    Saftey Door Switches for BIG printers
    1.5k
    • nhofundefined
      nhof
      Hello Christian,
      The M582 command should do what you need. This code allows you to poll the switches to see if they're in a triggered state already, rather than only activating on an edge.
      CR3Dundefined 1 Reply Last reply Reply Quote 0
      • CR3Dundefined
        CR3D @nhof
        @nhof
        Yes, I know this command ... I have already used it in RR2, but unfortunately he didn't do that ... 😞
        • CR3Dundefined
          CR3D
          I plan to do it this way.
          I send the M582 command before homing and in the start script to see the current status.
          I would now like to query the whole thing with the META commands. Say ask if door 1, door 2 and door 3 are closed, do homing or print start, otherwise wait.
          I use the META command to check the homing state:
          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed
            G28
          @dc42 But is there a Object Model for the inputs at itself?
          • CR3Dundefined
            CR3D
            This post is deleted!
            • CR3Dundefined
              CR3D
              @dc42 can you help me at this point?
              In any case, I have to make sure that the printer cannot be operated with the doors open.
              Do you have an idea how?
                jay_s_uk
                Why not use daemon.g and conditional gcode?
                You could then monitor for when the printer is printing and check the state of some door switches.
                Then, if they are open rather than closed, or vice versa, the print is paused.
                CR3Dundefined 1 Reply Last reply Reply Quote 1
                • CR3Dundefined
                  CR3D @jay_s_uk
                  @jay_s_uk said in Saftey Door Switches for BIG printers:
                  Yes, I would like to do that ... so far I have queried the doors with M581, but this only evaluated the rising flank.
                  How could I solve that? do you have a concrete solution?
                    A Former User
                    M582 would should run the trigger again if the state is still triggered.
                    But I suspect the suggestion was to use the object model, don't have the specific node to use, but if noone comes up with it I'll have some time to poke it tomorrow
                      A Former User
                      or we could go down the "teach a man to fish" road?
                      M409 F"v" K"sensors"
                      and
                      https://forum.duet3d.com/topic/14878/conditional-gcode-expressions?_=1593546611563
                      where you find it under sensors will depend on how the sensor is defined, endstop or gpIn maybe?
                        dc42 administrators @CR3D
                        @CR3D said in Saftey Door Switches for BIG printers:
                        Yes, in RRF 3.1 they can be found in sensors.gpIn[x] where x is the GpIn number you assigned in M950 (the J parameter).
                        FS-TOOLSundefined 1 Reply Last reply Reply Quote 0
                        • CR3Dundefined
                          CR3D
                          Solved!
                          I created the switches like following in the config.g:
                          ; Custom Safety Settings
                          ; Open Door Switch
                          M950 J0 C"!1.io0.in"
                          M950 J1 C"!1.io1.in"
                          M950 J2 C"!1.io2.in"
                          ; Emergency Stop
                          M950 J3 C"!1.io3.in"
                          And at the homeall.g I used the conditional commands:
                          ; homeall.g
                          ; called to home all axes
                          if sensors.gpIn[0].value==1 & sensors.gpIn[1].value==1 & sensors.gpIn[2].value==1 & sensors.gpIn[3].value==1  ;If the Doors are closed and the emergency stop is released -> Homing
                          	M106 P0 S0		; Part cooling Fan off
                          	G91                    ; relative positioning
                          	G1 H2 Z10 F6000         ; lift Z relative to current position
                          	G1 H1 X-650 Y550 U650 F5000 ; first pass XYU
                          	G1 H2 X5 Y-5 U-5 F6000     ; go back a few mm
                          	G1 H1 X-20 Y20 U20 F360  ; second pass XY
                          	G90                   ; absolute positioning
                          	G1 X270 Y170 U460 F20000    ; first bed probe point -> move X to the middle of the Bed, U outside and home Z
                          	G30
                          Now if the doors are open or the emergency stop is active the printer will not move πŸ˜‰
                          Thank you for your help!
                          Regards Christian (CR-3D)
                            A Former User
                            are you still having a trigger to react to the doors being opend mid-print, or is that wired together with the e-stop?
