    How to setup the Bigtreetech smart filament sensor?
    Third-party add-ons
    15
    55
    11.8k
    • Infinitysnekundefined
      Infinitysnek
      Thank you for your extensive testing!
      Looking at your schematic do you think I could have blown up U1 when it was wired up wrong? I still have the desoldered chip and assuming I did not damage it during desoldering I could place it back.
      Does it anywhere say what your board version is? I notice the housing for the one you have is 3D printed while mine is injection molded. Maybe they changed the spring too, mine is certainly stiff but does not deform the filament, there is some noticeable resistance to get it going but it rolls smooth after that. I do wonder if the stiff spring will be a problem with flexible filaments.
      • arhiundefined
        arhi @Infinitysnek
        @Infinitysnek said in How to setup the Bigtreetech smart filament sensor?:
        I ordered this filament monitor myself (stuck in the post somewhere for months šŸ˜ž ) and I'm helping out @omni to migrate to duet and upgrade his printer and he's using this monitor too so it's for selfish reasons šŸ˜„
        Looling at the documents from btr they put there GSV and not GSSV so if you really pay attention you see on the images that there is a wire missing between S and V on their image but it's visible only if you really know what to look for, normally it looks like GSVx and in that way you power the output of the circuit. There's 200R on the output but it could maybe kill that PRC clone of the dual schmitt trigger.
        omni also connected the device wrong but it is working ok, the U1 did not die. What did you power it with? 5V? 12V?
        I doubt you can kill it by desoldering those can survive a lot of heat, but you measured something other than Vss/Vcc on the 2-3 pins and output of schmitt trigger cannot float, it's either 0 or 1 hence me assume that U1 is dead.
        Yes, @omni's sensor is 3d printed case. PCB is v1.2
        sorry images are total %$#%^@ I was not looking if they are in focus I assumed stupid iphone will focus properly šŸ˜ž
        I pressed this one few times fully and now it does not deform filament any more but it still offer way more resistance than I'd like
        this one will be but it's super easy to replace so I'm sure omni will do it... it's more that whole design is imo wrong, the connector slides instead of bearing, the additional bearing between wheel with holes and idler, no rubber on the drive wheel.. dunno, makes no sense to me really, I expected much more refined design
        Infinitysnekundefined 1 Reply Last reply Reply Quote 0
          Infinitysnek @arhi
          @arhi said in How to setup the Bigtreetech smart filament sensor?:
          Only 3V3 and 5V never any higher.
          Since I have to wait anyway for a replacement chip could I measure on the pins for resistance to check? Otherwise I'll just going to solder it back and hope it magically fixed itself.
          • arhiundefined
            arhi @Infinitysnek
            omni did the same and did not kill it
            Nope, you need to power it on to test it.
            it is easiest way to test it, you can easily remove it if it does not work.
            When you power it (3.3V enough) irrelevant to what input is, output (pins 4 and 6) must be either ground or vcc, can't be nothing in between, if you measure something in between it is dead. BUT make sure you keep the sensor in dark when you are measuring as if the sensor is picking up some noise it could be turning the input on/off quickly that will then translate to output going quickly between Vcc and Vss and since you are measuring with DMM and not a scope you will get some RMS value that will be between Vcc and Vss. So put some metal cap over the transistor when measuring outputs
              dc42 administrators @arhi
              @Infinitysnek your schematic was very close to the real thing šŸ˜„ ...
              here's my take
              The two phototransistors will be NPN, but otherwise that looks highly plausible. In which case, it has quadrature outputs, so by using two inputs on the Duet and appropriate firmware it would be possible to sense direction of filament travel as well as amount.
              arhiundefined supertb1undefined 2 Replies Last reply Reply Quote 1
              • arhiundefined
                arhi @dc42
                @dc42 said in How to setup the Bigtreetech smart filament sensor?:
                I never seen PNP photo transistor, but with NPN one would normally do E to Vss, out from C and pull up resistor from C to Vcc, but here the C is on Vcc and output is on the bottom which is why I assumed PNP and not NPN .. in any case works the same as base does not exist
                I assumed that transistors are one next to another so that light opens one first than another, but tbh didn't manage to get that on the scope, they both open/close at the same time
                is that needed at all? firmware knows the direction it is turning the motor at ?
                I'm using on my printer (not yet enabled still using in disabled state) a 600 steps optical encoder but only the A output.
