Issues setting up duet 3
duet3 duet3 6hc
1.1k
    Vanbluca @A Former User
    @bearer so I reformatted the sd and it is empty now. Do you have a good guide on what files I should put on the SD now? I already made the config.zip through the RepRap page, but I assume that's not all I put on the SD
    ? 1 Reply Last reply 30 May 2020, 18:51 Reply Quote 0
      A Former User @Vanbluca
      @Vanbluca come to think of it it needs decompressing and placing into /sys and /www on the sd card.
      ref https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
      (it won't match 100% but close enough hopefully)
      ? 1 Reply Last reply 30 May 2020, 19:15 Reply Quote 0
        A Former User @A Former User
        doing some more thinking - if its a new board it probably shipped with RRF 3.0b12. So you would have to install 3.0 release first, then update to 3.1.1.
        (if you didn't get a download link to a DuetWebControl.zip file then grab https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetWebControl-SD-2.04.zip and extract to /www on the SD card before putting it in the Duet3)
        download https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip and upload it to DuetWebControl once you're connected.
        then repeat with https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
        undefined 1 Reply Last reply 30 May 2020, 19:24 Reply Quote 0
          @bearer at this point everything is confusing me.
          without any sd in my duet, I can't get it connected to my computer. is that normal?
          ? ? 2 Replies Last reply 30 May 2020, 19:27 Reply Quote 0
            @Vanbluca said in Issues setting up duet 3:
            without a sd card you can (only) connect with usb and use a serial terminal (ref the getting connected guide).
            at that point you can enable the network (but the files for the webserver should be on the sd card so network won't help much without the card)
            undefined 1 Reply Last reply 30 May 2020, 19:43 Reply Quote 0
              @bearer I tried exactly that and got an error “permission denied”
              undefined ? 2 Replies Last reply 30 May 2020, 19:44 Reply Quote 0
                Vanbluca @Vanbluca
                and from my understanding I need to connect the duet first before I can do pretty much anything
                ? 1 Reply Last reply 30 May 2020, 19:46 Reply Quote 0
                  when connecting via serial? which software, which operating system?
                  undefined 1 Reply Last reply 30 May 2020, 19:56 Reply Quote 0
                    sort of, but if you have the network config in config.g + the DuetWebControl files in place and boot with the SD card you should be able to access http://duet3/ just like that.
                    undefined 1 Reply Last reply 30 May 2020, 19:59 Reply Quote 0
                      @bearer yeah I just connected the USB. I use Mac and typed the commands in Terminal exactly as the guide said
                      ? 1 Reply Last reply 30 May 2020, 19:58 Reply Quote 0
                        Mac, right. the permission denied probaly means you need elevated access rights to run the command on the Mac.
                          @bearer The DuetWebControl files, aren't they just the files from the "SD_Card_Contents.zip" download? or do you need to change them?
                          ? 1 Reply Last reply 30 May 2020, 20:00 Reply Quote 0
                            they are likely ancient. use these instead
                              Sorry in advance, cant resist......
                              And respect to @bearer you are a very brave man indeed..........
                              Might I suggest you take up another form of additive manufacturing which might suit you better.
                              Its called knitting, two needles and a ball of yarn, nothing more to do, and away you go...
                              undefined 1 Reply Last reply 31 May 2020, 09:57 Reply Quote 0
                                deckingman @A Former User
                                @CaLviNx Also can't resist, but you do realise that your "advice" will bite you in the ar*e the next time you ask for advice (as you did fairly recently IIRC).
                                ? 1 Reply Last reply 31 May 2020, 10:02 Reply Quote 0
                                  A Former User @deckingman
                                  @deckingman
                                  And I think you well know it's not often you see me asking anything let alone advice, I think in all the years you could count that on one hand.................
                                  Asking for assistance is a LAST resort, and even then I have found some of the assistance to turn out plain wrong (but for the sake of respect I haven't posted about it) So back to mainly working it out on my own.
                                    @CaLviNx @deckingman Do we need to create a forum for old farts to snip at each other?
                                    undefined 1 Reply Last reply 31 May 2020, 18:34 Reply Quote 0
                                      deckingman @Phaedrux
                                      @Phaedrux said in Issues setting up duet 3:
                                      Excellent idea! I guess now that you've called me an old fart, you'll want to join too.
                                      16 out of 24
