    Strange behavior with Bl touch
    613
      Phaedrux Moderator @Marco Bona
      @Marco-Bona said in Strange behavior with Bl touch:
      at the start of printing a new tool is created with the coordinates of the probe which is then deleted once any other tool is called
      Can you describe that a bit more please?
      Can you send M115 and verify your firmware version?
        What do you have in M98 P"customconfig.g" that gets called at the end of config.g?
          Remove M401 and M402 from your bed.g
          M401                          ; deploy Z probe if necessary
          G30 P0 X-140 Y0 Z-99999       ; left lead screw
          G30 P1 X140 Y0 Z-99999 S2     ; right lead screw
          M402                          ; retract the Z probe
            Also include your homeall.g and your slicer start gcode please.
            • Marco Bonaundefined
              Marco Bona
              @Phaedrux, I have understand where the problem lies, I have a small motor very close to the probe, if I enable the motor before touching the bed it creates some disturbance at bltouch.
              I am doing some tests but it would seem solved.
              Another problem I am having is the continuous restart of panel due once the bed reaches the temperature, I also tried to enable the bang-bang function but nothing changes. The bed is 24v, the card is connected to an ssr, do I have to put a restorer or something between the card and the ssr?
              PDBealundefined 1 Reply Last reply Reply Quote 0
                I would suggest you use PID for the bed instead of bang bang. Try to seperate your power wiring from signal wiring. Twisting the wire pairs can help as well.
                https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                  Marco Bona
                  @Phaedrux , i tried all the options you suggested but i didn't get anything. Just out of curiosity because I didn't find detailed information, do you suggest putting ssr before or after load?
                    I'm sorry,I don't understand the question.
                    • PDBealundefined
                      PDBeal @Marco Bona
                      From what I read before I went with BLTouch sensors on all my machines, they're very sensitive to noise. To combat this, on all my machines I've threaded the wires through a braided shield I bought from McMasterCarr. It's paid of as I don't have any repeatability issues with any of them, and two of them run next to motors and heater wires. I do heat shrink both ends to prevent the braided shield from fraying.
                      Interference-Shielding Expandable Sleeving
                      1/4" ID
                        Marco Bona
                        @PDBeal ,great advice!! Thanks for the info
                          Marco Bona
                          @Phaedrux, sorry for the bad english ...... I hope you can make understand otherwise I will make a drawing, do you recommend putting SSR before or after heated bed?
                            @Marco-Bona You would switch the live side, not the ground side.
                            But if the bed is 24v why use an SSR?
                              Marco Bona
                              @Phaedrux ,I try to invert it, the bed is powered by 24v but I believe that the connection does not change.
                              Check it out and I'll update you, thanks
                                @Phaedrux said in Strange behavior with Bl touch:
                                  Marco Bona
                                  @Phaedrux, just for safety
                                    Marco Bona
                                    @Phaedrux, I finally managed to solve, all the fault of bad insulation of heated bed ...........
