    Issues with print quality, wall surface rough.
    138
    15.0k
    • CorvoDewittV2undefined
      CorvoDewittV2 @CorvoDewittV2
      @Corexy @mwolter This is a PETG print I did last week, it was on the marlin board, but seeing as the Duet didn't change anything, maybe this will help ID something:
        @mwolter @Corexy I am also using these, do you think that is a problem? I will try the stock spring type when I get home. Maybe I should try printing some too.
        https://www.amazon.com/Befenybay-Aluminium-Flexible-Coupling-Connector/dp/B07RMZCLZ3/ref=sr_1_3?dchild=1&keywords=3d+printer+coupling&qid=1594218589&sr=8-3
        mwolterundefined 1 Reply Last reply Reply Quote 0
        • mwolterundefined
          mwolter @CorvoDewittV2
          @CorvoDewittV2 personally I prefer the solid couplers. They provide more support and are typically more axially concentric. IMO spring or spider (like in your link) couplers are only used to make up for design or construction flaws.
          CorvoDewittV2undefined 2 Replies Last reply Reply Quote 1
            CorvoDewittV2 @mwolter
            @mwolter I'll try printing some solid ones as my lead screws are straight and aligned. 5 walls of PETG should be good?
            CorvoDewittV2undefined 1 Reply Last reply Reply Quote 1
              @mwolter @Corexy OK I know this is a stupid question, but I have a dial caliper, and other than measuring the backlash of the z, is there something else I can measure that can help ID whats going on? It is in inches because America but still is there something I should test?
              • Corexyundefined
                Corexy
                Have you tried those settings yet? I'd do that before you work on it mechanically.
                One trick I've found with PETG is that if you are getting blobs building up on the nozzle tip, drop the extrusion multiplier (not the esteps) until it stops happening. PETG prefers to be slightly under extruded.
                I've got those same plum couplings on my other printers and haven't had any problems with them. Why did you change them from the standard ones anyway?
                I've got nothing else I can tell you from the information you've given until you do the steps I listed on post some pics. Best you do the same cube an benchy for comparison. Definitely there's some Z wobble there, but lets see it without the over extrusion first.
                  CorvoDewittV2 @Corexy
                  @Corexy Not yet I am still at work, ill be home in 2 hours. I just though spring ones were dumb, I changed them when I build the thing, IDK if I even printed much of anything with the stock couplings. Do you think the 0.9 deg motors would cause an issue on the XY?
                  Corexyundefined 1 Reply Last reply Reply Quote 0
                  • Corexyundefined
                    Corexy @CorvoDewittV2
                    @CorvoDewittV2 said in Issues with print quality, wall surface rough.:
                    0.9 deg motors are supposed to be the correct ones to use for X and Y, Z as well I am told.
                    You need to run all of your steppers at 75-85% of their rated current. That's the done thing apparently, and is better than guessing.
                    I haven't seen what your fan duct is doing, but it is definitely not good to have it blowing on the heater block.
                    Let's see how those prints work out, and take it from there.
                      @Corexy Ok thank you, I'll get back to you soon
                        @mwolter Here are the step files, thanks again!!!
                        Front Cover.STEP
                        Main Carriage TITAN.STEP
                        BLTouch mount for V2.STEP
                        fan mount 2.STEP
                        • Corexyundefined
                          Corexy
                          From this pic it doesn't seem that the fan is blatantly blowing on the heat block, and you've got a silicone cover on it as well. Sure you could certainly have a better fan shroud, but I don't think it's a major cause of any problems. I'd stick with the 40x10 blowers myself, but I tend to use as little fan as possible in my prints. I generally go with 10-20% fan on materials like PLA/PETG, and with the exception of bridging never go over 60%.
                          It would be nice to print some sort of U shaped cover to go over the doubled sections of belt, then use a cable tie to hold it in place. Nothing to do with print quality, but would jut be a nicer fit and finish.
                          I'm happy with my choice of a Bondtech BMG for my V-core printer. I'm a bit unsure about that E3D one, just looking at it.
                          CorvoDewittV2undefined 1 Reply Last reply Reply Quote 0
                            @Corexy So i ran with you setting (but 30% fan bc they won't spin at 20%) and its...different. the blobby nature is gone, but the z wobble is worse? What do you think?
