    Wifi module idle
    2.1k
    • tkdirpundefined
      tkdirp
      @bearer
      okay 🙂
      • Dougal1957undefined
        Dougal1957
        The # is ok (I have that in my PW as well with no special treatment) not sure about the +
        But it may be worth trying
        M587 S"U'+'Net48C4" p"8040P8C0#1"
        Do make sure that you are sending it in the correct case.
        Doug
        tkdirpundefined 1 Reply Last reply Reply Quote 0
          A Former User
          screen shouldn't affect case, thats a workaround for pronterface or whats it called that converts all gcode to uppercase, incluing the strings for parameters like wifi credentials.
            Dougal1957 @A Former User
            @bearer said in Wifi module idle:
            It was more a warning rather than in instruction and not know the ops system I felt it worth pointing out!
            • tkdirpundefined
              tkdirp @Dougal1957
              @Dougal1957
              I guess M587 S"U'+'Net48C4" p"8040P8C0#1" seems to work because the terminal responded "ok" but when I put "m552 S1" this still happens...
                A Former User
                show us M587 with no parameters?
                • tkdirpundefined
                  tkdirp @A Former User
                  @bearer
                  What does it mean to have an M587 with no parameters? I just don't know because I am pretty new to this.
                    Dougal1957 @tkdirp
                    @tkdirp said in Wifi module idle:
                    @bearer
                    just send M587 on its own with nothing after it then the Duet will tell us what it has set!
                      A Former User
                      just send M587 (with no S"......" P".....")
                      it should return the stored netwoks in the wifi module.
                      • tkdirpundefined
                        @bearer @Dougal1957
                        SSID: U+Net48C4
                        PW: 8040P8C0#1
                          A Former User
                          what firmware are you running?
                          check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
                          • tkdirpundefined
                            @bearer
                            seem to be 2.03
                              A Former User @tkdirp
                              2.03
                              thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
                              • tkdirpundefined
                                @bearer
                                This happens if I send a M122 command...
                                  A Former User
                                  right, wifi not happy.
                                  btw could you try running stty -F /dev/tty.usbmodem14101 inlcr in another terminal and see if it sorts the line endings for you? (edit or stty -F /dev/tty.usbmodem14101 -icrnl)
                                  then lets try the nuke from orbit approach.
                                  M552 S-1
                                  M552 S0
                                  M588 S"*"
                                  M587 S"U'+Net48C4" p"8040P8C0#1"
                                  M552 S1
                                  M552 S-1 resets the wifi module
                                  M588 S"*" clears the wifi credentials
                                  edit fixed typo M589 to M588
                                  tkdirpundefined 2 Replies Last reply Reply Quote 0
                                  • tkdirpundefined
                                    in another terminal
                                    So, on another computer?
                                      another computer?
                                      no, same computer just another window with a terminal. (but its not that important, it just makes it easier to read if the end of line characters actually causes a new line - and I'm not sure if it would work on a Mac)
                                      • tkdirpundefined
                                        M589 S"*" clears the wifi credentials
                                        The nuke plan failed... 😞
                                          A Former User
                                          but M122 shows the wifi version now?
                                          if not lets try
                                          M552 S-1
                                          M552 S0
                                          M588 S"*"
                                          M122
                                          edit: fixed typo M589 to M588
                                          • tkdirpundefined
                                            @bearer
                                            M122 is still not working
