    Wifi module idle
    2.2k
    • Dougal1957undefined
      Dougal1957 @tkdirp
      @tkdirp said in Wifi module idle:
      @bearer
      What does it mean to have an M587 with no parameters? I just don't know because I am pretty new to this.
      just send M587 on its own with nothing after it then the Duet will tell us what it has set!
        A Former User
        just send M587 (with no S"......" P".....")
        it should return the stored netwoks in the wifi module.
        tkdirpundefined 1 Reply Last reply Reply Quote 0
        • tkdirpundefined
          tkdirp @A Former User
          @bearer @Dougal1957
          SSID: U+Net48C4
          PW: 8040P8C0#1
            A Former User
            what firmware are you running?
            check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
            • tkdirpundefined
              @bearer
              seem to be 2.03
                A Former User @tkdirp
                2.03
                thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
                • tkdirpundefined
                  @bearer
                  This happens if I send a M122 command...
                    A Former User
                    right, wifi not happy.
                    btw could you try running stty -F /dev/tty.usbmodem14101 inlcr in another terminal and see if it sorts the line endings for you? (edit or stty -F /dev/tty.usbmodem14101 -icrnl)
                    then lets try the nuke from orbit approach.
                    M552 S-1
                    M552 S0
                    M588 S"*"
                    M587 S"U'+Net48C4" p"8040P8C0#1"
                    M552 S1
                    M552 S-1 resets the wifi module
                    M588 S"*" clears the wifi credentials
                    edit fixed typo M589 to M588
                    tkdirpundefined 2 Replies Last reply Reply Quote 0
                    • tkdirpundefined
                      @bearer said in Wifi module idle:
                      in another terminal
                      So, on another computer?
                        another computer?
                        no, same computer just another window with a terminal. (but its not that important, it just makes it easier to read if the end of line characters actually causes a new line - and I'm not sure if it would work on a Mac)
                        • tkdirpundefined
                          M589 S"*" clears the wifi credentials
                          The nuke plan failed... šŸ˜ž
                            A Former User
                            but M122 shows the wifi version now?
                            if not lets try
                            M552 S-1
                            M552 S0
                            M588 S"*"
                            M122
                            edit: fixed typo M589 to M588
                            • tkdirpundefined
                              @bearer
                              M122 is still not working
                              • tkdirpundefined
                                M552 S-1
                                M552 S0
                                M589 S"*"
                                M122
                                Worked.
                                  A Former User
                                  ah, okay, was about to suggest just updating it without finding out which version it is, but thats all up to date then. (1.23 is the latest iirc)
                                  if you run M111 P14 S1 it will enable debug output for wifi.
                                  then run M587 S... P.... (with your credentials) followed by M552 S1
                                  (but I suspect you really need to find another terminal for that to be usefull, or have screen translate LF into CR/LF)
                                  ((edit: if you must use screen maybe log to a file and view the file (in another window) with fixed line endings tail -F my.log | sed 's/$/\r/' ))
                                  • tkdirpundefined
                                    M111 P14 S1
                                    After that commend, the M587 S"U'+Net48C4" Pā€8040P8C0#1" dos not seem to have any significant effect
                                      thats okay, was primarily after the ouput that say WiFi: ../src/Sock <...> found network U+Net48C4.
                                      Either the + is a problem or there is some sort of interoperability issue with the router.
                                      I would suggest checking the encyption type, or change it to WPA(2)/TKIP, changing the SSID and Passphrase to something without special charters.
                                      Or optionally use M589 to set up the duet as an access point.
                                      But first, repeat https://forum.duet3d.com/post/164593 as I had made a typo in the command to clear the wifi settings. (However as you did get an OK at some point i doubt it'll make a difference)
                                        A Former User
                                        forgot the link to M589 to try AP mode
                                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
                                        • tkdirpundefined
                                          @bearer
                                          Thank you so much
                                            A Former User
                                            which bit helped? correcting to M558 or are you using the Duet as an access point?
