    Conditional gcode help required - New Problem
    Gcode meta commands
    2.2k
    • botundefined
      bot @deckingman
      @deckingman do you still have if tools[iterations] != null ? Because that is what should check if the array index has a value. Perhaps that is itself what is causing the error, I've never used the object model/conditional gcode.
      *not actually a robot
        deckingman @bot
        @bot said in Conditional gcode help required:
        Yes - and that bit works.
        Like I said, if I define tools 0 to 9 plus tool 19, then there are no errors for the non-existent tools 10 to 18 providing I set the "while iterations < 20". Only when I set that "while iterations" value to something higher than the highest defined tool number do I get the error.
        If I redefine tool 19 back to it's original value of "10", then I have to use "while iterations <11" otherwise I get the array out of bounds error.
          A Former User @deckingman
          @deckingman said in Conditional gcode help required:
          array index out of bounds
          probably my bad; I added the echo statement above the if statement so it will generate errors for non existent tools, moving it down help.
          anyways, could you put up a sample config/macro for the tools to play with?
            deckingman @A Former User
            @bearer The echo seems to work fine - it shows which tools have had their temperatures set and no others.
            The macro is exactly as you wrote except I use a number instead of your "#tools". Here is a cut and paste of the tools section in my config.g - sorry, it's a bit long. The M568 are historic and no longer necessary, hence commented out.
            M563 P0 S"Black" D0:1:2:3:4:5 H1 ; Define tool 0 (drive 3 not used)
            G10 P0 X0 Y0 ; Set tool 0 axis offsets
            ;M568 P0 S1 ; Enable mixing for tool 0
            M567 P0 E1.00:0.00:0.00:0.00:0.00:0.00 ; Set mixing ratios for tool 0
            M563 P1 S"Red" D0:1:2:3:4:5 H1 ; Define tool 1
            G10 P1 X0 Y0 ; Set tool 1 axis offsets
            G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
            ;M568 P1 S1 ; Enable mixing for tool 1
            M567 P1 E0.00:1.00:0.00:0.00:0.00:0.00 ; Set mixing ratios for tool 1
            M563 P2 S"Yellow" D0:1:2:3:4:5 H1 ; Define tool 2
            G10 P2 X0 Y0 ; Set tool 2 axis offsets
            G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
            ;M568 P2 S1 ; Enable mixing for tool 2
            M567 P2 E0.00:0.00:1.00:0.00:0.00:0.00 ; Set mixing ratios for tool 2
            M563 P3 S"Clear" D0:1:2:3:4:5 H1 ; Define tool 3
            G10 P3 X0 Y0 ; Set tool 3 axis offsets
            G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
            ;M568 P3 S1 ; Enable mixing for tool 3
            M567 P3 E0.00:0.00:0.00:1.00:0.00:0.00 ; Set mixing ratios for tool 3
            M563 P4 S"Blue" D0:1:2:3:4:5 H1 ; Define tool 4
            G10 P4 X0 Y0 ; Set tool 4 axis offsets
            G10 P4 R0 S0 ; Set initial tool 4 active and standby temperatures to 0C
            ;M568 P4 S1 ; Enable mixing for tool 4
            M567 P4 E0.00:0.00:0.00:0.00:1.00:0.00 ; Set mixing ratios for tool 4
            M563 P5 S"White" D0:1:2:3:4:5 H1 ; Define tool 5
            G10 P5 X0 Y0 ; Set tool 5 axis offsets
            G10 P5 R0 S0 ; Set initial tool 5 active and standby temperatures to 0C
            M567 P5 E0.00:0.00:0.00:0.00:0.00:1.00 ; Set mixing ratios for tool 5
            M563 P6 S"Orange" D0:1:2:3:4:5 H1 ; Define tool 6
            G10 P6 X0 Y0 ; Set tool 6 axis offsets
            G10 P6 R0 S0 ; Set initial tool 6 active and standby temperatures to 0C
            M567 P6 E0.00:0.50:0.50:0.00:0.00:0.00 ; Set mixing ratios for tool 6
            M563 P7 S"Purple" D0:1:2:3:4:5 H1 ; Define tool 7
            G10 P7 X0 Y0 ; Set tool 7 axis offsets
            G10 P7 R0 S0 ; Set initial tool 7 active and standby temperatures to 0C
            M567 P7 E0.00:0.50:0.00:0.00:0.50:0.00 ; Set mixing ratios for tool 7
            M563 P8 S"Green" D0:1:2:3:4:5 H1 ; Define tool 8
            G10 P8 X0 Y0 ; Set tool 8 axis offsets
            G10 P8 R0 S0 ; Set initial tool 8 active and standby temperatures to 0C
            M567 P8 E0.00:0.00:0.50:0.00:0.50:0.00 ; Set mixing ratios for tool 8
            M563 P9 S"Pink" D0:1:2:3:4:5 H1 ; Define tool 9
            G10 P9 X0 Y0 ; Set tool 9 axis offsets
            G10 P9 R0 S0 ; Set initial tool 9 active and standby temperatures to 0C
            M567 P9 E0.00:0.50:0.00:0.00:0.00:0.50 ; Set mixing ratios for tool 9
