    Strange behavior with Bl touch
    613
      Also include your homeall.g and your slicer start gcode please.
      • Marco Bonaundefined
        Marco Bona
        @Phaedrux, I have understand where the problem lies, I have a small motor very close to the probe, if I enable the motor before touching the bed it creates some disturbance at bltouch.
        I am doing some tests but it would seem solved.
        Another problem I am having is the continuous restart of panel due once the bed reaches the temperature, I also tried to enable the bang-bang function but nothing changes. The bed is 24v, the card is connected to an ssr, do I have to put a restorer or something between the card and the ssr?
        PDBealundefined 1 Reply Last reply Reply Quote 0
          I would suggest you use PID for the bed instead of bang bang. Try to seperate your power wiring from signal wiring. Twisting the wire pairs can help as well.
          https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
            Marco Bona
            @Phaedrux , i tried all the options you suggested but i didn't get anything. Just out of curiosity because I didn't find detailed information, do you suggest putting ssr before or after load?
              @Marco-Bona said in Strange behavior with Bl touch:
              I'm sorry,I don't understand the question.
              • PDBealundefined
                PDBeal @Marco Bona
                From what I read before I went with BLTouch sensors on all my machines, they're very sensitive to noise. To combat this, on all my machines I've threaded the wires through a braided shield I bought from McMasterCarr. It's paid of as I don't have any repeatability issues with any of them, and two of them run next to motors and heater wires. I do heat shrink both ends to prevent the braided shield from fraying.
                Interference-Shielding Expandable Sleeving
                1/4" ID
                  Marco Bona
                  @PDBeal ,great advice!! Thanks for the info
                    Marco Bona
                    @Phaedrux, sorry for the bad english ...... I hope you can make understand otherwise I will make a drawing, do you recommend putting SSR before or after heated bed?
                      Phaedrux Moderator @Marco Bona
                      @Marco-Bona You would switch the live side, not the ground side.
                      But if the bed is 24v why use an SSR?
                        Marco Bona
                        @Phaedrux ,I try to invert it, the bed is powered by 24v but I believe that the connection does not change.
                        Check it out and I'll update you, thanks
                          @Phaedrux said in Strange behavior with Bl touch:
                            Marco Bona
                            @Phaedrux, just for safety
                              Marco Bona
                              @Phaedrux, I finally managed to solve, all the fault of bad insulation of heated bed ...........
