    'Jumpy' X/Y movement on Maestro
    481
    • dm86undefined
      dm86
      Hi all,
      I'm using a Maestro on an old Rigidbot. Been working fine for a while but all of a sudden the movements have stopped being smooth. It is moving in about 1 inch increments, the same on both X & Y so confident its not mechanical.
      Youtube Video here.
      M122 shows timeout out on 3 drivers. A few on driver 3 but 100% on 5 & 6. Is this normal of a symptom of my problem?
      M122
      RepRapFirmware for Duet 2 Maestro version 2.05.1 running on Duet Maestro 1.0
      Board ID: 08DJM-9P6T2-L43S4-7JTD4-3SJ6Q-TBSRQ
      Used output buffers: 3 of 24 (23 max)
      Static ram: 19804
      Dynamic ram: 87372 of which 0 recycled
      Exception stack ram used: 364
      Never used ram: 23532
      Tasks: NETWORK(ready,764) HEAT(blocked,1264) MAIN(running,3896) IDLE(ready,160)
      Owned mutexes:
      Last reset 04:40:26 ago, cause: software
      Last software reset at 2020-06-20 17:08, reason: User, spinning module GCodes, available RAM 23572 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 8
      SD card 0 detected, interface speed: 15.0MBytes/sec
      SD card longest block write time: 104.6ms, max retries 0
      MCU temperature: min 27.9, current 30.6, max 50.8
      Supply voltage: min 0.0, current 23.9, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: ok, read errors 0, write errors 1, ifcount 32, reads 17625, timeouts 0
      Driver 1: ok, read errors 0, write errors 1, ifcount 34, reads 17623, timeouts 0
      Driver 2: ok, read errors 0, write errors 1, ifcount 34, reads 17625, timeouts 0
      Driver 3: ok, read errors 0, write errors 1, ifcount 22, reads 17602, timeouts 27
      Driver 4: ok, read errors 0, write errors 1, ifcount 34, reads 17625, timeouts 0
      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 17637
      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 17637
      Date/time: 2020-06-20 21:49:02
      Slowest loop: 104.81ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 156, MinFreeDm: 108, MaxWait: 3105021ms
      === DDARing ===
      Scheduled moves: 71370, completed moves: 71359, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Bed heaters = 0, chamberHeaters = -1 -1
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.3
      Segments left: 3
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 2
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 106.31ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      Config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Mar 26 2020 22:56:52 GMT+0000 (Greenwich Mean Time)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Rigidbot"                                   ; set printer name
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0 S1                                         ; X physical drive 0 goes backwards
      M569 P1 S1                                         ; Y physical drive 1 goes backwards
      M569 P2 S1                                         ; Z physical drive 2 goes backwards
      M569 P3 S0                                         ; E physical drive 3 goes forwards
      M584 X0 Y1 Z2:4 E3                                   ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X200.00 Y200.00 Z1600.00 E135.00               ; set steps per mm
      M566 X900.00 Y1100.00 Z10.00 E200.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z400.00 E8000.00         ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00             ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1500 E1600 I20                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S50                                            ; Set idle timeout
      M671 X-76:302 Y0:0 S8 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X250 Y230 Z250 S0                             ; set axis maxima
      M574 X1 Y1 S0                                      ; set active low and disabled endstops
      M574 Z1 S2                                         ; set endstops controlled by probe
      M558 P1 H2 I0 F120 T12000 A10 S0.01
      G31 P500 X53 Y0 Z1                             ; set Z probe trigger value, offset and trigger height
      M557 X65:215 Y30:210 S8.5                           ; define mesh grid
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R2200                        ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      M305 P1 X200                                       ; configure PT100 for heater 1
      M143 H1 S350                                       ; set temperature limit for heater 1 to 350C
      M106 P0 C"Part Fan" S0 I0 F500 H-1 L80 B0.5     ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 C"Driver Fan" S0 I0 F500 H1 T80 L255
      M106 P2 C"Hotend Fan" S0 I0 F500 H1 T80 L255 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"Extruder" D0 H1 F0                       ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      M929 P"eventlog.txt" S1										; Enable logging
      M501
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        @dm86 said in 'Jumpy' X/Y movement on Maestro:
        Z10.00 E200.00
        I would suggest increasing your Z and E jerk speeds. Try Z100 and E2000
        • dm86undefined
          dm86
          Will give it a go, config not changed so odd its just started. Will report back...
            Stutter like that is usually because of low jerk on Z and having mesh compensation active. Low E jerk may also contribute when using pressure advance and could be triggered by the model/gcode as well.
            What slicer are you using? there was a bug in a recent version of Cura that has since been fixed that caused stuttering. Updating Cura to 4.6.1 fixes it.
            • dm86undefined
              dm86
              CURA but I am on 4.6.1.
              I think your correct on the mesh. Upping these values has smoothed it out but not corrected it.
              Just checked my latest mesh and it does look like a mountain range for some reason. Can't get my head around the scale of this though, is the deviation on this significant?
              Using differential IR sensor on glass bed.
              JoergS5undefined 3 Replies Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @dm86
                @dm86 you have driver 4 not defined with M569, but use it in M584 for Z. After correction some of the errors may go away.
                  I suggest you clean the bed really well before redoing the heightmap. It will pick up all the glue gunk.
                  You can also add a taper off for the compensation.
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M376_Set_bed_compensation_taper
                  • JoergS5undefined
                    JoergS5 @dm86
                    @dm86 you could also check whether the M906 setting for x and y motors 1800 is not too high. It should be about 50 to 80 % of the stepper current, please check documentation.
                    The M92 setting of 200 for x and y seem strange to me, do you have 400 step per round stepper (0.9 degree) with 16 teeth pulley? Otherwise 200 could be wrong.
                    • JoergS5undefined
                      JoergS5 @dm86
                      This post is deleted!
                      • dm86undefined
                        dm86
                        Thanks all,
                        Will have another go today and report back.
                        @JoergS5 said in 'Jumpy' X/Y movement on Maestro:
                        Good spot. I don't think it will make a difference but will correct and see. Thanks.
                        Your right on the currents. I'm not sure how accurate they are though. They are 2A steppers but if I go lower they start to miss steps. I used a Duet2 Wifi on here before and had them quite a bit lower with no issues.
                        M92 is correct, that is what I have. Dimension accuracy is spot on.
                        • dm86undefined
                          dm86
                          Thanks all.
                          Problem solved. Was combo of dodgy bed mesh caused my loose mounting screw on sensor & low Z jerk.
                          Simplified the mesh too as being glass its pretty flat, just often on a tilt.
                          • JoergS5undefined
                            JoergS5 @dm86
                            @dm86 your tilt could be due to different stepper positions of the Z steppers, when you power on.
                              You may want to try this: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                              dm86undefined 1 Reply Last reply Reply Quote 0
                              • dm86undefined
                                dm86 @Phaedrux
                                @Phaedrux Thanks. I did but had real trouble getting it to work reliably. However that was using a capacitive sensor and was my main reason for changing to IR.
                                My X is usually fairly stable anyway. Its my Y that I have issues taking the tilt out of.