                  A Former User @arhi
                  would be okay in one direction, did you try both?
                  • arhiundefined
                    arhi @A Former User
                    @bearer said in How to setup the Bigtreetech smart filament sensor?:
                    I did not waste too much time on it as RRF uses only one impulse train anyhow so as soon as I got it working I wrapped it up and moved to a next task šŸ™‚ and whatever's in that IR receiver is not very useful as I can't purchase another one like that so investigation was not going anywhere šŸ™‚
                    But in both direction one need to come first they should never turn on in the same time
                      A Former User @arhi
                      not a problem as long as its different in the other direction. (ofc. if they turn on and off at the same time in one direction it'll make it tricky to distinguish the other direction)
                        Infinitysnek @arhi
                        and, def. works
                        need to be now properly configured (this is configured for my encoder) but to get you started
                        M591 D0 P7 C"e0stop" L0.5 R90:110 E3 S0
                        now you need to setup your own L value and your own span .. for start it's disabled but will collect data, when you are happy with the way you calibrated it you enable it and enjoy šŸ™‚
                        @omni 's U1 was not dead, I'm not sure how was he connecting it when it was not working but he did not burn the U1 so I just retraced the whole schematic (I desoldered the photo transistor pack to test it separately and make sure it's not ghosting my schematic, and then put it back after I was done, tested transistors separately with IR transmitter from a remote controller šŸ˜„ )
                        All in all, it works directly from 3v3 so all pins you need are on the E0STOP and E1STOP connectors on duet2ethernet (I assume the other duet's have similar/same connector)
                        So after a month I have a working sensor. Measured the signal pin and it now gives a 3.3v pulse like it should and wired it all up like you mentioned earlier.
                        Yet I keep getting no data received. I've switched to the other extruder port to check and changed all the settings multiple times yet nothing seems to be doing anything....
                        • arhiundefined
                          arhi @Infinitysnek
                          @Infinitysnek try a simple test
                          1. remove your "real filament" going trough the sensor and feed it to your extruder directly
                          2. push a 20cm piece of filament into the sensor
                          3. connect the sensor to duet and configure (disabled state)
                          4. start any print from sd
                          5. when the printer start printing check the status of the sensor (should be no data)
                            M591 D0
                          6. now move, using your hand, those 20 cm of filament all the way trough the sensor one way, then return it all the way to the other end, repeat this few times
                          7. check the status again
                            M591 D0
                            you should now see some data
                            Infinitysnek @arhi
                            @arhi Well at least something changed. I tried that as well as doing a full print. Now it says no calibration data so I assume my config isnt right yet?
                            • omniundefined
                              omni
                              Just a short update from my side about the Bigtree filament sensor.... It works as intended now! šŸ™‚
                              My settings are M591 D0 P7 C"e0stop" L7 R75:125 E22 S1
                              The readings are usually from 93 to 108%, but I keep it on the safe side with the 75/125 % min/max settings.
                              It already saved one print.... šŸ™‚
                              Hope it helps.
                              • fadighrayebundefined
                                fadighrayeb
                                its SN74LVC1G14 Single Schmitt-Trigger Inverter
                                you can refere to Page 11 ( https://www.ti.com/lit/ds/symlink/sn74lvc1g14.pdf?ts=1601472384457&ref_url=https%253A%252F%252Fwww.google.com%252F)
                                i hope this useful
                                • phiednateundefined
                                  phiednate
                                  I don't know if this will help anyone but I have been been running the BTT filament sensor for a few months ago with the below settings. Besides for a few false faults while printing with some clearish filament it's been working great!
                                  M591 D0 P7 C"e0_stop" S1 R80:120 L6.2 E18.6
                                  M591 D0
                                  Pulse-type filament monitor on pin e0stop, enabled, sensitivity 6.200mm/pulse, allowed movement 80% to 120%, check every 18.6mm, measured sensitivity 6.252mm/pulse, measured minimum 96%, maximum 102% over 33984.9mm
                                  Popstarundefined martin7404undefined 2 Replies Last reply Reply Quote 0
                                  • Popstarundefined
                                    Popstar @phiednate
                                    @phiednate how do you connect to duet/duex board? Is the extra circuitry discussed above necessary to get it working?
