Conditional gcode help required - New Problem
@bearer Brilliant!
As you say "#tools" seems to evaluate to the highest tool number which is just what I want.
So now I can define any number of tools (up to the limit of 50), and use any tool numbers including non-sequential ones, and the macro will always set the active and standby temperatures for all of the defined tools - and without throwing up any errors.
Which means I just need a single macro for each filament type (PLA, PET-G, ABS etc) and it will work regardless of whether I'm using a single input hot end, a 3 colour Diamond hot end, a 5 colour Diamond, or my own 6 colour (if I ever get it working).
Many thanks indeed!
@deckingman said in Conditional gcode help required:
Many thanks indeed!
No worries, looking forward to seeing what you come up with next
@bearer I'm one step ahead of you and already thinking about it.
At the end of every print, I run another macro which sets the active and standby temperatures to 0 (I could use -273.something to turn them off but 0 will do). So it occurs to me that if I had another "if" statement, I could use the same macro for both pre-print and post print.
Something like
if the tool set temperature (G10 S or R parameter) >0, set it to 0 else set it to (say) 210.How would I do that?
Can I use something like this
After the echo "setting temp for tool"
if G10 P{iterations} S >0
(indented) G10 P{iterations} S210 R210
(not indented) G10 P{iterations} S0 R0Does that work as an "else"?
no else needs to be explicit; without it it will revert the changes on every run immediately as the last line will always execute.
you're on the right track, but have to access the object model instead of the G10 g-code.
something like
if tools[#tools].activeTemp > 0 ;set the temp to 0 else ;set the temp to 210
I'm not sure about the correct object model node, but will try to poke it some more later, stepping out for a bit now that the sun is no longer scorching everything in an instant.. (and deliberately testing the last tool as it will be defined, the first might not)
@bearer
if tools[#tools].activeTemp > 0should be
if tools[#tools-1].activeTemp > 0
Tools array starts at zero, whereas number of tools starts at 1
to poke the object model you can user
M409
it will print out the top level object model in a flat JSON string, use something like https://jsonformatter.org/ to make it more readable.M409
shows the tool object, and you can dig further withM409 K"tools"
which return an array of tool objects,M409 K"tools[19]"
will return the last tool object. (The returned JSON string will have the actual object model inside the result object - for forM409 K"tools[19]"
you should haveresult.active[0]
for the active temp, but the object model will not use theresult
as part of the path, but it will need thetools[19]
as part of the path giving youtools[19].active[0]
. (why active is an single element array idk so this may break in wonderful and unexpected ways)I now see your thinking was to look at each individual tool inside the loop, but my thinking was to look at the last tool and have two loops - subtle difference. Not sure if either is better, depends a little on wheather or not all tools will be in the same state.
taking
if G10 P{iterations} S >0 G10 P{iterations} S210 R210 G10 P{iterations} S0 R0
and inserting into
;/macros/tool.g echo "Running toosl.g" while iterations < #tools if tools[iterations] != null echo "Setting temp for tool T", iterations G10 P{iterations} S1 R0 ; - set it's active and standby temperature echo "done"
you get
;/macros/toggletools.g - toggles stand by temps for all tools. echo "Running toggletools.g" while iterations < #tools if tools[iterations] != null if tools[iterations].active[0] > 0 echo "Turning off tool T", iterations G10 P{iterations} S0 R0 else echo "Turning on tool T", iterations G10 P{iterations} S210 R210 echo "done"
edit looking back there was something amiss with
tools[#tools-1]
so worked out well to go with your approach and a single loop avoidingtools[#tools-1]
@bearer Thanks very much for putting the time into this, and also thanks for the lessons.
Having slept on it and thought about it some more, I can foresee a few scenarios where having a single "toggle" macro could be problematic. I'm often "tinkering" and even my home Z will pre-heat the nozzle. So it is likely that sooner or later, the active temperature might be other than zero when the macro is called but the intention is to set the tools to print temperature. If the active temperature is non zero, then the tool(s) will be set to zero which would be the opposite of what is intended. For that reason I think it will be safer to use two separate macros, one which will explicitly set the temperatures to print temperature, and the other to set them to zero.
But thanks again for showing me how to do it. I'm sure that knowledge will be useful in the future.
And thanks also to @OwenD for your contribution.
Edit - I've changed the title to show (in an unconventional way) that this is solved.
