    Need help to connect Herkulex smart servos to the Duet wifi
    • ScaraManundefined
      ScaraMan
      Hi Guys,
      I have attached an image showing how the Herkulex smart servo is connected with an Arduino uno board ( RX is pin 11, and TX is pin 10 ), how can I connect the servo to the Duet wifi ??
        Do they take step and direction pulses?
        https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
        ScaraManundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
        • ScaraManundefined
          ScaraMan @Phaedrux
          here are the electrical specifications
          Working Voltage: 7~12VDC(Optimized 7.4V)
          Rated Current: 450mA @ 7.4V : 1.7kgf.cm
          Communication Link: Full Duplex Asynchronous Serial(TTL Level), Binary Packet, Multi Drop
          Multi control through Servo ID: 0 ~ 253, 254(Broadcast only)
          Maximum Baud Rate: 0.67Mbps
          Feedback: Position, Speed, Temperature, Load, Voltage etc.
          Various Control Algorithm: PID, Feedforward, Trapezoidal Velocity Profile, Velocity Override, Torque Saturator & Offset, Overload Protection, Neutral Calibration, Dead Zone
          • mrehorstdmdundefined
            mrehorstdmd @Phaedrux
            @Phaedrux Those are RC/robot - no step/dir/enable... RS-232 serial comms only
            https://www.robotshop.com/media/files/pdf2/_eng_herkulex_manual_20140218.pdf
            ScaraManundefined 1 Reply Last reply Reply Quote 1
            • ScaraManundefined
              ScaraMan @mrehorstdmd
              hi
              Yes, I have all those documents already, and have used the servos connected with Arduino uno and Arduino due.
              I just want to know how can I use them with the Duet wifi ???
              a sketch would be appreciated for the connections,
              or since I know how to connect them to the Arduino board, is it possible to use the Arduino with the duet wifi ?? if so how ??
