    Wifi module idle
    2.2k
      A Former User
      You didn't show what happened when you entered the M587 command?
      But try
      M552 S-1
      M552 S0
      M587 S"your-network-SSID" P"your-network-password”
      m552 S1
      • tkdirpundefined
        tkdirp
        @bearer said in Wifi module idle:
        after putting this the results...
          A Former User
          Bad or missing parameter, hmm, are there any special characters in your SSID or Passphrase?
          tkdirpundefined 1 Reply Last reply Reply Quote 0
          • tkdirpundefined
            tkdirp
            I put in...
            • M587 S"U+Net48C4" P"8040P8C0#1”
            • tkdirpundefined
              tkdirp @A Former User
              @bearer
              If I proceed with...
              m552 S1
              this happens
                A Former User
                It'll keep saying no known networks found until M587 succeeds adding yours. Don't recall if + and # is on the list of characters that needs special treatment so hopefully someome else will chime in on that.
                • tkdirpundefined
                  tkdirp
                  @bearer
                  okay 🙂
                  • Dougal1957undefined
                    Dougal1957
                    The # is ok (I have that in my PW as well with no special treatment) not sure about the +
                    But it may be worth trying
                    M587 S"U'+'Net48C4" p"8040P8C0#1"
                    Do make sure that you are sending it in the correct case.
                    Doug
                      A Former User
                      screen shouldn't affect case, thats a workaround for pronterface or whats it called that converts all gcode to uppercase, incluing the strings for parameters like wifi credentials.
                        Dougal1957 @A Former User
                        It was more a warning rather than in instruction and not know the ops system I felt it worth pointing out!
                        • tkdirpundefined
                          tkdirp @Dougal1957
                          @Dougal1957
                          I guess M587 S"U'+'Net48C4" p"8040P8C0#1" seems to work because the terminal responded "ok" but when I put "m552 S1" this still happens...
                            A Former User
                            show us M587 with no parameters?
                            • tkdirpundefined
                              @bearer
                              What does it mean to have an M587 with no parameters? I just don't know because I am pretty new to this.
                                Dougal1957 @tkdirp
                                @tkdirp said in Wifi module idle:
                                @bearer
                                just send M587 on its own with nothing after it then the Duet will tell us what it has set!
                                  A Former User
                                  just send M587 (with no S"......" P".....")
                                  it should return the stored netwoks in the wifi module.
                                  • tkdirpundefined
                                    @bearer @Dougal1957
                                    SSID: U+Net48C4
                                    PW: 8040P8C0#1
                                      A Former User
                                      what firmware are you running?
                                      check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
                                      • tkdirpundefined
                                        @bearer
                                        seem to be 2.03
                                          A Former User @tkdirp
                                          2.03
                                          thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
                                          • tkdirpundefined
                                            @bearer
                                            This happens if I send a M122 command...
