    Duet 2 Pro 4 U
    Hardware wishlist
    10
    38
    4.1k
      jay_s_uk
      Is that a ESP-WROOM-02U wifi module?
        A Former User @jay_s_uk
        @jay_s_uk said in Duet 2 Pro 4 U:
        ESP-WROOM-02U
        it was more legible on another photo, but yes.
        • pixelpieperundefined
          pixelpieper
          Neat! I really like where this is going... Do I spot a CAN-FD-Connector in the left top?
          Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
          Voron V0.250 / Duet 2 Maestro
            dc42 administrators @pixelpieper
            @pixelpieper said in Duet 2 Pro 4 U:
            No, that's the SWD connector.
            • botundefined
              bot
              Did I miss where the types of drivers were announced? 5160? 2209?
              Never mind, saw the other thread.
              What would be the differentiation between this and the Duet2 Eth/Wifi?
              *not actually a robot
              pixelpieperundefined A Former User? 2 Replies Last reply Reply Quote 0
                pixelpieper @bot
                @bot Modern drivers with Stealthchop, more Memory, Raspberry-Pi interface, Neopixel-Support
                • botundefined
                  bot @pixelpieper
                  Hmmm, more memory sounds good. How much more?
                  I don't really care about the sound of the drivers. The 2260s in the Duet 2 work fine for me. Do the 2209's provide a slight reduction in the max amperage the drivers can push?
                  dc42undefined pixelpieperundefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @bot
                    @bot said in Duet 2 Pro 4 U:
                    Yes, they will probably be limited to about 2.0A peak. For users needing higher motor current, we have Duet 3.
                    pixelpieperundefined A Former User? 2 Replies Last reply Reply Quote 1
                      pixelpieper @bot
                      @bot AFAIK double the flash, don' know about SRAM. The 2209s are rated up to 2A, so yes a downgrade from the Duet2 but an update from the Maestro.
                        Double both flash and SRAM.
                          pixelpieper @dc42
                          @dc42 Will the driver expansion be available from the start or is the Maestro one compatible (worst case via jumper wires)?
                          Would love to get my hands on one to replace the Maestro in my Voron for science as I believe this will be the perfect beginner board where a ready made configuration can be easily shared.
                          The quad gantry levelling shenanigans definitely need at least 7 drivers...
                          • botundefined
                            bot
                            Will the increased RAM from the Duet 2 allow for the possibility to expand the look ahead queue, or speed up step generation, or anything like that? I'm not dissatisfied with the performance of RRF on my Duet 2, but I'm always looking to optimize speed and performance.
                              It will allow us to expand the lookahead queue, and I hope eventually speed up file uploading.
                                We expect the expansion board to be available from the start. We've already prototyped it.
                                  A Former User @dc42
                                  @dc42 said in Duet 2 Pro 4 U:
                                  are we reading between the lines that this new board takes the place of the entire Duet 2 range? (or that it is the extent of the Duet 2 redesign)
                                  edit:
                                  is this where the erase pin is hiding or is there a more capable bootloader somewhere?
                                    A Former User @bot
                                    there seems to be at least 0.5mm more clearance between the fan header and the fan mosfet - so much easier to repair >D
