Thermistor at 2000c
Firmware installation
1.5k
    Bewaren
    Duet 2 Ethernet I believe, was a while since I bought it and only just had chance to use it.
    Running RepRap 3.1.1
    Bed is wired into a SSR and the thermistor too the thermistor bed pins
    Using a 10" 400w Keenovo heater pad with a NTC 100k thermistor (Beta 25/50 3950k)
      If you send M98 Pconfig.g in the gcode console do you get any error messages?
      If you send M115 does it report that you are actually using 3.1.1?
      undefined 1 Reply Last reply 13 Jun 2020, 20:04 Reply Quote 0
        Bewaren @Phaedrux
        @Phaedrux When I send M115 I get
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-06-13b2
        When sending M98 Pconfig.g I get
        HTTP is enabled on port 80
        FTP is enabled on port 21
        TELNET is enabled on port 23
        Warning: M308 command is not supported
        Warning: M950 command is not supported
        undefined 1 Reply Last reply 13 Jun 2020, 20:08 Reply Quote 0
          Phaedrux Moderator @Bewaren
          @Bewaren said in Thermistor at 2000c:
          There we go. You've not actually updated to 3.1.1. You'll need to update to 3.0 first do to some required IAP files, and then to 3.1.1.
          undefined 1 Reply Last reply 13 Jun 2020, 20:35 Reply Quote 0
            Bewaren @Phaedrux
            @Phaedrux What would be the best way to do this?
              Bewaren
              Alright done, i'll test if that's worked
                Bewaren
                Strange, it's completely changed the way the web interface looks, however it says the firmware version is still the same @Phaedrux
                  Bewaren
                  I've managed to get the firmware updated, just had to reinstall it. However the thermistors now show a temperature of '-273.1 C'. @Phaedrux
                  undefined 1 Reply Last reply 13 Jun 2020, 21:34 Reply Quote 0
                    The web interface was updated along with the firmware.
                    When you send M98 Pconfig.g now do you get any errors?
                    undefined 1 Reply Last reply 15 Jun 2020, 22:59 Reply Quote 0
                      Bewaren @Phaedrux
                      @Phaedrux
                      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                      This is what I am getting now, I am also struggling with the smart effector wiring for the thermistor, I am using a PT100 Thermistor, 2 pins but I am trying to figure out which pins I need to connect it too.
                        If you're using a PT100 your config is incorrect.
                        This is for a thermistor. In the configurator you'd need to choose which channel you have the PT100 connected to.
                        Do you have the PT100 daughter board?
                        undefined 2 Replies Last reply 15 Jun 2020, 23:23 Reply Quote 0
                          Bewaren @Phaedrux
                          @Phaedrux I do not no, I am using the thermistor provided with the E3D Hotend for the smart effector, I believe it is a PT100, correct? It was a while back since I bought it.
                            Bewaren @Phaedrux
                            @Phaedrux I have pins T3 - T4 wired up, is that correct?
                              I'm not sure what you bought. 😀
                              To use a pt100 you'll need the pt100 daughter board.
                                Can you post some photos?
                                undefined 2 Replies Last reply 15 Jun 2020, 23:55 Reply Quote 0
                                  Bewaren @Phaedrux
                                    Bewaren @Phaedrux
                                    @Phaedrux Hope these help
                                      Bewaren
                                      The wiring it a little messy at the moment, please excuse it xD
                                        Well we need to verify what sensor you are actually using. Is it a thermistor or PT100. If it's a PT100 you will need the daughter board before you can use it.
                                        undefined 1 Reply Last reply 16 Jun 2020, 00:09 Reply Quote 0
                                          Bewaren @Phaedrux
                                          This is the thermistors or PT100 I am using, not sure if it helps identify it
                                          12 out of 31
