    Large printer- nema 23 and power supply questions
    413
    • kaduhn1undefined
      kaduhn1
      So I'm in the process of building a roughly 2 foot by 3 foot printer. Budget allows me to spend more on stepper motors so i was looking at Nema 23 due to the size of the printer and the lack of space constraints.
      I found out that you can get motors in basically any voltage and amp rating as you want.
      I've mainly been looking at these https://openbuildspartstore.com/nema-23-stepper-motor/
      So they're 24-48 volt. Under the amp rating for the duet 3. To choose a power supply I'd go with a 24 volt supply. Do the motors draw as much amperage and voltage as they're designed for or is that set somehow? the power supply just needs to have enough amp and wattage to cover all the motors correct?
      the Hot end is going to be 24 volt as well so I don't need to worry about that but what if I ended up getting a higher voltage power supply for the motor? Does the board automatically supply the correct voltage of 24V?
      https://www.trcelectronics.com/View/Mean-Well/RSP-750-24.shtml this is the power supply i was quickly looking at. Should have plenty of amp and wattage to supply everything.
        This may help:
        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
        https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
        kaduhn1undefined 1 Reply Last reply Reply Quote 0
        • kaduhn1undefined
          kaduhn1
          This post is deleted!
          • kaduhn1undefined
            kaduhn1 @Phaedrux
            @Phaedrux
            yeah i've read those but it doesn't really answer my question entirely. just says use 24 volt.
            what if the motor i go with is a lower voltage motor? Do the drivers just automatically supply the right voltage and amp?
              @kaduhn1 said in Large printer- nema 23 and power supply questions:
              You set the amperage with the M906 command and the driver ensures the motors get the right current you've set. The voltage rating isn't relevant. These are constant current drivers.
              Stepper motors and drivers are a pretty deep topic. If you want to learn more you'll have to do some more research, but for our purposes you just need to choose motors that are within the current limit of the duet and choose a PSU good 24v PSU.
              https://www.orientalmotor.com/stepper-motors/technology/stepper-motor-overview.html
              • kaduhn1undefined
                kaduhn1 @Phaedrux
                @Phaedrux ok so i'm thinking too much about it. get a 24 volt supply big enough that it can power everything it needs to. make sure fans and heaters are 24 volts etc. Set the amp with M906 and it'll supply the right amp and voltage.
                  Yes.
                  For fans you can use a buck converter to supply 12v if you wish as there are a wider selection of 12v fans available.
                  https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
                  But for heaters, yes, they should be natively 24v.
                  deckingmanundefined 1 Reply Last reply Reply Quote 1
                    deckingman @Phaedrux
                    @Phaedrux said in Large printer- nema 23 and power supply questions:
                    Yes.
                    I believe the OP mentioned using Duet 3. In which case, it already has a 12v regulator which can be used by setting the appropriate jumpers (no need for the buck converter). The documentation you linked to ought perhaps be updated to include this for gen 3 hardware?
                    kaduhn1undefined Phaedruxundefined 2 Replies Last reply Reply Quote 2
                    • kaduhn1undefined
                      kaduhn1 @deckingman
                      @deckingman I do have some step down converters already so either way im good there.
                      but you are right i think. and yes- better fans with 12 volt available.
                        deckingman @kaduhn1
                        As long as you don't do what I once did and connect 12V fans but forget to move the jumper across, thus putting 24V across them 🙂
                        kaduhn1undefined 1 Reply Last reply Reply Quote 1
                        • kaduhn1undefined
                          kaduhn1 @deckingman
                          @deckingman i'll have backup fans...... for reasons....
                            Phaedrux Moderator @deckingman
                            @deckingman said in Large printer- nema 23 and power supply questions:
                            Note added.