                                    omniundefined 1 Reply Last reply Reply Quote 0
                                    • omniundefined
                                      omni @Popstar
                                      @Popstar
                                      No additional electronics is needed. It works as is - without any problems - just make sure you get the pinout right and put this line to configure the sensor :
                                      M591 D0 P7 C"^e0stop" L7 R50:250 E22 S1 ;pulse, disabled, 7 mm/pulse, measure every 22 sec, minimum 50 maximum 250
                                      Also it would be wise to disassemble the sensor and "squeeze" the spring a little bit, to make the filament go through more easily, since by default the spring is too strong and puts a lot of resistance to the filament flow....
                                      • scottjundefined
                                        scottj
                                        I just bought this sensor and wanted to add that the new case is injection molded, not 3d printed like the older version.
                                        It still uses the "Roller Encoder v1.2" PCB.
                                        I noticed the idler wheel with "V" groove was not lined up, so I loosened the 3mm screw to give it some movement, so it can match up with filament against the roller encoder wheel. Here is a picture looking through the filament channel, you can see the "V" is now center, where before it was toward to bottom (misaligned).
                                        I'm very interested in looking at the quadrature output, if it exists (maybe in another thread). Also, this platform might provide a way to replace the quadrature wheel with solid plastic part + 1x2mm magnet(s) with analog hall effect sensor + ATTiny45 to make higher precision (definitely other thread).
                                        Thanks for the prior research thus far, this was very helpful to me, and I wanted to contibute some current pictures and my tip about aligning the idler.
                                        -Scott
                                        • supertb1undefined
                                          supertb1 @dc42
                                          I have the Duet 3 6hc in my open build machine, I followed your wiring scheme and used io5.
                                          Here is my config.
                                          firmware version 3)
                                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 08 2021 08:53:31 GMT-0600 (Central Standard Time)
                                          M550 P"Colossus Openbuild" ; set printer name
                                          M586 P0 S1 ; enable HTTP
                                          M586 P1 S0 ; disable FTP
                                          M586 P2 S0 ; disable Telnet
                                          M569 P0.4 S1 ; physical drive 0.4 goes forwards
                                          M584 X0.3 Y0.2 Z0.0:0.1 E0.4 ; set drive mapping
                                          M671 X-122.25:689.20 Y0:0 S3.0 ; leadscrews at left (connected to Z0) and right (connected to Z1) of X axis
                                          M350 X32 Y32 Z32 E16 I1 ; configure microstepping with interpolation
                                          M92 X106.5 Y257 Z795.00 E339.00 ; set steps per mm
                                          M906 X900 Y3000 Z3000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30 ; Set idle timeout
                                          M208 X609 Y609 Z762 S0 ; set axis maxima
                                          M574 X1 S1 P"!^io1.in" ; configure active-high endstop for low end on X via pin !^io1.in
                                          M574 Y1 S1 P"!^io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
                                          M591 D0 P7 C"io5.in" L7 R55:150 E22 S1 ;Bigtree smart filament moniter v2 set to moniter between 55%-150% of 7 counts over a distance of 22mm
                                          M591 D0 ; display filament sensor parameters for extruder drive 4
                                          M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                                          M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                          G31 P100 X60 Y0 Z1.272 ; set Z probe trigger value, offset and trigger height
                                          M557 X100:500 Y100:500 S100 ; define mesh grid
                                          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                                          M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                                          M307 H0 B1 S10.00 ; enable bang-bang mode for the bed heater and set PWM limit
                                          M143 H0 S110 ; set temperature limit for heater 0 to 120C
                                          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                                          M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
                                          M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                                          M106 P0 C"Tool Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                                          M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
                                          M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency
                                          M106 P1 C"Extruder" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                                          M563 P0 S"Hemera" D0 H1 F0 ; define tool 0
                                          all I needed to do was wire 3.3vdc to pin 1, io5.in to pin 3 and ground to pin 4 and it works great
                                          Poloundefined 1 Reply Last reply Reply Quote 0
                                          • martin7404undefined
                                            martin7404 @phiednate
                                            @phiednate Hi I just got BTT filament sensor. I did read a few treads, but there is no clear post about wiring, could you be so kind to share your wiring diagram
                                            Muldex IDEX Duet2+Duex5
                                            Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                                            Sapphire Pro with Duet2, with closed-loop motors
                                            custom high temp E3D tool changer with Duet2+Duex
                                            supertb1undefined 1 Reply Last reply Reply Quote 0
