Bad color, After update
PanelDue
paneldue
682
    bastien
    Hi, i just install firmware 1.24 on my paneldue( fysetc 7i) and now the screen color is bad!1593965397521962011944206099111.jpg
      A Former User
      sounds like you might have used the wrong file?
      https://github.com/Duet3D/PanelDueFirmware/releases/download/1.24/PanelDue-5.0i-7.0i.bin is this the one you used?
      undefined 1 Reply Last reply 5 Jul 2020, 16:17 Reply Quote 0
        bastien @A Former User
        @bearer yes
        I try 1.22 and 1.17e, same problem
          A Former User
          @bastien said in Bad color, After update:
          fysetc 7i
          hmm, are you sure its a 7i design ?
          Looks a bit different to my 7i, maybe try PanelDue-v3-7.0.bin instead?
          undefined 1 Reply Last reply 5 Jul 2020, 16:24 Reply Quote 0
            @bearer yes thanks, it's normal panel
              skymasteres
              Has there been any resolution to this issue? I am having the identical problem
              ? 1 Reply Last reply 3 Feb 2021, 06:30 Reply Quote 0
                what firmware version does Fysetc supply it with?
                  A Former User @skymasteres
                  @skymasteres said in Bad color, After update:
                  as OP never posted anything else I took it to be solved by using the regular PanelDue v3 binary
                    jay_s_uk
                    There was another user with a fysetc 7i and they had to use the v3 firmware to get the right colours
                      TrevJonez
                      I just picked up a few of these fysetc panels (LCD800480 V1.1). The important thing to look at is that yes its more like a paneldue 7i in form factor, but the back of the pcb says it is based on the paneldue v3 not the 7i. So once I flashed the board with PanelDue-v3-7.0.bin files everything was as expected now.