            M563 P10 S"All6" D0:1:2:3:4:5 H1 ; Define tool 10
            G10 P10 X0 Y0 ; Set tool 10 axis offsets
            G10 P10 R0 S0 ; Set initial tool 10 active and standby temperatures to 0C
            M567 P10 E0.16:0.17:0.17:0.17:0.17:0.16 ; Set mixing ratios for tool 10
              • sorry, it's a bit long
              no worries; point was to save me re-create it all from scratc:)
              (and compulsory thats what she said)
              Anyways, I did up two macro files for testing, and seems #tools evaluates to the highest tool number (i.e. you had 10 tools, and I skipped T3, #tools still evaluates to 10). and correctly the echo command doesn't access the array so it will not create an index out of bounds error regardless of it being below the if statement or not, still its tidier inside.
              so if you'te getting index errors it might be a tool thats not properly defined?
              Can you run M409 and post for the setup that generates the error?
              edit: output is the NOT same with while iterations < 29 or any other fixed number - conclusion making a tool with a gap, creates null tools to fill the gap, but testing a tool past the last tool results in a index error. use #tools or another test for valid tools.
              6/17/2020, 8:28:31 PM	M98 P"0:/macros/mktools.g"
              6/17/2020, 8:28:41 PM	M98 P"0:/macros/tools.g"
              Running toosl.g
              Setting temp for tool T 0
              Setting temp for tool T 1
              Setting temp for tool T 2
              Setting temp for tool T 4
              Setting temp for tool T 5
              Setting temp for tool T 6
              Setting temp for tool T 7
              Setting temp for tool T 8
              Setting temp for tool T 9
              Setting temp for tool T 19
              done
              ;/macros/tool.g
              echo "Running toosl.g"
              while iterations < #tools
                  echo "Setting temp for tool T", iterations
                  G10 P{iterations} S1 R0 ; - set it's active and standby temperature
              echo "done"
              ;/macros/mktools.g
              M569 P0 S1	R-1	;drivers are bust..
              M569 P1 S1	R-1	;drivers are bust..
              M569 P2 S1	R-1	;drivers are bust..
              M569 P3 S1	R-1	;drivers are bust..
              M569 P4 S1	R-1	;drivers are bust..
              M584  E0:1:2:3:4
              ;t0
              M563 P0 S"Black" D0:1:2:3:4 H1
              M567 P0 E0.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 0
              ;t1
              M563 P1 S"Red" D0:1:2:3:4 H1 ; Define tool 1
              M567 P1 E1.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 1
              ;t2
              M563 P2 S"Yellow" D0:1:2:3:4 H1 ; Define tool 2
              M567 P2 E2.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 2
              ;t3 - skip t3 to create gap in test data
              ;M563 P3 S"Clear" D0:1:2:3:4 H1 ; Define tool 3
              ;G10 P3 X0 Y0 ; Set tool 3 axis offsets
              ;G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
              M567 P3 E3.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 3
              ;t4
              M563 P4 S"Blue" D0:1:2:3:4 H1 ; Define tool 4
              M567 P4 E4.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 4
              ;t5
              M563 P5 S"White" D0:1:2:3:4 H1 ; Define tool 5
              M567 P5 E5.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 5
              ;t6
              M563 P6 S"Orange" D0:1:2:3:4 H1 ; Define tool 6
              M567 P6 E6.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 6
              ;t7
              M563 P7 S"Purple" D0:1:2:3:4 H1 ; Define tool 7
              M567 P7 E7.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 7
              ;t8
              M563 P8 S"Green" D0:1:2:3:4 H1 ; Define tool 8
              M567 P8 E8.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 8
              ;t9
              M563 P9 S"Pink" D0:1:2:3:4 H1 ; Define tool 9
              M567 P9 E9.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 9
              ;t10 - shifted to 19
              M563 P19 S"All6" D0:1:2:3:4 H1 ; Define tool 10
              G10 P19 X0 Y0 ; Set tool 10 axis offsets
              G10 P19 R0 S0 ; Set initial tool 10 active and standby temperatures to 0C
              M567 P19 E10.00:0.00:0.00:0.00:0.00  ; Set mixing ratios for tool 19
              deckingmanundefined 1 Reply Last reply Reply Quote 1
                @bearer Brilliant!
