Auto bed compensation working just not very well
2.3k
    luckyflyer
    I've made the changes, copied and pasted. G32 ended up@ .01 and .01. Did G29, took a long time Here is the new print.
    Height map
      have you tuned the extruder? The second half of a good first layer is the right flow rate for the height from the bed.
      undefined 1 Reply Last reply 13 Jun 2020, 21:57 Reply Quote 0
        Now that you've got a good height map generated you can use G29 S1 to load a saved heightmap instead of redoing it every time.
        Print something like this to test the heightmap over the entire surface of the bed rather than a full print of a small section. Much faster this way and will give a better idea if the mesh compensation is working.
        bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
          luckyflyer @Phaedrux
          @Phaedrux I have confirmed the amount extruded by measuring 100mm of filament and then extruding 100mm. Comes out to within about a mm.
            luckyflyer
            @Phaedrux
            New test print, Since this is a 3 layer print the pictures mask what the first layer looks like. As I watched the first layer being put down generally speaking the right side of the print was laid more closely to the bed than the left. On the left the layer lines were thinner and rounded under a magnifier. As the nozzle progressed from right to left I watched the Z stepper wheel lower the bed. This is what was happening with the previous print with the holes, started good on the right and got worse as it went left. Is there anything left that can be done?
            And I do appreciate your time and effort to help me out on this!
            Front of printer is on the left, did it that way to avoid shadows, but got some anyway.
            Want to mention that h.e. is a genuine e3dv6 and the Z lead screws are T8-2 instead of the more common T8-8. More turns per inch as opposed to T8's = better resolution I'm told.
            Lower right
            Lower left
            Upper left
            Upper right
              Just to confirm, you have 3 motors for your 3 bed lead screws for the auto leveling, right?
              Are you sure the positions are correct?
              Is there much deviation after each iteration of G32?
                luckyflyer
                Just 2 lead screws and 1 stepper , I use G32 to adjust the 3 spring loaded bed leveling screws. Very little variation between iterations, day to day = some change, .03 +or-.
                  What is your nozzle width? What slicer are you using? What line width and layer height are you using for the first layer?
                    The only other thing I noticed is the trigger height is a bit high.
                    G31 P25 X-4 Y59 Z3.20
                    When the BLTouch is mounted correctly the base of the probe should be ~8mm above the nozzle tip which leads to a trigger height of ~2mm, when you get too far away from that the BLtouch can be a bit off sometimes. It has a sweet spot.
                      luckyflyer
                      Nozzle .4mm, S3d V4.12, flh 90%, flw 100%
                      Bltouch base is now 8.25mm above bed (mechanical limitation prevents 8mm) with nozzle touching bed, new trigger height = 1.40mm.
                      37 out of 37
