    How to setup the Bigtreetech smart filament sensor?
    Third-party add-ons
    15
    55
    11.3k
    • arhiundefined
      arhi
      Most probably it is dual smidth 74xx2g14. If you could reverse engineer schematic that would be great.
      But looking at images, output from the LDR goes to input2 ... see if you can see where the pins 4 and 6 from the U1 go. Pins 2 and 5 are Vss and Vcc, 4 and 6 are outputs, it is possible one is going directly to the signal pin on the connector.
      Also check if Vcc and Vss from the connector go directly to pins 5 and 2.
      This should be powered from 3v3 and should have 3v3 pulses on the signal output..
      For test, no resistor needed as this does not have open drain output.
      1. supply 3.3V to Vcc, ground to Vss
      2. measure voltage between pins 2 and 5 (middle pins) on U1
      3. measure voltage across LED
      4. use camera phone, see if you can see if LED is emitting light (you should be able to see IR light with most phone cameras, check also some remote controller if you can see the light with camera when you press a button)
      5. Measure voltage on U1 pins 1 and 3 (input)
      6. measure voltage on U1 pins 4 and 6 (output) - check if they are inverted 1-3
      7. measure resistance U1 pins 4 and 6 to the signal pin on the connector
      Infinitysnekundefined 1 Reply Last reply Reply Quote 1
      • zaptaundefined
        zapta @Infinitysnek
        @Infinitysnek said in How to setup the Bigtreetech smart filament sensor?:
        with the resistor between Out and GND
        I think arhi suggested a resistor between Out and Vin.
        Infinitysnekundefined 1 Reply Last reply Reply Quote 0
        • Infinitysnekundefined
          Infinitysnek @arhi
          @arhi This is what I could find and its only confusing me more and more. If 4 &6 are supposed to be outputs one goes to what I thought was Vcc and the other to a pin that is not even connected to anything.
          Based on the schematic I switched Vcc and Out around to test but then the IR led is turning on.
          2.55V
          1.113V
          I am not really getting a consistent reading on both of them sometimes its around 1.1V, around 0.8V or nothing and 4&6 are usually inverted but not always
          Pin6 - Signal = 1.3M ohm
          Pin4 - Signal = 24.4 ohm
          arhiundefined 2 Replies Last reply Reply Quote 0
            Infinitysnek @zapta
            @zapta said in How to setup the Bigtreetech smart filament sensor?:
            I tried it both ways, the first one was between Out and Vin the second between Out and GND
            • arhiundefined
              arhi @Infinitysnek
              Looking at this schematic, I'd say the names on the J1 are all wrong 😞
              Fors start, the main thing to do is to get the IR led to power on.
              In order to power the IR LED on you need Ground (Vss) to be on J1-4 and 5V (Vcc) on J1-1. Bringing 5V between pins 1 and 4 should get the LET to turn on as that will directly power the LED trough R1.
              If that works, this will automatically properly power the C145 as U1-2 is Vss and U1-5 is Vcc and that correspond with 5V on J1-1 to J1-4.
              In this case output of the U1 are pins J1-2 and J1-3 and are alternating from what I see so you should be able to use either as the signal to the duet's sensor input.
              All this hoping that all the parts on the board are working ok, as by connecting them with wrong pinout you might kill the U1
              Note that to test the outputs properly the whole thing needs to be closed or in the dark so that P1 only see the light from the IR diode and not ambient light.
                Infinitysnek @arhi
                @arhi I changed the pins around, this made the led turn on and got 3.3V over pin 2 - 5 so that's all good now. Measured the voltage over 1 & 3 while turning the wheel and that does seem to give a 1V pulse consistently but nothing happens overt 4 & 6. The IC is not getting hot so either something is going wrong or the IC is already dead i guess?
                I updated the schematic to reflect the changes and I do have to say this makes more sense now πŸ™‚
                • arhiundefined
                  arhi @Infinitysnek
                  The Vt+ when operating from 3V source per datasheet is 1.3-2.2V so 1V is not enough to trigger that schmitt. Check if will trigger better if you power the contraption from 5V.
                  Not sure if input on the duet is 5V tolerant (@dc42 should know) so if it works when powered from 5V you will probbly need a voltage divider on the output before feeding it to duet. But for now, just test it without any connection to duet.
                  To test the U1 on it's own you can bring Vcc to pin1 and expect 0V on the pin6 and also Vss to pin1 and expect 5V on pin6, just to be sure the U1 is not dead. Shorting U1-1 to Vcc or Vss should not damage anything.
                  BTW are you sure about schematic? The C1 seems weird, maybe they did it like this to just have a single pulse even if the hole is there for a while
                  • arhiundefined
                    arhi @Infinitysnek
                    I have to say the schematic as a whole does not make too much sense to me.
                    Vcc directly on the base of the foto transistor will keep it always open ?!?! for e.g. maybe Vcc is in the collector? SFH303 is BCE footprint:
                    but from the pictures I see it's a square piece, not the round one so.. who knows what PRC made pos is that 😞
                    Anyhow, assuming the schematic works 2 and 3 pins should have the pulses out if nothing is dead on that board.
                      Infinitysnek @arhi
                      @arhi Oh yes i could not find writing on the sensor so i just took something from the eagle library that roughly looked the same
                      • arhiundefined
                        arhi
                        yes probably the vcc is in the collector.. if that's npn at all ..
                        did you manage to test the U1 and output on J1-2 and J1-3 ?
