    Issues with print quality, wall surface rough.
    138
    14.5k
      No sense retyping the wheel
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
      Corexyundefined 1 Reply Last reply Reply Quote 0
      • Corexyundefined
        Corexy @Phaedrux
        @Phaedrux said in Issues with print quality, wall surface rough.:
        You know I've used bang bang on the bed of my Duet/Zortrax for 4 years...it's just got the built in thermistor that came with the Keenovo mat.
        Would I benefit from PID? I certainly see some minor Z banding there. I always chased it mechanically.
        • Corexyundefined
          Corexy @CorvoDewittV2
          @CorvoDewittV2 said in Issues with print quality, wall surface rough.:
          This is the most frustrating part. This is a print off the ender 3 pro I have. I've spent less that half on that printer that I have on the v core.
          I've got bad news for you...that's a bit ordinary for an E3 Pro. I've got one too with BMG extruder, Capricorn tube/fittings and a stock hot end/fans with a printed fan shroud, and it knocks out the best prints I've ever done or even seen...regularly.
          When you've done tweaking this one, you need to go and do the 3 steps on that one too.
          If you don't mind paying for Simplify 3D, they have a built in profile that works pretty well for that model too.
          CorvoDewittV2undefined 1 Reply Last reply Reply Quote 0
          • CorvoDewittV2undefined
            CorvoDewittV2 @Corexy
            @Corexy I did the 2/3 steps. 96 is the extrusion multiplier and 190 is the temp. It looks no different. There is a mechanical issue. My guess is the lead screws. But honestly do I really want to throw more money at this printer? If I was able to tune in the ender 3 with much less fiddling, then why would I keep fiddling with this one? I'm sorry im just upset. I've spent every day for 2 months and over 2k on this printer.
              CorvoDewittV2
              Also just noticed that sometimes when I start a print it will not set the extrusion multiplayer. So got to figure that out now. Must be something with the start gcode. I sometimes get an error that no tool is selected but it it heats up the only one I have so IDK.
              • Corexyundefined
                OK, so those temp/EM numbers sound quite reasonable. Run with those. Have you done the retraction test yet?
                So where's the pics of the 100x300 single walled vase mode cylinder? Do that please next.
                The other cylinder you posted above looked much better, why be upset? You're moving in the right direction.
                You're not going to get better prints from this printer, you get much larger prints due to the build volume.
                You haven't eliminated the bed temp causing the banding yet, but just do the cylinder next and put the picture up here so people can help you.
                And please tell me about this electronic protractor...I might use one.
                No use flipping out mate. You've got to keep your shirt on, take the curlers out and move through the steps. It's frustrating but victory is sweet in the end. If you want to see frustration, go back through my posts to when I first converted a Zortrax to Duet...I drove everyone mad. Now I've used it for 4 years and it's pounded out tonnes of top prints. It's a total work horse.
                Cylinder pic next please!
                  @Corexy Its a Wixey Digital Protractor, about $60 US.
                  I have the 8 inch one from woodworking, but for printer building I would prob get a smaller one. I'll pick this back up tomorrow. Maybe I need to lower my expectations a bit too.
                  • Corexyundefined
                    Extrusion multiplier is set in the slicer, at least that's how I do it. I'll save a profile in the slicer for a specific roll/material, which has all my preferred settings for that material. The only thing I have in the config file is Esteps, which I'll check and change as required when I change rolls.
                    My understanding is that Duet will always start a print at 100% flow, but that will be 100% of the flow/EM setting you entered in the slicer.
                    • dgratundefined
                      dgrat
                      Is the titan running free (without filament if you spin the gear 360). I often had issues with them. But to be honest, this rather looks like a loose pulley somewhere on the XY axis. Or maybe the extruder is loose. The lack of accel dependency is maybe an indicator.
                        CorvoDewittV2 @dgrat
                        @dgrat Well I kinda agree with you on the pulley front. They are tight and do not wiggle, but they are all smooth pulleys. I am wondering if i should change the ones that run on the tooth side to ones with teeth. I'm just not confident it will fix much of anything. I check the titan tonight.
                          CorvoDewittV2
                          On a semi related note, what current should I be running to these steppers? They are the e3d ones.
                            60 to 85% of rated
                              CorvoDewittV2 @Phaedrux
                              @Phaedrux Thank you !
                              • mwolterundefined
                                mwolter
                                @CorvoDewittV2 Sorry for it taking so long! Started by working with an existing design and ended up totally recreating them to work within the constraints. They should clear everything including the BLTouch but the fans will be a little difficult to install due to the upper mounting bracket.
                                Printing and Preparation
                                This design is very similar to a duct I used in the past and it printed properly with supports. You might have to be a little creative with how it's positioned on the build plate. The fan screw holes will need to be opened up with a drill bit after printing. I purposely undersized them so the screws have a good amount of plastic to grip.
                                Mounting
                                Start by mount the duct to the hotend with upper screw only, rotate the duct around so the fan can be inserted from the front of the hotend. Put in all the fan screws, then rotate the duct around and insert the bottom screw. It should fit M3 screws if enlarge the holes a little.
                                Let me know how they work and if you need any changes!
                                4010-blower-duct-left.STEP
                                4010-blower-duct-right.STEP
                                CorvoDewittV2undefined 1 Reply Last reply Reply Quote 1
                                  CorvoDewittV2 @mwolter
                                  @mwolter Oh I am so excited man!! Thank you so much! I will print as soon as i get home report back. You are awesome.
                                  • mwolterundefined
                                    mwolter
                                    You're welcome, hope this helps!
                                    CorvoDewittV2undefined 2 Replies Last reply Reply Quote 1
                                      @mwolter Side one done, fits and looks great!!!
                                        @mwolter This looks great!!!! I love it! Thank you so much!!!!!!!!
                                        mwolterundefined 1 Reply Last reply Reply Quote 0
                                        • mwolterundefined
                                          mwolter @CorvoDewittV2
                                          @CorvoDewittV2 Glad you like it! Can't wait to see the prints!
                                            @mwolter I have to do some prints for work, but I will follow up for sure!!!
