    duet 2 wifi , erased no port after erase .
    Firmware installation
    1.4k
    • morf33undefined
      morf33
        A Former User
        👍 looks good, all the usual suspects look fine, then again the LEDs did suggest the same.
        Grasping at straws before giving up, try the reset button and make sure it gives a good tactile feedback on both pressing and depressing it? Or even better use a multimeter to measure across the switch to check its not stuck. (with power off ofc)
        edit: think you can safely remove the jumper once the red DIAG light comes on when erasing the firmware btw.
        • morf33undefined
          morf33
          the red light stays on now but ill check the reset
          the 4 contact pads on the sides of the reset have continuity . front two and back two . is that correct or should i measure in the two holes in the back ?
            A Former User @morf33
            @morf33 said in duet 2 wifi , erased no port after erase .:
            maybe should have mentioned that, but, yes, looking at the front of the switch there will be continuity left to right, but not front to back. (if you press the switch you'll have continuity front to back as well)
            so in short, the switch isn't shorted out causing a problem.
            • morf33undefined
              morf33
              yes that works properly when pressing front to back had continuity when pressed and when not press it does not .switch functioning properly
              • morf33undefined
                morf33
                any next steps to try ?
                  A Former User
                  its either any link in the USB chain or the CPU itself at this point i think.
                  So you could measure the D-/D+ pins on the computer side of the USB cable go to pin 136/137 on the ATSAM4E with a 27 ohm series resistance, but that'd be fiddly and statistically unlikely to be the issue given its new and worked recently?
                  • aidarundefined
                    aidar
                    Your erase jumper is still fitted. As far as i understand, after erasing firmware you have to remove that jumper and reboot board, then it will show up as bossa port.
                      A Former User @aidar
                      @aidar said in duet 2 wifi , erased no port after erase .:
                      not a problem as long as its removed before you write the firmware to the board. leaving it on will just mean the board doesn't leave bootloader mode and will show up as bossa after writing the firmware and resetting the board.
                      aidarundefined 1 Reply Last reply Reply Quote 0
                      • aidarundefined
                        aidar @A Former User
                        @bearer Ok, thanks for information. I actually never had to do this, so was just guessing.
                          Can you post another close up photo of the reset switch? Is it just me or does it seem askew?
                          • morf33undefined
                            morf33
                              A Former User @Phaedrux
                              @Phaedrux said in duet 2 wifi , erased no port after erase .:
                              its not perfect, but it is functional from his testing.
                                In device manager do you see any unknown devices?
                                When you plug it in do you get the new device chime?
                                Where you able to try with a USB hub?
                                Where you able to try a different PC?
                                • morf33undefined
                                  morf33
                                  5 differnt windows pc all confirmed ports working and used same cable to program other devices . no issues but this on cant get a port , going try a linux and mac next
                                  device manager no chime or anything in device manager will try powered hub next
                                  • morf33undefined
                                    morf33
                                    tried powered USB hub to see if that would work still no port . tried Ubuntu and tried mac nothing works yet .
                                      Thanks for trying. How old is the board and where was it purchased?
                                      morf33undefined 1 Reply Last reply Reply Quote 0
                                      • morf33undefined
                                        morf33 @Phaedrux
                                        @Phaedrux
                                        less than 4 month old . filastruder is were i bought it from
                                          Phaedrux Moderator @morf33
                                          @morf33 Please ask them to exchange under warranty. You can direct them to this thread as authorization.
