    Wifi module idle
    2.2k
      A Former User
      what firmware are you running?
      check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
      tkdirpundefined 1 Reply Last reply Reply Quote 0
      • tkdirpundefined
        tkdirp @A Former User
        @bearer
        seem to be 2.03
          A Former User @tkdirp
          @tkdirp said in Wifi module idle:
          2.03
          thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
          • tkdirpundefined
            @bearer
            This happens if I send a M122 command...
              A Former User
              right, wifi not happy.
              btw could you try running stty -F /dev/tty.usbmodem14101 inlcr in another terminal and see if it sorts the line endings for you? (edit or stty -F /dev/tty.usbmodem14101 -icrnl)
              then lets try the nuke from orbit approach.
              M552 S-1
              M552 S0
              M588 S"*"
              M587 S"U'+Net48C4" p"8040P8C0#1"
              M552 S1
              M552 S-1 resets the wifi module
              M588 S"*" clears the wifi credentials
              edit fixed typo M589 to M588
              tkdirpundefined 2 Replies Last reply Reply Quote 0
              • tkdirpundefined
                @bearer said in Wifi module idle:
                in another terminal
                So, on another computer?
                  another computer?
                  no, same computer just another window with a terminal. (but its not that important, it just makes it easier to read if the end of line characters actually causes a new line - and I'm not sure if it would work on a Mac)
                  • tkdirpundefined
                    M589 S"*" clears the wifi credentials
                    The nuke plan failed... šŸ˜ž
                      A Former User
                      but M122 shows the wifi version now?
                      if not lets try
                      M552 S-1
                      M552 S0
                      M588 S"*"
                      M122
                      edit: fixed typo M589 to M588
                      • tkdirpundefined
                        @bearer
                        M122 is still not working
                        • tkdirpundefined
                          M552 S-1
                          M552 S0
                          M589 S"*"
                          M122
                          Worked.
                            A Former User
                            ah, okay, was about to suggest just updating it without finding out which version it is, but thats all up to date then. (1.23 is the latest iirc)
                            if you run M111 P14 S1 it will enable debug output for wifi.
                            then run M587 S... P.... (with your credentials) followed by M552 S1
                            (but I suspect you really need to find another terminal for that to be usefull, or have screen translate LF into CR/LF)
                            ((edit: if you must use screen maybe log to a file and view the file (in another window) with fixed line endings tail -F my.log | sed 's/$/\r/' ))
                            • tkdirpundefined
                              M111 P14 S1
                              After that commend, the M587 S"U'+Net48C4" Pā€8040P8C0#1" dos not seem to have any significant effect
                                thats okay, was primarily after the ouput that say WiFi: ../src/Sock <...> found network U+Net48C4.
                                Either the + is a problem or there is some sort of interoperability issue with the router.
                                I would suggest checking the encyption type, or change it to WPA(2)/TKIP, changing the SSID and Passphrase to something without special charters.
                                Or optionally use M589 to set up the duet as an access point.
                                But first, repeat https://forum.duet3d.com/post/164593 as I had made a typo in the command to clear the wifi settings. (However as you did get an OK at some point i doubt it'll make a difference)
                                  A Former User
                                  forgot the link to M589 to try AP mode
                                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
                                  • tkdirpundefined
                                    @bearer
                                    Thank you so much
                                      A Former User
                                      which bit helped? correcting to M558 or are you using the Duet as an access point?
                                      • tkdirpundefined
                                        @bearer
                                        I just changed the name of the wifi I guess the "+" in the SSID name was the issue
                                        A Former User? Natuserundefined 2 Replies Last reply Reply Quote 1
                                          interesting feedback, perhaps something should be tested and added to the documentation.
                                            There is no hard rule for SSID special character support on the router side. Some will let you use pretty much anything, but in general it's probably best to avoid special characters in the SSID.
                                            I'll add a note to the M587 command regarding that.