                            • Corexyundefined
                              Corexy
                              Wow! That looks awful.
                              OK...so that's after you set the esteps?
                              What extrusion multiplier are you running in the slicer?
                              I'm a bit blown away by the curling of the corners on the top surfaces...I've never had that happen. It looks like a combination of over extruding and too much heat.
                              It would appear that the coast/retraction settings aren't working for that setup. Try removing the coast altogether ans dropping retraction to 0.5mm please.
                              Again, let's just leave the Z wobble for now and get the extrusion/retraction/temp right.
                              **EDIT.
                              I'd drop the extrusion multiplier to 90%/0.9 now as well as above comments.
                              I'd also leave the fan setting and drop 5 deg C on both first and second layers respectively.
                              This will be a slow process, but at least we can see the differences as we try things.
                              CorvoDewittV2undefined 2 Replies Last reply Reply Quote 0
                                @Corexy It sure does look awful! lol Yes that is after checking the esteps (within 0.1mm of 100mm at 1mm/s) and 94% flow rate, 30mm/s and all the settings you told me to do earlier. Sooo....now what? I can try lowering the fans as low as possible and do like 60% fan.
                                  @Corexy Should I leave wipe?
                                  • Corexyundefined
                                    No drop the wipe, and please note the edit to my above post.
                                    • Corexyundefined
                                      Corexy
                                      Also, did you say 16x micro stepping?
                                      @Phaedrux You're the expert on that mate....what do you think of that?
                                      CorvoDewittV2undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                        @Corexy Ah ok yeah ill print with the new settings now EDIT yes 16x interpolate on
                                        • Corexyundefined
                                          Corexy
                                          Mate I've got to go to work now, so please consider this in the meantime.
                                          As well as that, please don't let me be the only one giving you tips. I could be wrong and others should weigh in with their experience too.
                                          There's a major setting issue here it seems, so it's time to really go back to basics. Here's where I would go from here (assuming the machine is assembled correctly and the esteps are correct, and all at 0.2mm layer height/0.5mm layer width):
                                          1. Extrude filament while dropping the temp 2 degC at a time (no fan). When the extruder starts to click and the filament is "pigtailing" as it comes out of the nozzle, add 10 degC to that temperature, and use it as your print temp. Ignore what the reading is and whether it sounds strange, just do it to that temp.
                                          2. Print a 50mm cube with 2 wall thicknesses and 50 bottom layers (no fan). Using the Duet DWC and starting at 100% extrusion multiplier in the slicer, lower the extrusion (in the DWC or Paneldue) by 5% at a time until you see gaps in the extrusions. When gaps appear, then raise the EM by 2% at a time until they just close, possibly dropping 1% after that. ALLOW A FULL 3 LAYERS BETWEEN ADJUSTMENTS, and click the setting just as the print starts a new layer. Again, don't worry if the setting that works seems unorthodox, just find what works. The extrusion % you get in the DWC will become the EM value you enter in your slicer for that material profile. That's a start point, and as you print more technical prints like benchy's, you may alter it slightly. If the middle of the extrusions are neat and just touching, but the ends/direction changes are gluggy, that would suggest coasting will help but leave it for the moment.
                                          3. After that, do one of those "retraction tester" prints, the one with 2 vertical posts on a base. It's on thingiverse. Start at 0 retraction and increase by 0.2mm every 5mm of height by setting multiple processes in your slicer. Use 30mm/sec retraction speed and 120mm/sec free movement speed/40mm/sec print speed throughout. No wipe/coast/vertical lift...nothing at all but the retraction height. No fan, and don't worry if there's some stringing. Just go for the best result, and then you can do it again using that retraction setting but adding 10% fan every 5mm of print height.
                                          Please take pics of all these tests and post them here.
                                          It has been my experience that settings that vary wildly from S3Ds generic profile settings indicate an underlying issue, but don't dwell on that for now.
                                          Also please remember I'm just one of a million opinions/methods on the internet and take my advice as you will.
                                          Good luck!
                                            Phaedrux Moderator @Corexy
                                            @Corexy said in Issues with print quality, wall surface rough.:
                                            x16 with interpolation is the way to go.
