    bltouch
    1.9k
    • JoergS5undefined
      JoergS5 @nemecek
      @nemecek said in bltouch:
      @JoergS5
      ok and for this reason that did not work in P9? I'll try tomorrow thanks
      I dont know whether it is the solution, but P5 is an unspecific probe and P9 for bltouch specifically, and for P9 I often see P25, somtimes even P5, but never a high value.
      • nemecekundefined
        nemecek
        ok thanks for the assistance I will try today as joerg55 told me to set P25 instead of P500. if even this attempt doesn't work, I stay at P5. the bltouch does not lose quality right? and equal P5 or P9
        • JoergS5undefined
          JoergS5 @nemecek
          @nemecek P9 has deploy/retract probing for the BLtouch and if there are firmware improvements, I am sure P9 will include improvements for BLtouch, but P5 not, because P5 is used for other probe types also. But if only P5 works, you have to decide and maybe go on with P5 until you know the reason why P9 doesn't work.
          nemecekundefined 1 Reply Last reply Reply Quote 0
          • nemecekundefined
            nemecek @JoergS5
            @JoergS5 said in bltouch:
            yes the best solution
            • nemecekundefined
              nemecek
              hi i also tried p25 without success. sorry but here it must be inserted on channel 2 and correct?blt.png
                Phaedrux Moderator @nemecek
                @nemecek Yes that combination should work and result in
                M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                M280 P3 S10 I1 ; deploy BLTouch
                  You must also check your config-override.g for a M307 H3 command that would overwrite your M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch in config.g and comment it out.
                  • nemecekundefined
                    nemecek
                    I finally found the problem if I understood correctly H5 means that the pin comes out at 5 mm from the plate so the z goes down too much before letting out the pin if I put H50 then it's fine
                    but now i don't understand why i have 2 M558 this from errors one and to H30
                    the other is at H5
                    M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                    G31 P500 X-45.712 Y36.357 Z2.5 ; set Z probe trigger value, offset and trigger height
                    M557 R180 S20 ; define mesh grid
                      As it says, once delta calibration has been done and the homed height etc has been determined you don't need to use such a high dive height and it can be removed.
                      • nemecekundefined
                        nemecek
                        @Phaedrux said in bltouch:
                        config-override.g
                        ok perfect now everything works thanks to you. thanks for the assistance .you are geniuses
                        • nemecekundefined
                          nemecek
                          good morning i need you. When I run the G29 after the G32 with the exception of the M500, then I go to check I go down with the z and touch the
                          flat even when I move to check if it is well leveled in some parts the sheet passes well and in some parts also tight. So my question is this: does it compensate only during printing? Or was the calibration not performed correctly?
                          do you need photos? let me know, thanks
                            https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                            Mesh compensation is active after you've run G29 to create a new mesh, or after using G29 S1 to load a saved mesh.
                            You can also send M122 in the console and look for "Compensation: mesh" or something like that to verify it's enabled.
                            If you're noticing that the mesh isn't adapting the height accurately where it should, double check your X Y offsets in G31 are correct.
                            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
                            • nemecekundefined
                              nemecek
                              I can not I have a problem after the G32 I go down manually then I move with x but there is a difference in height so I do a G29 I try again manually but it does not compensate for anything because it does so?
                              ; config-override.g file generated in response to M500 at 2020-07-04 21:55
                              ; Delta parameters
                              M665 L520.889:520.889:520.889 R272.296 H365.630 B200.0 X-0.273 Y-0.895 Z0.000
                              M666 X2.672 Y-0.944 Z-1.727 A-0.99 B-1.14
                              ; Heater model parameters
                              M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                              M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                              G10 L2 P1 X0.00 Y0.00 Z0.00
                              G10 L2 P2 X0.00 Y0.00 Z0.00
                              G10 L2 P3 X0.00 Y0.00 Z0.00
                              G10 L2 P4 X0.00 Y0.00 Z0.00
                              G10 L2 P5 X0.00 Y0.00 Z0.00
                              G10 L2 P6 X0.00 Y0.00 Z0.00
                              G10 L2 P7 X0.00 Y0.00 Z0.00
                              G10 L2 P8 X0.00 Y0.00 Z0.00
                              G10 L2 P9 X0.00 Y0.00 Z0.00
                              • nemecekundefined
                                nemecek
                                RepRapFirmware height map file v2 generated at 2020-07-04 22:16, min error -0.350, max error -0.048, mean -0.185, deviation 0.068
                                xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                                -80.00,80.10,-80.00,80.10,100.00,20.00,20.00,9,9
                                0, 0, -0.101, -0.080, -0.100, -0.124, -0.125, 0, 0
                                0, -0.189, -0.162, -0.203, -0.217, -0.238, -0.322, -0.216, 0
                                -0.134, -0.091, -0.088, -0.090, -0.103, -0.086, -0.185, -0.208, -0.141
                                -0.138, -0.163, -0.162, -0.192, -0.251, -0.273, -0.350, -0.323, -0.264
                                -0.135, -0.048, -0.075, -0.100, -0.072, -0.116, -0.175, -0.190, -0.250
                                -0.163, -0.172, -0.213, -0.250, -0.212, -0.286, -0.276, -0.264, -0.304
                                -0.150, -0.128, -0.136, -0.176, -0.184, -0.205, -0.188, -0.223, -0.246
                                0, -0.165, -0.172, -0.176, -0.239, -0.252, -0.237, -0.289, 0
                                0, 0, -0.211, -0.189, -0.223, -0.198, -0.173, 0, 0
                                • nemecekundefined
                                  nemecek
                                  ; bed.g
                                  ; called to perform automatic delta calibration via G32
                                  ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jul 04 2020 14:57:29 GMT+0200 (heure d’été d’Europe centrale)
                                  G28 ; home all towers
                                  ; Probe the bed at 10 peripheral and 6 halfway points, and perform 9-factor auto compensation
                                  ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                                  G30 P0 X0 Y88.34 H0 Z-99999
                                  G30 P1 X62.31 Y85.77 H0 Z-99999
                                  G30 P2 X114.13 Y37.08 H0 Z-99999
                                  G30 P3 X114.13 Y-37.08 H0 Z-99999
                                  G30 P4 X70.53 Y-97.08 H0 Z-99999
                                  G30 P5 X0 Y-120 H0 Z-99999
                                  G30 P6 X-64.49 Y-88.76 H0 Z-99999
                                  G30 P7 X-85.63 Y-27.82 H0 Z-99999
                                  G30 P8 X-77.81 Y25.28 H0 Z-99999
                                  G30 P9 X-47.8 Y65.79 H0 Z-99999
                                  G30 P10 X0 Y33.72 H0 Z-99999
                                  G30 P11 X46.71 Y26.97 H0 Z-99999
                                  G30 P12 X51.96 Y-30 H0 Z-99999
                                  G30 P13 X0 Y-60 H0 Z-99999
                                  G30 P14 X-31.82 Y-18.37 H0 Z-99999
                                  G30 P15 X-26.38 Y15.23 H0 Z-99999
                                  G30 P16 X0 Y0 H0 Z-99999 S9
                                  ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                                  ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