                As you say "#tools" seems to evaluate to the highest tool number which is just what I want.
                So now I can define any number of tools (up to the limit of 50), and use any tool numbers including non-sequential ones, and the macro will always set the active and standby temperatures for all of the defined tools - and without throwing up any errors.
                Which means I just need a single macro for each filament type (PLA, PET-G, ABS etc) and it will work regardless of whether I'm using a single input hot end, a 3 colour Diamond hot end, a 5 colour Diamond, or my own 6 colour (if I ever get it working).
                Many thanks indeed!
                  Many thanks indeed!
                  No worries, looking forward to seeing what you come up with next 😉
                    @bearer I'm one step ahead of you and already thinking about it.
                    At the end of every print, I run another macro which sets the active and standby temperatures to 0 (I could use -273.something to turn them off but 0 will do). So it occurs to me that if I had another "if" statement, I could use the same macro for both pre-print and post print.
                    Something like
                    if the tool set temperature (G10 S or R parameter) >0, set it to 0 else set it to (say) 210.
                    How would I do that?
                      deckingman
                      Can I use something like this
                      After the echo "setting temp for tool"
                      if G10 P{iterations} S >0
                      (indented) G10 P{iterations} S210 R210
                      (not indented) G10 P{iterations} S0 R0
                      Does that work as an "else"?
                        no else needs to be explicit; without it it will revert the changes on every run immediately as the last line will always execute.
                        you're on the right track, but have to access the object model instead of the G10 g-code.
                        something like
                        if tools[#tools].activeTemp > 0
                          ;set the temp to 0
                        else
                          ;set the temp to 210
                        I'm not sure about the correct object model node, but will try to poke it some more later, stepping out for a bit now that the sun is no longer scorching everything in an instant.. (and deliberately testing the last tool as it will be defined, the first might not)
                        OwenDundefined 1 Reply Last reply Reply Quote 0
                        • OwenDundefined
                          OwenD @A Former User
                          @bearer
                          should be
                          if tools[#tools-1].activeTemp > 0
                          Tools array starts at zero, whereas number of tools starts at 1
                            A Former User
                            to poke the object model you can user M409 it will print out the top level object model in a flat JSON string, use something like https://jsonformatter.org/ to make it more readable.
                            M409 shows the tool object, and you can dig further with M409 K"tools" which return an array of tool objects, M409 K"tools[19]" will return the last tool object. (The returned JSON string will have the actual object model inside the result object - for for M409 K"tools[19]" you should have result.active[0] for the active temp, but the object model will not use the result as part of the path, but it will need the tools[19] as part of the path giving you tools[19].active[0]. (why active is an single element array idk so this may break in wonderful and unexpected ways)
                            I now see your thinking was to look at each individual tool inside the loop, but my thinking was to look at the last tool and have two loops - subtle difference. Not sure if either is better, depends a little on wheather or not all tools will be in the same state.
                            taking
                            and inserting into
                            ;/macros/tool.g
                            echo "done"
                            you get
                            ;/macros/toggletools.g - toggles stand by temps for all tools.
                            echo "Running toggletools.g"
                                if tools[iterations].active[0] > 0
                                  echo "Turning off tool T", iterations
                                else
                                  echo "Turning on tool T", iterations
                            echo "done"
                            edit looking back there was something amiss with tools[#tools-1] so worked out well to go with your approach and a single loop avoiding tools[#tools-1]
                            deckingmanundefined OwenDundefined 2 Replies Last reply Reply Quote 1
                              @bearer Thanks very much for putting the time into this, and also thanks for the lessons.