With a multi-input mixing hot end, one defines tools (colours) by using combinations of extruders and then setting mixing ratios for those extruders. But having a large number of tools defined at once, takes up too much space on the web interface. I haven't yet worked out the best way to deal with that but one option would be to have a "palette" of 50 tools but only use a selection of that full palette defined at any one time.
I think that when version with support for variables come up this should be easier. In theory (we'll see whent he variable support is out) you could have something like a config variable that you set in the config.g header and then you have each tool defined in it's separate .g file and then according to that variable you call the specific number of g-code files... and since it all works in runtime with RRF you could have your slicer startup file do something like:
$bt={bed_temperature} ; copy bed temp from slicer to $bt variable $ht={hotend0_temperature} ; copy hotend temp from slicer to $ht variable $htsb={hotend0_standbytemperature} ; set standby temperature for hotend to $htsb $tool_combination=7 ; Use specific set of configured tools M98 P"start_print.g" ; call start_print.g macro
and then in start_print.g you have something like
if $tool_combination == 0 M98 P"configure_tool_1.g" M98 P"configure_tool_4.g" M98 P"configure_tool_5.g" else if $tool_combination == 1 M98 P"configure_tool_1.g" M98 P"configure_tool_2.g" M98 P"configure_tool_3.g" else if $tool_combination == 2 M98 P"configure_tool_4.g" M98 P"configure_tool_8.g" else if $tool_combination == 3 M98 P"configure_tool_4.g" M98 P"configure_tool_5.g" M98 P"configure_tool_6.g" M98 P"configure_tool_7.g" ... else if $tool_combination == 30 M98 P"configure_tool_14.g" M98 P"configure_tool_15.g" M98 P"configure_tool_20.g" else abort "You did not set valid tool_combination value" M200 D0 ; do not use volumetric extrusion M83 ; relative extruder ; heat up ; heat up bed first M140 S{$bt} M190 S{$bt} ; heat up extruder while iterations < #tools if tools[iterations] != null if tools[iterations].active[0] > 0 echo "Turning off tool T", iterations G10 P{iterations} S0 R0 else echo "Turning on tool T", iterations G10 P{iterations} S{$ht} R{$htsb} ; do not home if already homed if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed G28 M98 P"wipe.g" ; do the wipe G29S1 ; use MESH compensation M913 X100 Y100 Z100 ; all currents to 100% M290 R0 S0 ; reset baby steps ; reset speed overrides M221 S100 M220 S100 ; Dynamic Acceleration Adjustment ; M593 Fxxx ; Pressure Advance M572 D0 S0.03 ; ...
in theory, this start_print.g can be something you call before number of other operations as it will reconfigure your tools based on the input variable ...
in any case, variables should come with 3.2 and if I understood dc42 properly they are now testing new batch of toolboard they got from the supplier so question is when will this come around and how will the variables work... but I believe you understand the basic idea
@arhi Yes, I had been thinking along those lines myself. Essentially taking the tool definitions out of config.g and putting them in one or more macros.
For info, I already use pre-and post print macros which take care of the everything from heating the bed to homing and purging (as well as setting tool temperatures which will now be done by calling this new macro). That's mostly because it gives me better control over the order that things happen. For example, I pre-heat the bed to around 40 and wait. Once it reaches 40 I set the bed to (say) 55 but don't wait and commence homing and all the other stuff. The net result is that homing, heating tools, and purging all happen within the time it takes for the bed to reach temperature, but not too soon before to minimise the time that the hot end is at print temperature before printing starts.
@bearer said in Conditional gcode help required - SOLVED:
edit looking back there was something amiss with tools[#tools-1] so worked out well to go with your approach and a single loop avoiding tools[#tools-1]
My bad.
Should have been tools[(#tools-1)]The equation must be in braces
@OwenD said in Conditional gcode help required - SOLVED:
braces
dammit, i only tried curly braces. noted
edit: interesting:
6/18/2020, 11:43:48 AM M409 K"tools[19]" {"key":"tools[19]","flags":"","result":{"active":[0],"axes":[[0],[1]],"extruders":[0,1,2,3,4],"fans":[0],"filamentExtruder":-1,"heaters":[1],"mix":[10.00,0,0,0,0],"name":"All6","number":19,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":2.0,"speed":16.7,"unretractSpeed":16.7,"zHop":0},"standby":[0],"state":"off"}} 6/18/2020, 11:43:35 AM M409 K"tools[(#tools-1)]" {"key":"tools[(#tools-1)]","flags":"","result":null} 6/18/2020, 11:39:30 AM echo (#tools-1) 19 6/18/2020, 11:39:15 AM echo {(#tools-1)} 6/18/2020, 11:39:04 AM echo {#tools-1} 6/18/2020, 11:38:56 AM echo {#tools} 20
I now have a new problem which is frying my brain somewhat. I have this macro to set the tool temps to zero at the end of a print:
G10 P{iterations} S0 R0 ; - set it's active and standby temperatureIt is correctly indented - but this forum removes the indents when I do a copy and paste.