                            • CR3Dundefined
                              CR3D @A Former User
                              @bearer
                              In RRF2.05 I made this with M581 to call Trigger 0:
                              I planned like this:
                              ; Open Door Switch
                              M581 P"!1.io0.in" T0 C0
                              M581 P"!1.io1.in" T0 C0
                              M581 P"!1.io2.in" T0 C0
                              ; Emergency Stop
                              M581 P"!1.io3.in" T0 C0
                                A Former User
                                gotcha, was wondering if you went with the slow down option and if so how you approached it - and if the time delay between the trigger and the speed reduction was acceptable with feed rate override f.ex.
                                • CR3Dundefined
                                  CR3D @A Former User
                                  @bearer
                                  before I have not found a way to listen to the protected ...
                                  how do I then implement it?
                                  Right now I'm opposing to stop everything. The reduction of the protected would be the best solution!
                                    A Former User
                                    I'm not sure how you'd go about it but I supect you'd set a M581 trigger for one flank to say trigger1.g that include
                                    ;trigger1.g - called when doors open
                                    M220 S20
                                    ;cancel T1
                                    M581 P"nil" T1 C0
                                    ;and arm T2
                                    M581 P"1.io0.in" T2 C0
                                    M581 P"1.io1.in" T2 C0
                                    M581 P"1.io2.in" T2 C0
                                    and in trigger2.g you set it back to 100 and change the trigger back to the original
                                    ;trigger2.g - called when doors close
                                    M220 S100
                                    ;cancel T2
                                    M581 P"nil" T2 C0
                                    ;and arm T1
                                    M581 P"!1.io0.in" T1 C0
                                    M581 P"!1.io1.in" T1 C0
                                    M581 P"!1.io2.in" T1 C0
                                    or something to that effect that causes the trigger to change function so it can respond differently to opening and closing.
                                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M220_Set_speed_factor_override_percentage
                                    I suppose you could refactor it to use only trigger1.g and use conditional logic to check if the sensors.GpIn[n] is high or low as well.
                                    • CR3Dundefined
                                      CR3D @A Former User
                                      @bearer
                                      Ok this sounds good! πŸ™‚ Thank you
                                      But this will work for a running Print or always?
                                      For example if the printer is homed, someone opens the door and moves the axes manually. Will this also be slowed down?
                                        A Former User
                                        hmm, docs doesn't specify so I'd presume its valid for all moves, but it'll probably be some amount of time between the switch triggering and command getting applied to the moves in the queue.
                                        if you test it and find M220 to not do the trick, you could also look into changing the actual speed limit with M203.
                                        • CR3Dundefined
                                          CR3D
                                          Hi all...
                                          I tested the example from @bearer and it works for the first step...
                                          There are still a few small things:
                                          1). I get an error message when I call trigger2.g and trigger3.g! Shown here in the picture
                                          Here the code:
                                          ; trigger2.g
                                          ;called wenn door was closed and gets opend
                                          M220 S20
                                          ;cancel T2
                                          M581 P"nil" T2
                                          ;and arm T3
                                          M581 P1 S0 T3 R0
                                          M581 P2 S0 T3 R0
                                          M581 P3 S0 T3 R0
                                          ;trigger3.g - called when doors close
                                          M220 S100
                                          ;cancel T3
                                          M581 P"nil" T3
                                          ;and arm T1
                                          M581 P1 S1 T2 R0
                                          M581 P2 S1 T2 R0
                                          M581 P3 S1 T2 R0
                                          it seems to have something to do with the "nile". Why does this error appear?
                                          as I said but it currently works when I open the door the speed decreases and when I close the door it increases again
                                          2). can you improve the response time? That he does this immediately and not only when the buffer is empty? similar to the emergency stop?
                                          Thank you! πŸ™‚
                                            A Former User @CR3D
                                            not sure if M25 (pause) is faster with respect to response time? i.e. pause, change speed and resume, but it might be subject to the same latency and/or not affect the moves already planned.