                              Having slept on it and thought about it some more, I can foresee a few scenarios where having a single "toggle" macro could be problematic. I'm often "tinkering" and even my home Z will pre-heat the nozzle. So it is likely that sooner or later, the active temperature might be other than zero when the macro is called but the intention is to set the tools to print temperature. If the active temperature is non zero, then the tool(s) will be set to zero which would be the opposite of what is intended. For that reason I think it will be safer to use two separate macros, one which will explicitly set the temperatures to print temperature, and the other to set them to zero.
                              But thanks again for showing me how to do it. I'm sure that knowledge will be useful in the future.
                              And thanks also to @OwenD for your contribution.
                              Edit - I've changed the title to show (in an unconventional way) that this is solved.
                              • arhiundefined
                                arhi @deckingman
                                With a multi-input mixing hot end, one defines tools (colours) by using combinations of extruders and then setting mixing ratios for those extruders. But having a large number of tools defined at once, takes up too much space on the web interface. I haven't yet worked out the best way to deal with that but one option would be to have a "palette" of 50 tools but only use a selection of that full palette defined at any one time.
                                I think that when version with support for variables come up this should be easier. In theory (we'll see whent he variable support is out) you could have something like a config variable that you set in the config.g header and then you have each tool defined in it's separate .g file and then according to that variable you call the specific number of g-code files... and since it all works in runtime with RRF you could have your slicer startup file do something like:
                                $bt={bed_temperature}                ; copy bed temp from slicer to $bt variable
                                $ht={hotend0_temperature}            ; copy hotend temp from slicer to $ht variable
                                $htsb={hotend0_standbytemperature}   ; set standby temperature for hotend to $htsb
                                $tool_combination=7                  ; Use specific set of configured tools
                                M98 P"start_print.g"                 ; call start_print.g macro
                                and then in start_print.g you have something like
                                if $tool_combination == 0
                                  M98 P"configure_tool_1.g"
                                  M98 P"configure_tool_4.g"
                                  M98 P"configure_tool_5.g"
                                else if $tool_combination == 1
                                  M98 P"configure_tool_2.g"
                                  M98 P"configure_tool_3.g"
                                else if $tool_combination == 2
                                  M98 P"configure_tool_8.g"
                                else if $tool_combination == 3
                                  M98 P"configure_tool_6.g"
                                  M98 P"configure_tool_7.g"
                                else if $tool_combination == 30
                                  M98 P"configure_tool_14.g"
                                  M98 P"configure_tool_15.g"
                                  M98 P"configure_tool_20.g"
                                else
                                  abort "You did not set valid tool_combination value"
                                M200 D0 ; do not use volumetric extrusion
                                M83 ; relative extruder
                                ; heat up
                                ; heat up bed first
                                M140 S{$bt}
                                M190 S{$bt}
                                ; heat up extruder
                                    else
                                      G10 P{iterations} S{$ht} R{$htsb}
                                ; do not home if already homed
                                if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                  G28
                                M98 P"wipe.g" ; do the wipe
                                G29S1 ; use MESH compensation
                                M913 X100 Y100 Z100 ; all currents to 100%
                                M290 R0 S0 ; reset baby steps
                                ; reset speed overrides
                                M221 S100
                                M220 S100
                                ; Dynamic Acceleration Adjustment
                                ; M593 Fxxx
                                ; Pressure Advance
                                M572 D0 S0.03
                                in theory, this start_print.g can be something you call before number of other operations as it will reconfigure your tools based on the input variable ...
                                in any case, variables should come with 3.2 and if I understood dc42 properly they are now testing new batch of toolboard they got from the supplier so question is when will this come around and how will the variables work... but I believe you understand the basic idea
                                  deckingman @arhi
                                  @arhi Yes, I had been thinking along those lines myself. Essentially taking the tool definitions out of config.g and putting them in one or more macros.
                                  For info, I already use pre-and post print macros which take care of the everything from heating the bed to homing and purging (as well as setting tool temperatures which will now be done by calling this new macro). That's mostly because it gives me better control over the order that things happen. For example, I pre-heat the bed to around 40 and wait. Once it reaches 40 I set the bed to (say) 55 but don't wait and commence homing and all the other stuff. The net result is that homing, heating tools, and purging all happen within the time it takes for the bed to reach temperature, but not too soon before to minimise the time that the hot end is at print temperature before printing starts.
