    How to setup the Bigtreetech smart filament sensor?
    Third-party add-ons
    15
    55
    12.2k
      A Former User
      if its pin-compatible you could try stretching and bending the legs to force it onto the bigger pad.
      (apply liberal amounts of "carefulling" first)
      or solder thin wires from the pad to the leads. if current situation means huge delays I'd be inclined to try it.
      edit: i've only had to use bigger chips on smaller pads, but having given it a second thought I'd flatten the legs to they come straight out the side of the chip to make up the missing length, angle them outwards to align with the pads, then just solder a wire between the pad on the board and lead of the chip that would otherwise be floating in air. once you got one down the rest should be simple-ish.
      • arhiundefined
        arhi
        uh, I hate when it happens...
        @omni will bring his one to me these days ('cause mine is not arriving for months now 😞 ) so I can do some real life testing here ... I finished the new "case" for my encoder last night
        it's not a fancy package like the btree sensor but it does not restrict filament flow as much as btree one does and it's 600 impulses per rotation so ~8 impulses per mm instead of 1 impulse every 7mm πŸ™‚ and these encoders are 5-6eur delivered so 3x cheaper than btree one πŸ™‚
        anyhow I'm waiting for the tests you do after you replace the chip.
        btw, one quick test you should be able to do during the weekend .. if you have hotair gun, heat it up a bit and just lift the pin1 and pin6 from the pcb so they don't touch any of the circuitry ... power the chip with 5V and measure output on the pin6 when you short the pin1 to ground and to 5V (should be easy to just solder a jumper wires so you can easily measure) just to be 100% sure that chip is dead ... or if you already desoldered it (I think you did), just solder the 4 wires (1,2,5,6) and try "in the air" ...
        and I agree with @bearer few wires and that small one can fit, I did it more than once and still hate doing it but it's a fairly quick job if you have a steady hand and ok-ish vision πŸ™‚
        • Infinitysnekundefined
          Infinitysnek
          I have desoldered the chip already yes. I could try soldering on wires, hated doing that last time for a different project but it’s better than waiting a few weeks for new chips.
          Does yours work with the duet? If this won’t play nice with the duet I could repurpose the housing for something like that
          • arhiundefined
            arhi @Infinitysnek
            @Infinitysnek said in How to setup the Bigtreetech smart filament sensor?:
            Useful hint, how I do it if I don't want to make a breakout board pcb - hot-glue πŸ˜„
            Put some hot-glue on a plate (wood, plastic, cardboard...) and put the chip on its back on that hot glue. This way the chip is held in place, the legs are up in the air much more accessible when the chip is "back up" compared to "back down". Use "magnet wire" (lacquered wire from a transformer or similar device). With some practice, you can even make whole circuits using that (dead bug) technique.
            Yes, I had it connected to duet for a while with old design I made, it was disabled but collecting data. Problem was that old design was not very good (not sure if new one is much better we'll see) so the filament got tangled few times and almost ruined the print so I redesigned it and will be adding it back on the duet. This encoders have Vcc, Vss, A and B outputs (AB is from encoder) and I'm using A to send signals to duet and it was working good. What I don't remember is what I used for Vcc :(, IIRC this thing has 7805 inside so can be powered from 6-12V. I have one DCDC hooked on my duet2 to produce 12V for various needs but no clue if that's how I was connecting it. I'll play with it on Sunday again so I'll make a separate post about how it works if anyone wants to use the same el-cheapo encoder from PRC (hoping someone will make a better housing for it πŸ˜„ πŸ˜„ πŸ˜„ .. here if you can see from the images the 608 bearing slides on some rails, is pressed by the spring between that slider and external slider and externan slider is locked in place by the hole on the rail and piece of filament in that hole πŸ˜„ .... on the encoder's shaft I press fitted the printed wheel with concave edge and a wide rubber band wrapped around it to give it "grip" ... I glued the ptfe guide's 'cause during design I had no clue what the position of the wheels will be and after I did it was faster to just glue it in place than to change design and add more material with holes for those tubes πŸ˜„
              Infinitysnek
              Soldering wires wasn’t really a succes so I’ll wait for the other chip to arrive
              • arhiundefined
                arhi @Infinitysnek
                @Infinitysnek your schematic was very close to the real thing πŸ˜„ ...
                here's my take
                dc42undefined 1 Reply Last reply Reply Quote 2
                • arhiundefined
                  arhi
                  https://youtu.be/hOYq8nTVFww
                  • arhiundefined
                    arhi
                    The only thing I'm unsure about is the foto sensor as I never seen PNP foto-transistor, nor I seen them in this dual packages before. Normally they are NPN and single package but the way it is connected I have to assume this is PNP.
