duet 2 wifi , erased no port after erase .
any next steps to try ?
its either any link in the USB chain or the CPU itself at this point i think.
So you could measure the D-/D+ pins on the computer side of the USB cable go to pin 136/137 on the ATSAM4E with a 27 ohm series resistance, but that'd be fiddly and statistically unlikely to be the issue given its new and worked recently?
Your erase jumper is still fitted. As far as i understand, after erasing firmware you have to remove that jumper and reboot board, then it will show up as bossa port.
@aidar said in duet 2 wifi , erased no port after erase .:
not a problem as long as its removed before you write the firmware to the board. leaving it on will just mean the board doesn't leave bootloader mode and will show up as bossa after writing the firmware and resetting the board.
@bearer Ok, thanks for information. I actually never had to do this, so was just guessing.
Can you post another close up photo of the reset switch? Is it just me or does it seem askew?
@Phaedrux said in duet 2 wifi , erased no port after erase .:
its not perfect, but it is functional from his testing.
In device manager do you see any unknown devices?
When you plug it in do you get the new device chime?
Where you able to try with a USB hub?
Where you able to try a different PC? -
5 differnt windows pc all confirmed ports working and used same cable to program other devices . no issues but this on cant get a port , going try a linux and mac next
device manager no chime or anything in device manager will try powered hub next -
tried powered USB hub to see if that would work still no port . tried Ubuntu and tried mac nothing works yet .
Thanks for trying. How old is the board and where was it purchased?
less than 4 month old . filastruder is were i bought it from
@morf33 Please ask them to exchange under warranty. You can direct them to this thread as authorization.
