    External SD Card not Reading (Maestro with 12864 Display)
    608
      Is there any indication of what the pinout is on the silk screen of the PCB?
      JadonMundefined 1 Reply Last reply Reply Quote 0
      • JadonMundefined
        JadonM @Phaedrux
        @Phaedrux said in External SD Card not Reading (Maestro with 12864 Display):
        Unfortunately, there's none whatsoever. It did come with an adapter for using it with a ramps board though, and that seems to be the same as the official adapter as far as I can tell.
          There isn't any configuration to do for the external SD card, it should just work assuming that you have plugged both ribbon cables into the correct 2 ports of the Maestro. If both the LCD and the rotary encoder are working then you've got that right.
          Before you send the LCD unit back, let me test that the external SD card support still works in RRF 3.02-RC2 for the Maestro, because it's been a while since I tested it.
            dc42 administrators @dc42
            @dc42 said in External SD Card not Reading (Maestro with 12864 Display):
            I can't get the external SD card working on my 12864 LCD either, so it's probably a firmware bug. If so, you reported this just in time for me to fix it in 3.01-RC3.
              Confirmed, it's a firmware bug in the RepRapFirmware 3 series for the Maestro. Now fixed in 3.01-RC3, which I hope to release later today.
              • JadonMundefined
                JadonM @dc42
                David, thanks very much for your time, investigation, and quick response! I really appreciate it, and I've never found a company with service that even compares to yours!
                Thanks for the quick fix! When you release the update, I'll test it and be sure to get back with you.
                Jadon
                • JadonMundefined
                  JadonM @JadonM
                  @JadonM said in External SD Card not Reading (Maestro with 12864 Display):
                  I can confirm that the external SD card works perfectly with the new firmware version. Thanks!
                    dc42 administrators @JadonM
                    You're very welcome!
                    Kiwi3Dundefined 1 Reply Last reply Reply Quote 0
                    • Kiwi3Dundefined
                      Kiwi3D @dc42
                      @dc42 Hi David,
                      Ive just got my Maestro Zaribo built...and facing t he same issue. I'm on 3.1.1
                      12864 rotary encode is working and can use the screen fully. SD card on the screen is working from DWC 3.1.1 but not from the 12864
                      Thoughts?
                      Many thanks
                      Ray
                        Phaedrux Moderator @Kiwi3D
                        @Kiwi3D said in External SD Card not Reading (Maestro with 12864 Display):
                        @dc42 Hi David,
                        Thoughts?
                        Many thanks
                        Ray
                        Probably best if you start your own thread.