                    Now, Vcc - GND, I tested 5V and 3.3V and both work perfect.
                    The out_X is already push-pull so you do not need any pull-up/push-down on the IO pin on duet. And no need for resistor dividers, only power the sensor from 3.3V and you should be golden.
                    Have not yet connected to my duet but scope shows impulses going ok.
                    I have to say I don't get the construction?!?!
                    1. the spring (at least in the one that @omni brought here today for me to test) is so damn strong the sensor deforms the filament and makes it very hard to pull. Not a big deal if you are running BMG but cmon, there's no need for this, the original spring must go away and to be replaced with a softer one
                    2. there is a fixed idler bearing with V grove ?!?!
                      normally you make this idler moveable so it presses on the drive gear, but they decided to make this bearing static and to move the whole block with electronics, connector... to press the filament ?!!? WEEEEEEIRD
                    3. then, instead of encoder wheel (with rubber outside ring, soft and sticky to grab the filament easily) having contact with the filament, they add another bearing between encoder wheel and the filament, another V groved metal bearing that have zero grip on the filament (probbly why the spring is so strong so filament don't slip on the smoth side of the bearing)
                    So, to "fix"
                    • replace the spring with something softer
                    • need to add grip on the bearing in the slide-block, I assume a small wide rubber band will do the trick (those used for money wide ones are great)
                    To connect:
                    Pin closes to the bowden coupling is Ground, than there are 2 output pins and the pin farthest from the bowden connector is Vcc. Connect Vcc to 3v3, Ground to Ground, one of the output pins to the E_stop and that's it
                    • arhiundefined
                      arhi
                      and, def. works
                      need to be now properly configured (this is configured for my encoder) but to get you started
                      M591 D0 P7 C"e0stop" L0.5 R90:110 E3 S0
                      now you need to setup your own L value and your own span .. for start it's disabled but will collect data, when you are happy with the way you calibrated it you enable it and enjoy πŸ™‚
                      @omni 's U1 was not dead, I'm not sure how was he connecting it when it was not working but he did not burn the U1 so I just retraced the whole schematic (I desoldered the photo transistor pack to test it separately and make sure it's not ghosting my schematic, and then put it back after I was done, tested transistors separately with IR transmitter from a remote controller πŸ˜„ )
                      All in all, it works directly from 3v3 so all pins you need are on the E0STOP and E1STOP connectors on duet2ethernet (I assume the other duet's have similar/same connector)
                      Infinitysnekundefined 1 Reply Last reply Reply Quote 1
                        Infinitysnek
                        Thank you for your extensive testing!
                        Looking at your schematic do you think I could have blown up U1 when it was wired up wrong? I still have the desoldered chip and assuming I did not damage it during desoldering I could place it back.
                        Does it anywhere say what your board version is? I notice the housing for the one you have is 3D printed while mine is injection molded. Maybe they changed the spring too, mine is certainly stiff but does not deform the filament, there is some noticeable resistance to get it going but it rolls smooth after that. I do wonder if the stiff spring will be a problem with flexible filaments.
                        • arhiundefined
                          arhi @Infinitysnek
                          I ordered this filament monitor myself (stuck in the post somewhere for months 😞 ) and I'm helping out @omni to migrate to duet and upgrade his printer and he's using this monitor too so it's for selfish reasons πŸ˜„
                          Looling at the documents from btr they put there GSV and not GSSV so if you really pay attention you see on the images that there is a wire missing between S and V on their image but it's visible only if you really know what to look for, normally it looks like GSVx and in that way you power the output of the circuit. There's 200R on the output but it could maybe kill that PRC clone of the dual schmitt trigger.
                          omni also connected the device wrong but it is working ok, the U1 did not die. What did you power it with? 5V? 12V?
                          I doubt you can kill it by desoldering those can survive a lot of heat, but you measured something other than Vss/Vcc on the 2-3 pins and output of schmitt trigger cannot float, it's either 0 or 1 hence me assume that U1 is dead.
