    Wifi module idle
    2.2k
      A Former User
      It'll keep saying no known networks found until M587 succeeds adding yours. Don't recall if + and # is on the list of characters that needs special treatment so hopefully someome else will chime in on that.
      • tkdirpundefined
        tkdirp
        @bearer
        okay 🙂
        • Dougal1957undefined
          Dougal1957
          The # is ok (I have that in my PW as well with no special treatment) not sure about the +
          But it may be worth trying
          M587 S"U'+'Net48C4" p"8040P8C0#1"
          Do make sure that you are sending it in the correct case.
          Doug
          tkdirpundefined 1 Reply Last reply Reply Quote 0
            A Former User
            screen shouldn't affect case, thats a workaround for pronterface or whats it called that converts all gcode to uppercase, incluing the strings for parameters like wifi credentials.
              Dougal1957 @A Former User
              @bearer said in Wifi module idle:
              It was more a warning rather than in instruction and not know the ops system I felt it worth pointing out!
              • tkdirpundefined
                tkdirp @Dougal1957
                @Dougal1957
                I guess M587 S"U'+'Net48C4" p"8040P8C0#1" seems to work because the terminal responded "ok" but when I put "m552 S1" this still happens...
                  A Former User
                  show us M587 with no parameters?
                  • tkdirpundefined
                    tkdirp @A Former User
                    @bearer
                    What does it mean to have an M587 with no parameters? I just don't know because I am pretty new to this.
                      Dougal1957 @tkdirp
                      @tkdirp said in Wifi module idle:
                      @bearer
                      just send M587 on its own with nothing after it then the Duet will tell us what it has set!
                        A Former User
                        just send M587 (with no S"......" P".....")
                        it should return the stored netwoks in the wifi module.
                        • tkdirpundefined
                          @bearer @Dougal1957
                          SSID: U+Net48C4
                          PW: 8040P8C0#1
                            A Former User
                            what firmware are you running?
                            check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
                            • tkdirpundefined
                              @bearer
                              seem to be 2.03
                                A Former User @tkdirp
                                2.03
                                thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
                                • tkdirpundefined
                                  @bearer
                                  This happens if I send a M122 command...
                                    A Former User
                                    right, wifi not happy.
                                    btw could you try running stty -F /dev/tty.usbmodem14101 inlcr in another terminal and see if it sorts the line endings for you? (edit or stty -F /dev/tty.usbmodem14101 -icrnl)
                                    then lets try the nuke from orbit approach.
                                    M552 S-1
                                    M552 S0
                                    M588 S"*"
                                    M587 S"U'+Net48C4" p"8040P8C0#1"
                                    M552 S1
                                    M552 S-1 resets the wifi module
                                    M588 S"*" clears the wifi credentials
                                    edit fixed typo M589 to M588
                                    tkdirpundefined 2 Replies Last reply Reply Quote 0
                                    • tkdirpundefined
                                      in another terminal
                                      So, on another computer?
                                        another computer?
                                        no, same computer just another window with a terminal. (but its not that important, it just makes it easier to read if the end of line characters actually causes a new line - and I'm not sure if it would work on a Mac)
                                        • tkdirpundefined
                                          M589 S"*" clears the wifi credentials
                                          The nuke plan failed... 😞
                                            A Former User
                                            but M122 shows the wifi version now?
                                            if not lets try
                                            M552 S-1
                                            M552 S0
                                            M588 S"*"
                                            M122
                                            edit: fixed typo M589 to M588
