements with H1 parameter is individual motor mode and stopping at endstop, so it will stop when one of the axis is stopped.
                          In https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter it is more like:
                          G91 ; use relative positioning
                          G1 S1 X300 Y300 Z300 F2500 ; move all carriages up 300mm, stopping at the endstops
                          G1 S2 X-5 Y-5 Z-5 ; move all towers down 5mm
                          G1 S1 X8 Y8 Z8 F500 ; move towers slowly up 8mm, stopping at the endstops
                          G1 S2 X-5 Y-5 Z-5 F10000 ; move carriages down 5mm
                          G90 ; back to absolute positioning
                          So S1 instead of H1 and S2 instead of H2.
                          The movement problems can then be due to one axis set correctly, but the other two not, so the printer thinks he is somewhere else as he is.
                          BTW nice printer with ball screws!!
                          • JoergS5undefined
                            JoergS5
                            I think I'm wrong, because thread https://forum.duet3d.com/topic/15279/duet-2-ethernet-3-01-rc5-fail-deltahome/2 used H1 and H2 and this worked.
                            My other idea at the moment is that you defined a tool 1, but no 0 tool. Maybe the movement tries to move a nonexisting tool 0. So T1 at the end of the config file maybe.
                            • Oliver3dundefined
                              Oliver3d
                              When I use the “S” commands the DWC tells me that this is an obsolete command and to replace the “S” with “H”.
                              I have lowered manually the 3 motors to completely different heights and the homing sequence raises all motors at the same speed until they each reach their appropriate endstops and then each motor waits for the remaining motors to catch up before doing the final bounce down and back to the stops.
                              I’m now going to try the homing sequence you have posted to see if this makes any difference
                              • JoergS5undefined
                                JoergS5
                                Please see my addition with the tool to select T1.
                                • Oliver3dundefined
                                  Oliver3d
                                  I went back in to the RRF Config tool and changed the Tool to "0" and tested again with the exact same results.
                                  ; generated by RepRapFirmware Configuration Tool v3.1.1 on Sat May 30 2020 10:30:12 GMT-0700 (Pacific Daylight Time)
                                  M563 P0 S"TITAM AQUA" D0 H1 F0 ; define tool 0
                                  ; Custom settings
                                  M575 P1 B57600 S1
                                  • JoergS5undefined
                                    JoergS5
                                    One more idea: is there a sys/config-override.g in the SD card?
                                    • Oliver3dundefined
                                      Oliver3d
                                      • JoergS5undefined
                                        JoergS5
                                        I mean in the sys subdirectory.
                                        • Oliver3dundefined
                                          Oliver3d
                                          This is what I have on the SD card I had some problems during the initial setup because I replace some of the files on the SD card with some incorrect files but I thought I had fixed the problem buy downloading and installing all new files
                                          • JoergS5undefined
                                            JoergS5
                                            An additional idea: are the endstops and steppers corresponding? (X stepper to X endstop etc.) because if Y is stopped by X endstop etc., this would explain why Y moves if you want to move X etc.