                          Yes, @omni's sensor is 3d printed case. PCB is v1.2
                          sorry images are total %$#%^@ I was not looking if they are in focus I assumed stupid iphone will focus properly 😞
                          I pressed this one few times fully and now it does not deform filament any more but it still offer way more resistance than I'd like
                          this one will be but it's super easy to replace so I'm sure omni will do it... it's more that whole design is imo wrong, the connector slides instead of bearing, the additional bearing between wheel with holes and idler, no rubber on the drive wheel.. dunno, makes no sense to me really, I expected much more refined design
                          Infinitysnekundefined 1 Reply Last reply Reply Quote 0
                            Infinitysnek @arhi
                            @arhi said in How to setup the Bigtreetech smart filament sensor?:
                            Only 3V3 and 5V never any higher.
                            Since I have to wait anyway for a replacement chip could I measure on the pins for resistance to check? Otherwise I'll just going to solder it back and hope it magically fixed itself.
                            • arhiundefined
                              arhi @Infinitysnek
                              omni did the same and did not kill it
                              Nope, you need to power it on to test it.
                              it is easiest way to test it, you can easily remove it if it does not work.
                              When you power it (3.3V enough) irrelevant to what input is, output (pins 4 and 6) must be either ground or vcc, can't be nothing in between, if you measure something in between it is dead. BUT make sure you keep the sensor in dark when you are measuring as if the sensor is picking up some noise it could be turning the input on/off quickly that will then translate to output going quickly between Vcc and Vss and since you are measuring with DMM and not a scope you will get some RMS value that will be between Vcc and Vss. So put some metal cap over the transistor when measuring outputs
                                dc42 administrators @arhi
                                here's my take
                                The two phototransistors will be NPN, but otherwise that looks highly plausible. In which case, it has quadrature outputs, so by using two inputs on the Duet and appropriate firmware it would be possible to sense direction of filament travel as well as amount.
                                arhiundefined supertb1undefined 2 Replies Last reply Reply Quote 1
                                • arhiundefined
                                  arhi @dc42
                                  @dc42 said in How to setup the Bigtreetech smart filament sensor?:
                                  I never seen PNP photo transistor, but with NPN one would normally do E to Vss, out from C and pull up resistor from C to Vcc, but here the C is on Vcc and output is on the bottom which is why I assumed PNP and not NPN .. in any case works the same as base does not exist
                                  I assumed that transistors are one next to another so that light opens one first than another, but tbh didn't manage to get that on the scope, they both open/close at the same time
                                  is that needed at all? firmware knows the direction it is turning the motor at ?
                                  I'm using on my printer (not yet enabled still using in disabled state) a 600 steps optical encoder but only the A output.
                                    A Former User @arhi
                                    would be okay in one direction, did you try both?
                                    • arhiundefined
                                      arhi @A Former User
                                      @bearer said in How to setup the Bigtreetech smart filament sensor?:
                                      I did not waste too much time on it as RRF uses only one impulse train anyhow so as soon as I got it working I wrapped it up and moved to a next task πŸ™‚ and whatever's in that IR receiver is not very useful as I can't purchase another one like that so investigation was not going anywhere πŸ™‚
                                      But in both direction one need to come first they should never turn on in the same time
                                        A Former User @arhi
                                        not a problem as long as its different in the other direction. (ofc. if they turn on and off at the same time in one direction it'll make it tricky to distinguish the other direction)
                                          Infinitysnek @arhi
                                          and, def. works
                                          So after a month I have a working sensor. Measured the signal pin and it now gives a 3.3v pulse like it should and wired it all up like you mentioned earlier.
                                          Yet I keep getting no data received. I've switched to the other extruder port to check and changed all the settings multiple times yet nothing seems to be doing anything....
                                          • arhiundefined
                                            arhi @Infinitysnek
                                            @Infinitysnek try a simple test
                                            1. remove your "real filament" going trough the sensor and feed it to your extruder directly
                                            2. push a 20cm piece of filament into the sensor
                                            3. connect the sensor to duet and configure (disabled state)
                                            4. start any print from sd
                                            5. when the printer start printing check the status of the sensor (should be no data)
                                              M591 D0
                                            6. now move, using your hand, those 20 cm of filament all the way trough the sensor one way, then return it all the way to the other end, repeat this few times
                                            7. check the status again
                                              M591 D0
                                              you should now see some data
