    Wifi module idle
    2.2k
    • tkdirpundefined
      tkdirp @A Former User
      @bearer
      If I proceed with...
      m552 S1
      this happens
        A Former User
        It'll keep saying no known networks found until M587 succeeds adding yours. Don't recall if + and # is on the list of characters that needs special treatment so hopefully someome else will chime in on that.
        • tkdirpundefined
          tkdirp
          @bearer
          okay 🙂
          • Dougal1957undefined
            Dougal1957
            The # is ok (I have that in my PW as well with no special treatment) not sure about the +
            But it may be worth trying
            M587 S"U'+'Net48C4" p"8040P8C0#1"
            Do make sure that you are sending it in the correct case.
            Doug
            tkdirpundefined 1 Reply Last reply Reply Quote 0
              A Former User
              screen shouldn't affect case, thats a workaround for pronterface or whats it called that converts all gcode to uppercase, incluing the strings for parameters like wifi credentials.
                Dougal1957 @A Former User
                @bearer said in Wifi module idle:
                It was more a warning rather than in instruction and not know the ops system I felt it worth pointing out!
                • tkdirpundefined
                  tkdirp @Dougal1957
                  @Dougal1957
                  I guess M587 S"U'+'Net48C4" p"8040P8C0#1" seems to work because the terminal responded "ok" but when I put "m552 S1" this still happens...
                    A Former User
                    show us M587 with no parameters?
                    • tkdirpundefined
                      @bearer
                      What does it mean to have an M587 with no parameters? I just don't know because I am pretty new to this.
                        Dougal1957 @tkdirp
                        @tkdirp said in Wifi module idle:
                        @bearer
                        just send M587 on its own with nothing after it then the Duet will tell us what it has set!
                          A Former User
                          just send M587 (with no S"......" P".....")
                          it should return the stored netwoks in the wifi module.
                          • tkdirpundefined
                            @bearer @Dougal1957
                            SSID: U+Net48C4
                            PW: 8040P8C0#1
                              A Former User
                              what firmware are you running?
                              check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
                              • tkdirpundefined
                                @bearer
                                seem to be 2.03
                                  A Former User @tkdirp
                                  2.03
                                  thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
                                  • tkdirpundefined
                                    @bearer
                                    This happens if I send a M122 command...
                                      A Former User
                                      right, wifi not happy.
                                      btw could you try running stty -F /dev/tty.usbmodem14101 inlcr in another terminal and see if it sorts the line endings for you? (edit or stty -F /dev/tty.usbmodem14101 -icrnl)
                                      then lets try the nuke from orbit approach.
                                      M552 S-1
                                      M552 S0
                                      M588 S"*"
                                      M587 S"U'+Net48C4" p"8040P8C0#1"
                                      M552 S1
                                      M552 S-1 resets the wifi module
                                      M588 S"*" clears the wifi credentials
                                      edit fixed typo M589 to M588
                                      tkdirpundefined 2 Replies Last reply Reply Quote 0
                                      • tkdirpundefined
                                        in another terminal
                                        So, on another computer?
                                          another computer?
                                          no, same computer just another window with a terminal. (but its not that important, it just makes it easier to read if the end of line characters actually causes a new line - and I'm not sure if it would work on a Mac)
                                          • tkdirpundefined
                                            M589 S"*" clears the wifi credentials
                                            The nuke plan failed... 😞
