Corexy travel problems
Pure X and pure Y moves use both motors whereas diagonal moves at 45 degrees use only one motor. So it's likely a problem when using just a single motor. Does it exhibit the same behaviour in both diagonal directions? i.e. front left to rear right but also front right to rear left? This will tell you if just one motor is affected or both. What size motors are they, what is the current rating of the motors and what current have you set them to use in config.g?
hi
thank for the help
moving from front to back from left to right to jurks in both directions
moving front to back right to left to moves smoothly in both directions
I have nema 17 0.9 1.7a motors running at 1.3a in software
cheers -
So it's definitely to do with one motor, the one that does front to back, left to right. With the machine switched off, move the hot end diagonally in this direction and watch the belts. One motor will turn and the other will be static. the one that turns is the problem one. The first thing to check is that the pulley is held tight on the shaft and not slipping. If it is then it's most likely a wiring problem.
Edit. Looking closely at the video, the pulley on the motor in the shot is either very misshapen or it's loose on the shaft.
Its funny how a lose grub screw after tighting makes all the difference.
I cant thank you enought for your help,
cheers
https://youtu.be/mqxwj_fFxGs -
Glad you got it sorted. Out of interest, that looks like quite a large bed oblong bed but it might just be the camera angle. What size is it?
build area is X720 Y320 Z 800
With 3 hot ends, changible tools
diamond hot end
e3d volcano
direct drive with e3d hot end
so the hot ends get pick up as need in the print then droped offI call it "Small Box"
Wow that's impressive. May I ask how the hot end is fixed to the carriage after it gets picked up?
Wow nice Foehnsturm-style magnetic changer!
magnetics, holds real well
That is awesome! Will you be sharing the design of the magnetic changer?
Cheers
Tony
I guess I can after I get everything up and going
