    Homing advice
    3.0k
    • agent0810undefined
      agent0810
      so when i "home all" it sends it to the back right corner. when i got to 0,0 it goes to the front left corner. when i try to start a print, it starts in the back right corner, bangs against the stops then the bed starts to lower all the way.
        What do you have in your start gcode?
          agent0810
          Here is the start:
          ;FLAVOR:Marlin
          ;TIME:336
          ;Filament used: 0.10025m
          ;Layer height: 0.2
          ;MINX:89
          ;MINY:95
          ;MINZ:0.2
          ;MAXX:131
          ;MAXY:125
          ;MAXZ:14.8
          ;Generated with Cura_SteamEngine 4.6.1
          M140 S60
          M105
          M190 S60
          M104 S230
          M105
          M109 S230
          M82 ;absolute extrusion mode
          M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
          M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
          M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
          M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
          M220 S100 ;Reset Feedrate
          M221 S100 ;Reset Flowrate
          G28 ;Home
          G92 E0 ;Reset Extruder
          G1 Z2.0 F3000 ;Move Z Axis up
          G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
          G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
          G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
          G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
          G92 E0
          G92 E0
          G1 F5100 E-7
          ;LAYER_COUNT:86
          ;LAYER:0
          M107
            Phaedrux Moderator @agent0810
            @agent0810 said in Homing advice:
            Unrelated, but delete those lines from your slicer start gcode section in Cura.
            I don't see a G90 in there to make sure you're in absolute positioning mode.
            Does it do the prime line correctly or does it just start crashing?
              agent0810
              just starts crashing.
                agent0810
                Here are my machine settings in cura......do the print head settings look okay?
                  Change the Gcode flavor to RepRap.
                  Can you share an actual sliced gcode file?
                    agent0810
                    yea let me see what i can get. should i just place G90 in before the G92? googled it and didnt see an actual setting for it in cura but someone said they just put it in the start code.
                      Well I'd like to see the full sliced gcode first to see what it's actually got inserted where.
                        agent0810
                        I think this is what you are looking for.
                        base_x.gcode
                          Ok, try changing your start gcode to be
                          G28 ;Home
                          G90 ; absolute positioning.
                          G92 E0
                          G92 E0
                          G1 F5100 E-7
                          The other question I have is about your Z probe. Currently you are homing to the Z max position with an endstop. Do you also have a probe installed? Is your Z axis moving correctly?
                            agent0810
                            alright ill drop that in there, thank you.
                            i have this probe that came yesterday i need to install, but i need to print a bracket to put it on before i can lol.
                            https://www.filastruder.com/products/mini-differential-ir-height-sensor
                              agent0810
                              So i think we have progress, no crashing before hand, but the bed goes half way down and then it starts to print but doesnt extrude any fillament.
                                That sounds like the Z steps per mm is incorrect.
                                Try to measure how much it actually moves when you command it to move 10mm.
                                I'm not sure off hand what the Ender 5 pro Z steps should be, but if you have lead screw and motor details it can be worked out.
                                Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
                                  agent0810
                                  i raised it all the way, marked the back, lowered it 10mm then marked the back, lowered the bed out of the way and measured, looks like it only went about 4.5mm.
                                  Will the motor steps and driver info be online or on the device?
                                  thanks again for all your help on this.
                                    Doing a Google it looks like it might be 800. Which kinda matches with what you've measured.
                                      agent0810
                                      so update that in the config.g?
                                      current:
                                      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
                                      change to:
                                      M92 X80.00 Y80.00 Z800.00 E93.00 ; set steps per mm
                                        agent0810
                                        tried that and took a step back.
                                        it crashed a bit when the job started, then the bed lowered probably 3/4 of the way down and its printing now while the bed is still almost all the way down and no fillament coming out of the extruder.
                                          Does the Z axis move the right amount with 800 steps per mm?
                                          Can you post a video of it running?
                                          Is the extruder motor trying to move at all? Is the hotend at temp?
                                          And just to confirm, after homing you're able to jog the head around the bed fine?
                                          agent0810undefined 4 Replies Last reply Reply Quote 0
                                            agent0810 @Phaedrux
                                            This post is deleted!
