Unexpected X movement on tool pickup.
355
    duetlover
    Hi everybody
    I'm using E3D Tool Changer.
    When a tool is not used, the temperature respects Standby configuration.
    For exemple active 220°C, 200°C Standby.
    I want that when a tool is selected, the heat up comes while tool is still parked, not after it has been took and moved to bed.
    So I tried playing with tpre.g file
    I tried with M116 without success.
    ;Unlock Coupler
    M98 P/macros/Coupler - Unlock
    ;Move to location
    G1 X212.9 Y200 F50000
    ;Move in
    G1 X212.9 Y230 F50000
    ;Collect
    G1 X212.9 Y242.5 F2500
    ;Close Coupler
    M98 P/macros/Coupler - Lock
    M116 P2; heat up
    ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING!
    ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool!
    G91
    G1 Z10 F1000
    G90
    ;Move Out
    G1 X212.9 Y150 F4000
    It always moves to the bed and then heat up...
    Thanks !
      OwenD
      Your M116 should be in TPost
      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_files
      You probably need to move your "move out" code there as well.
      undefined 1 Reply Last reply 21 Jun 2020, 14:15 Reply Quote 0
        duetlover @OwenD
        @OwenD
        Moved to tpost and it works, thanks !
        undefined 1 Reply Last reply 23 Jun 2020, 18:24 Reply Quote 0
          duetlover @duetlover
          @sylvain
          So I moved :
          ;Move Out
          from tpre to tpost, after M116
          So it works as it heats up before move out.
          But when it moves out there a little x movement where it should not be...
          I think it is a relative/absolute issue but I don't find the way to solve it...
          Thanks !
            What firmware version are you using? M115 to find out.
              duetlover
              Here it is:
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
                I've edited your post title to match your current issue with X movement on tool pickup.
                undefined 1 Reply Last reply 24 Jun 2020, 20:19 Reply Quote 0
                  duetlover @Phaedrux
                  @Phaedrux
                  That's exactly the issue 😉
                  I partially solved the issue by replacing :
                  to
                  G1 Y150 F4000
                  but even if there was X212.9 it should not move on X at all.
                  Best regards
                  undefined 1 Reply Last reply 24 Jun 2020, 22:16 Reply Quote 0
                    JoergS5 @duetlover
                    @sylvain do you have a G10 offset which is moved when you change the tool?
                    undefined 1 Reply Last reply 25 Jun 2020, 06:31 Reply Quote 0
                      duetlover @JoergS5
                      @JoergS5
                      In fact I have in config.g:
                      G10 P2 X-9.0 Y39.5 Z-4.8
                      And I believe that the x movement is 9mm (when I look on web dashboard, I calculate a 9mm x movement)
                      10 out of 10
