v0.6 toolboard -- 24V fan?
298
    oliof
    What would be the sanest way to get a 24V fan running on a tool board? I could probably splice off VIN from the power terminal, and just use GND of the io I configured for the fan for PWM. Aside from the risk of shorting out things, anything else that would be terrible about this?
      A Former User
      i think there is a caveat running fans at a higher voltage than the Vfan for the mosfet; couldn't find it but i suspect another diode is involved in the solution.
        oliof
        ok, then I will ... install a fan whose cables I didn't shorten before referencing the wiring diagram and noticing IO0 is only 5V. Not enough for this 24V fan. I'd have taken 12.
          A Former User
          maybe you can make sense of this thread? https://forum.duet3d.com/post/40746
            oliof
            I think things behave differently on the tool board. Won't take a risk, undervolting the fan is just "less air" and can be addressed later.
            ? 1 Reply Last reply 16 Jun 2020, 20:07 Reply Quote 0
              @oliof said in v0.6 toolboard -- 24V fan?:
              Unfortunately that would feed voltage from VIN via the fan to the +12v rail, because of the flyback diode. We designed the tool board to use 12V fans.
                A Former User @oliof
                you could get away with using Out0 it doesn't have the diode?
                  oliof
                  I'm not risking the toolboard on a wrong fan. This 24V doesn't like 12V at all, so I will need to find a 12V one. The irony.
                  2 out of 8