                                  • OwenDundefined
                                    @bearer said in Conditional gcode help required - SOLVED:
                                    My bad.
                                    Should have been tools[(#tools-1)]
                                    The equation must be in braces
                                      A Former User @OwenD
                                      @OwenD said in Conditional gcode help required - SOLVED:
                                      braces
                                      dammit, i only tried curly braces. noted 👍
                                      edit: interesting:
                                      6/18/2020, 11:43:48 AM	M409 K"tools[19]"
                                      {"key":"tools[19]","flags":"","result":{"active":[0],"axes":[[0],[1]],"extruders":[0,1,2,3,4],"fans":[0],"filamentExtruder":-1,"heaters":[1],"mix":[10.00,0,0,0,0],"name":"All6","number":19,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":2.0,"speed":16.7,"unretractSpeed":16.7,"zHop":0},"standby":[0],"state":"off"}}
                                      6/18/2020, 11:43:35 AM	M409 K"tools[(#tools-1)]"
                                      {"key":"tools[(#tools-1)]","flags":"","result":null}
                                      6/18/2020, 11:39:30 AM	echo (#tools-1)
                                      19
                                      6/18/2020, 11:39:15 AM	echo {(#tools-1)}
                                      6/18/2020, 11:39:04 AM	echo {#tools-1}
                                      6/18/2020, 11:38:56 AM	echo {#tools}
                                      20
                                        deckingman
                                        I now have a new problem which is frying my brain somewhat. I have this macro to set the tool temps to zero at the end of a print:
                                        G10 P{iterations} S0 R0 ; - set it's active and standby temperature
                                        It is correctly indented - but this forum removes the indents when I do a copy and paste.
                                        This macro works like a charm if I simply run it. But when I put inside my "Post-Print" macro I get a bunch of errors - "Error G10: 'iterations' used when not inside a loop". And of course the temperatures don't get changed. But I can run that macro "stand alone", immediately afterwards and it'll work just fine.
                                        Here is my Post-Print Macro
                                        ;End print gcode
                                        G10 ; retract
                                        G91 ; set relative
                                        G1 Z5 F240 ; move bed down 5mm
                                        G90 ; back to absolute
                                        G1 X165 Y300 F9000 ; move to rear
                                        M98 P"0:/macros/ToolTemps/ToolTemps0.g" ; set the tool temperatures to 0
                                        M140 S0 ; turn off bed
                                        M106 S0 ; turn off part fan
                                        M291 P"Print finished" R"Post-Print Macro" S1 T10
                                        What is really frying my brain is that I do something very similar in a Pre-Print macro which calls another almost identical macro to set the tool temps to 210, and that works as expected.
                                        For the sake of completeness, here is a "Pre-Print" macro which works as expected
                                        ; Pre-print gcode 45deg bed, 210 hot end
                                        M291 P"Heating bed to 40 degC " R"Pre-Print PLA" S1 T10
                                        M190 S40; start heating bed and wait for it to get to 40
                                        M291 P"Homing all axes" R"Pre-Print PLA" S1 T10
                                        M140 S45; Now start to heat bed to 45 but don't wait
                                        M98 P"0:/macros/PrePrintHome.g" ; home all axes (at high temp)
                                        M98 P"0:/macros/ToolTemps/ToolTemps210.g" ; set the tool temperatures to 210
                                        G1 X80 Y363 F9000 ; move to rear
                                        M83;
                                        M291 P"Waiting for heaters to reach active temperatures" R"Pre-Print Macro" S1 T10
                                        M116 ; wait for all temps including hot end
                                        M291 P"Wiping nozzle" R"Pre-Print PLA" S1 T5
                                        M98 P"0:/macros/Nozzle wipe"
                                        So, I can't fathom why calling a macro to set the tool temps works from within a "pre-print" macro and also "stand alone" but calling it from within my post-print macro brings up errors.
                                          @deckingman said in Conditional gcode help required - New Problem:
                                          If you use code escapes (three back-quote characters at the start and end of the block) then it will preserve the indentation:
                                          Please either post the contents of the non-working macro in this way, or attach it as a file
                                          • arhiundefined
                                            arhi @deckingman
                                            you can do it like this:
                                            or withot "type of the code" like this
                                            and if you want to quote it in-line you do it like this
