    Wifi module idle
    2.2k
      A Former User
      show us M587 with no parameters?
      tkdirpundefined 1 Reply Last reply Reply Quote 0
      • tkdirpundefined
        tkdirp @A Former User
        @bearer
        What does it mean to have an M587 with no parameters? I just don't know because I am pretty new to this.
        • Dougal1957undefined
          Dougal1957 @tkdirp
          @tkdirp said in Wifi module idle:
          @bearer
          just send M587 on its own with nothing after it then the Duet will tell us what it has set!
            A Former User
            just send M587 (with no S"......" P".....")
            it should return the stored netwoks in the wifi module.
            • tkdirpundefined
              @bearer @Dougal1957
              SSID: U+Net48C4
              PW: 8040P8C0#1
                A Former User
                what firmware are you running?
                check with M122. The Duet board firmware will be at the top, and the Wifi firmware will be in a a section at the bottom.
                • tkdirpundefined
                  @bearer
                  seem to be 2.03
                    A Former User @tkdirp
                    2.03
                    thats just the RepRapFirmware version, as I said when you run M122 it will also print the version of the firmware running om the Wifi module.
                    • tkdirpundefined
                      @bearer
                      This happens if I send a M122 command...
                        A Former User
                        right, wifi not happy.
                        btw could you try running stty -F /dev/tty.usbmodem14101 inlcr in another terminal and see if it sorts the line endings for you? (edit or stty -F /dev/tty.usbmodem14101 -icrnl)
                        then lets try the nuke from orbit approach.
                        M552 S-1
                        M552 S0
                        M588 S"*"
                        M587 S"U'+Net48C4" p"8040P8C0#1"
                        M552 S1
                        M552 S-1 resets the wifi module
                        M588 S"*" clears the wifi credentials
                        edit fixed typo M589 to M588
                        tkdirpundefined 2 Replies Last reply Reply Quote 0
                        • tkdirpundefined
                          @bearer said in Wifi module idle:
                          in another terminal
                          So, on another computer?
                            another computer?
                            no, same computer just another window with a terminal. (but its not that important, it just makes it easier to read if the end of line characters actually causes a new line - and I'm not sure if it would work on a Mac)
                            • tkdirpundefined
                              M589 S"*" clears the wifi credentials
                              The nuke plan failed... šŸ˜ž
                                A Former User
                                but M122 shows the wifi version now?
                                if not lets try
                                M552 S-1
                                M552 S0
                                M588 S"*"
                                M122
                                edit: fixed typo M589 to M588
                                • tkdirpundefined
                                  @bearer
                                  M122 is still not working
                                  • tkdirpundefined
                                    M552 S-1
                                    M552 S0
                                    M589 S"*"
                                    M122
                                    Worked.
                                      A Former User
                                      ah, okay, was about to suggest just updating it without finding out which version it is, but thats all up to date then. (1.23 is the latest iirc)
                                      if you run M111 P14 S1 it will enable debug output for wifi.
                                      then run M587 S... P.... (with your credentials) followed by M552 S1
                                      (but I suspect you really need to find another terminal for that to be usefull, or have screen translate LF into CR/LF)
                                      ((edit: if you must use screen maybe log to a file and view the file (in another window) with fixed line endings tail -F my.log | sed 's/$/\r/' ))
                                      • tkdirpundefined
                                        M111 P14 S1
                                        After that commend, the M587 S"U'+Net48C4" Pā€8040P8C0#1" dos not seem to have any significant effect
                                          thats okay, was primarily after the ouput that say WiFi: ../src/Sock <...> found network U+Net48C4.
                                          Either the + is a problem or there is some sort of interoperability issue with the router.
                                          I would suggest checking the encyption type, or change it to WPA(2)/TKIP, changing the SSID and Passphrase to something without special charters.
                                          Or optionally use M589 to set up the duet as an access point.
                                          But first, repeat https://forum.duet3d.com/post/164593 as I had made a typo in the command to clear the wifi settings. (However as you did get an OK at some point i doubt it'll make a difference)
                                            A Former User
                                            forgot the link to M589 to try AP mode
                                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