                          Infinitysnek @arhi
                          @arhi said in How to setup the Bigtreetech smart filament sensor?:
                          I'm not exactly sure what you mean by this. Should i bridge Vcc or vss to U1-1 then measure over U1-6 and Vss?
                          With 5V I get a 1,7V pulse so that should be high enough however i'm getting a constant 1,3V on the output now
                          • arhiundefined
                            arhi @Infinitysnek
                            yes.
                            I fear that U1 is dead. The schmitt output can only be 0 or Vcc (with a very little offset), the output of 1.3 on the 4 or 6 pin should only happen if you power it from 1.3V
                              Infinitysnek @arhi
                              @arhi Well thats too bad. The chips is fairly cheap at €2 for 20 so ill get some and replace the chip when it arrives in a month or so.
                              It is impossible for me to bridge the 2 pins and probe 2 others at the same time so Im going to assume its dead.
                              Thank you for your help so far I really appreciate it πŸ˜„
                              • arhiundefined
                                arhi
                                double check if those outputs go really directly to the connector trough 200R or maybe they have some other links that you missed but on the output pins really you should not see anything except 0/1 (Vss/Vcc).
                                Also, if you have any other schmitt inverter you can bodge it there.. should work..
                                Infinitysnekundefined 2 Replies Last reply Reply Quote 0
                                  Infinitysnek @arhi
                                  @arhi I will check tomorrow. I don't have any schmitt inverters laying around but I did found another online: NC7WZ14P6X. Seems similar and should be here within a week.
                                    Infinitysnek @arhi
                                    @arhi I was going to replace the chip today until i found out its even smaller and doesn't fit 😞
                                    I ordered new ones but that will take a while to arrive... IMG_20200627_143036.jpg
                                      A Former User
                                      if its pin-compatible you could try stretching and bending the legs to force it onto the bigger pad.
                                      (apply liberal amounts of "carefulling" first)
                                      or solder thin wires from the pad to the leads. if current situation means huge delays I'd be inclined to try it.
                                      edit: i've only had to use bigger chips on smaller pads, but having given it a second thought I'd flatten the legs to they come straight out the side of the chip to make up the missing length, angle them outwards to align with the pads, then just solder a wire between the pad on the board and lead of the chip that would otherwise be floating in air. once you got one down the rest should be simple-ish.
                                      • arhiundefined
                                        arhi
                                        uh, I hate when it happens...
                                        @omni will bring his one to me these days ('cause mine is not arriving for months now 😞 ) so I can do some real life testing here ... I finished the new "case" for my encoder last night
                                        it's not a fancy package like the btree sensor but it does not restrict filament flow as much as btree one does and it's 600 impulses per rotation so ~8 impulses per mm instead of 1 impulse every 7mm πŸ™‚ and these encoders are 5-6eur delivered so 3x cheaper than btree one πŸ™‚
                                        anyhow I'm waiting for the tests you do after you replace the chip.
                                        btw, one quick test you should be able to do during the weekend .. if you have hotair gun, heat it up a bit and just lift the pin1 and pin6 from the pcb so they don't touch any of the circuitry ... power the chip with 5V and measure output on the pin6 when you short the pin1 to ground and to 5V (should be easy to just solder a jumper wires so you can easily measure) just to be 100% sure that chip is dead ... or if you already desoldered it (I think you did), just solder the 4 wires (1,2,5,6) and try "in the air" ...
                                        and I agree with @bearer few wires and that small one can fit, I did it more than once and still hate doing it but it's a fairly quick job if you have a steady hand and ok-ish vision πŸ™‚
                                          Infinitysnek
                                          I have desoldered the chip already yes. I could try soldering on wires, hated doing that last time for a different project but it’s better than waiting a few weeks for new chips.
                                          Does yours work with the duet? If this won’t play nice with the duet I could repurpose the housing for something like that
                                          • arhiundefined
                                            arhi @Infinitysnek
                                            Useful hint, how I do it if I don't want to make a breakout board pcb - hot-glue πŸ˜„
                                            Put some hot-glue on a plate (wood, plastic, cardboard...) and put the chip on its back on that hot glue. This way the chip is held in place, the legs are up in the air much more accessible when the chip is "back up" compared to "back down". Use "magnet wire" (lacquered wire from a transformer or similar device). With some practice, you can even make whole circuits using that (dead bug) technique.
                                            Yes, I had it connected to duet for a while with old design I made, it was disabled but collecting data. Problem was that old design was not very good (not sure if new one is much better we'll see) so the filament got tangled few times and almost ruined the print so I redesigned it and will be adding it back on the duet. This encoders have Vcc, Vss, A and B outputs (AB is from encoder) and I'm using A to send signals to duet and it was working good. What I don't remember is what I used for Vcc :(, IIRC this thing has 7805 inside so can be powered from 6-12V. I have one DCDC hooked on my duet2 to produce 12V for various needs but no clue if that's how I was connecting it. I'll play with it on Sunday again so I'll make a separate post about how it works if anyone wants to use the same el-cheapo encoder from PRC (hoping someone will make a better housing for it πŸ˜„ πŸ˜„ πŸ˜„ .. here if you can see from the images the 608 bearing slides on some rails, is pressed by the spring between that slider and external slider and externan slider is locked in place by the hole on the rail and piece of filament in that hole πŸ˜„ .... on the encoder's shaft I press fitted the printed wheel with concave edge and a wide rubber band wrapped around it to give it "grip" ... I glued the ptfe guide's 'cause during design I had no clue what the position of the wheels will be and after I did it was faster to just glue it in place than to change design and add more material with holes for those tubes πŸ˜„