This macro works like a charm if I simply run it. But when I put inside my "Post-Print" macro I get a bunch of errors - "Error G10: 'iterations' used when not inside a loop". And of course the temperatures don't get changed. But I can run that macro "stand alone", immediately afterwards and it'll work just fine.
Here is my Post-Print Macro
;End print gcode
G10 ; retract
G91 ; set relative
G1 Z5 F240 ; move bed down 5mm
G90 ; back to absolute
G1 X165 Y300 F9000 ; move to rearM98 P"0:/macros/ToolTemps/ToolTemps0.g" ; set the tool temperatures to 0
M140 S0 ; turn off bed
M106 S0 ; turn off part fanM291 P"Print finished" R"Post-Print Macro" S1 T10
What is really frying my brain is that I do something very similar in a Pre-Print macro which calls another almost identical macro to set the tool temps to 210, and that works as expected.
For the sake of completeness, here is a "Pre-Print" macro which works as expected
; Pre-print gcode 45deg bed, 210 hot end
M291 P"Heating bed to 40 degC " R"Pre-Print PLA" S1 T10
M190 S40; start heating bed and wait for it to get to 40
M291 P"Homing all axes" R"Pre-Print PLA" S1 T10
M140 S45; Now start to heat bed to 45 but don't wait
M98 P"0:/macros/PrePrintHome.g" ; home all axes (at high temp)M98 P"0:/macros/ToolTemps/ToolTemps210.g" ; set the tool temperatures to 210
G1 X80 Y363 F9000 ; move to rear
M83;M291 P"Waiting for heaters to reach active temperatures" R"Pre-Print Macro" S1 T10
M116 ; wait for all temps including hot end
M291 P"Wiping nozzle" R"Pre-Print PLA" S1 T5
M98 P"0:/macros/Nozzle wipe"So, I can't fathom why calling a macro to set the tool temps works from within a "pre-print" macro and also "stand alone" but calling it from within my post-print macro brings up errors.
@deckingman said in Conditional gcode help required - New Problem:
G10 P{iterations} S0 R0 ; - set it's active and standby temperatureIf you use code escapes (three back-quote characters at the start and end of the block) then it will preserve the indentation:
while iterations < #tools if tools[iterations] != null echo "Setting temp for tool T", iterations G10 P{iterations} S0 R0 ; - set it's active and standby temperature
Please either post the contents of the non-working macro in this way, or attach it as a file
you can do it like this:
or withot "type of the code" like this
and if you want to
quote it in-line
you do it like this -
looking at the code it should work as expected. better upload files directly as this "space formatting" can be the source of the problem
OK. Thanks all for the info about preserving indentations.
By a process of elimination I have isolated what causes the error. It is the preceding Z move. That is is to say, if I comment out the two lines below so I have ..........
G10 ; retract
;G91 ; set relative
;G1 Z5 F240 ; move bed down 5mm
..............Then I get no errors and the macro runs just fine.
Or if I just re-arrange things so that the macro runs before the Z move, it works fine too. i.e. I now have.................
;End print gcode
G10 ; retract
G91 ; set relative
G1 X165 Y300 F9000 ; move to rearM140 S0 ; turn off bed
........and this work fine. So it's either the preceding G91 switching to relative, or the G1 Z5 that breaks the conditional macro.
@arhi said in Conditional gcode help required - New Problem:
and if you want to quote it in-line you do it like this
you can even escape things with \ like `quote it in-line` becomes
quote it in-line
and then you can go all inception to show \`quote it in-line\` and then you can...edit: you can use double (as in two) quotes to avoid escaping single quotes (and three to escape two and so on..)
``single `quote` ``
becomessingle `quote`
I spoke too soon. I just ran a print with the end gcode macro as per my last post above and received the errors "Error G10: 'iterations' used when not inside a loop". I ran that same post-print macro again, and it worked without errors on that second try.
So it's seemingly random. Some times it runs without error, other times I get those errors.
Here is the macro yet again:
Can you confirm that you are running firmware 3.1.1 on the main board?
