    v0.6 toolboard -- 24V fan?
    309
    • oliofundefined
      oliof
      What would be the sanest way to get a 24V fan running on a tool board? I could probably splice off VIN from the power terminal, and just use GND of the io I configured for the fan for PWM. Aside from the risk of shorting out things, anything else that would be terrible about this?
        A Former User
        i think there is a caveat running fans at a higher voltage than the Vfan for the mosfet; couldn't find it but i suspect another diode is involved in the solution.
        • oliofundefined
          oliof
          ok, then I will ... install a fan whose cables I didn't shorten before referencing the wiring diagram and noticing IO0 is only 5V. Not enough for this 24V fan. I'd have taken 12.
            A Former User
            maybe you can make sense of this thread? https://forum.duet3d.com/post/40746
            • oliofundefined
              oliof
              I think things behave differently on the tool board. Won't take a risk, undervolting the fan is just "less air" and can be addressed later.
                @oliof said in v0.6 toolboard -- 24V fan?:
                Unfortunately that would feed voltage from VIN via the fan to the +12v rail, because of the flyback diode. We designed the tool board to use 12V fans.
                  A Former User @oliof
                  you could get away with using Out0 it doesn't have the diode?
                  • oliofundefined
                    oliof
                    I'm not risking the toolboard on a wrong fan. This 24V doesn't like 12V at all, so I will need to find a 12V one. The irony.
