Mosquito hot end...yes or no?
43
5.7k
    Corexy @Lanovar
    @Lanovar said in Mosquito hot end...yes or no?:
    @Corexy said in Mosquito hot end...yes or no?:
    I'm wondering how the long term longevity and reliability is, and I guess as well whether you felt it was worth the high price.
    I havent had any problem with the hotend, yet. The Extruder jammed once, but that was kind of my fault (crappy Geeetech filament)
    But! Mind the weight of the "printhead as a whole". I dont find it easy to get rid of ringing, still after a month Im not satisfied with my profiles.
    If you want to safe "some" money, consider going the the standart mosquitto. Imho you cant push a V-Core to speeds where you would need a magnum, without your prints looking like shit.
    Also, did you use the Slice engineering thermistor, or a PT100?
    Slice, same goes for the heater.
    Mate I've never gotten rid of some ringing on any printer without slowing it to an absolute crawl.
    Yeah, I'll probably go with the standard Mosquito over the magnum. If I'd have gone E3D V6 I wouldn't bother with the volcano either.
    undefined 1 Reply Last reply 10 Jul 2020, 12:09 Reply Quote 0
      Corexy @JoergS5
      @JoergS5 said in Mosquito hot end...yes or no?:
      Has anyone actually gotten a tool changer to work reliably?
      I have no experience, I am only watching the discord about toolchangers of E3D, Jubilee etc. I find it exciting to see what is being created, but have no recommendation. It was more a suggestion, which direction would be interesting. Tool changer is at the beginning of the "innovation hype cycle", so I am sure there will emerge additional players and solutions.
      Yeah I'll pass on the tool changer. I'm going for a simple, durable, reliable large volume printer.
        Lanovar @Corexy
        Iirc the standart mosquitto even has a hight max flow then the V6. So i wouldnt mind.
        On the other hand -> BMG Mosquitto - the magnum is only 20€. Anyways, i like the combination with a prusa IR sensor for loading and unloading.
          fcwilt
          I have the standard M on both my printers and am very happy with the performance.
          undefined 1 Reply Last reply 10 Jul 2020, 21:44 Reply Quote 1
            Corexy @fcwilt
            @fcwilt
            Thanks mate,
            I didn't realize there were a few of you using Mosquitos on here, good to know.
              arhi @Corexy
              YES!
              I've searched here and elsewhere regarding the Mosquito hot ends vs the E3D V6, and there's
              I'm running e3dv6 (original) since they exist (both 3 and 1.75)
              I'm running hexagon's also since they exist (both 3 and 1.75)
              I'm running 1730 from Kai
              I purchased M-clone (it is POS 😞 )
              I have seen original Mosquito in action and fell in love
              I'm using original Mosquito (short period only 😞 )
              1730 rocks, it is the best contraption I tried before Mosquito, it is much better than e3dv6 and hexagon. Hexagon is also IMO better than e3dv6. The problem is the environment, e3dv6 has env. that covers almost all your needs, others don't so getting parts for 1730 or hexagon ain't that simple. Mosquito came hard, adopting e3dv6 style nozzles and hitting all the shops out there so almost anyone selling 3d printer stuff is selling mosquito too, they reached BMG and other serious extruder manufacturers to create ready to push combos.. they are creating their own environment and doing it properly so while I do like the 1730 nozzle style better for e.g. Mosquito is overall much better device (of course if you want to print clay or some of those other Kai's crazy filaments 1730 is a must as Mosquito just like e3dv6 don't cut it)
              Mosquito comes as a breath of fresh air IMO both small footprint and ease of use. But I see v2 comes with some changes that confirm heat creep with PLA on v1, especially for slow prints or multi head prints. If you are going to be printing mostly PLA and PETG - any hotend will work. Mosquito will for sure get the job done (you wanna get the magnum if you wanna do fast & large extrusions) but the question is if it's worth the extra $$$ for features you do not need where 30$ hotend with a good original nozzle will do just as good.
              I see you are already advised to go .5 and not .4 for the nozzle. I personally use .6 for 99% of prints, .6 allow you to easily print both .1mm layer and .5mm layer.. not to mention, you can do .1mm perimeters and .5mm infill 😄 .. You can't have super precise fine features in XY but do you need them and how often?
              undefined undefined 2 Replies Last reply 10 Jul 2020, 23:30 Reply Quote 2
                Corexy @arhi
                @arhi said in Mosquito hot end...yes or no?:
                YES!
                Thanks mate, that's some good info!
                I only remember seeing the 1730 some time back and ignoring it. Didn't realize it was good, as you don't often hear about them.
                I think it's a good idea to stay away from V1 of anything IMHO...there's always issues that will only turn up in real world long term use, which is why I've been asking here.
                While it will be mostly PLA and PETG, I will look to enclose this machine later and want the option there to print exotic materials as well. I don't buy a new machine every week (my current workhorse has run for 4 years now, working hard) and I want this to be my long term/large print setup, so I'll be pretty obsessive about the components I use and correct assembly.
                I must admit I've got a subconscious resistance against moving away from a 0.4mm nozzle...I'll just but an assortment of sizes and play around with them. After all, I'll be having that "easy one handed nozzle change".
                Thanks for your post, I really appreciate it.
                undefined 1 Reply Last reply 11 Jul 2020, 02:28 Reply Quote 0
                  arhi @Corexy
                  😄 It's cause Kai Parthi is not a marketing guy but engineer/inventor. He's the guy who invented wood filament for e.g. but you will almost never find his wood filament out there but other brands that took the process and are using and marketing it etc etc... Kai made 1730 because he had problems with all other hotends on the market with his ceramic filament as his ceramic filament is very brittle and 1730 works ok with brittle filaments (and all other ones too). I don't know if he pushed it to market I'm using proto version. The idea is that he's using a "nozzle" that's all integrated, basically a surgical steel tube brased (soldered) to the e3d type nozzle. and then you put the heater block at the begining ad a big cooler at the rest of it and it works 😄 and it works great .. this is my 3mm nozzle:
                  If you look at feltlay, polylay, porolay, woodlay, layfomm ... etc etc .. those are all filament made by him. Unfortunately his filaments (like his hotend) are rather expensive so not very popular, and he's not investing in marketing so few ppl know about them too...
                  https://www.matterhackers.com/store/c/Kai Parthy Lay Series
                  https://shop.3dfilaprint.com/kai-parthy-filaments-229-c.asp
                  Don't get me wrong V1 Mosquito works like a charm. It is AWESOME!!!. @omni was reluctant to mount it as he was using original extruder for a while and was "waiting for everything else of upgrades to finish before he..." .. when he moved to Mosquito he was confused how good it was compared to original (ok, original is wanhao mk something bs so not hard to be better but again). 😄 .. and he printed a lot of PLA and PETG with it (I think he did not try anything else yet) so v1 Mosquito works like a charm for PLA and PETG (and other stuff too, but for other stuff even the shitty clone is perfect with ABS/ASA/HIPS/PA so ..)
                  I'd go with Mosquito for sure then!!! BUT I'd immediately ask about water cooling option. They mentioned it in numerous videos I see but I did not see water cooling block for sales. If they have it I'd get it. It will work awesome immediately of course but will be crucial in enclosed printer with exotic filaments IMHO so better immediately go that route 🙂 as that's something most ppl forget when they plan for printing in enclosure... ABS is ok, enough to close the printer and get there some 40C (you need 70 for big intricate parts but 40 will do for number of parts) and air cooling work ok-ish in 40C env, but if you wanna print PA you need serious temps and air cooling will not work
                  Dunno, when I started over a decade ago my first nozzle was .5mm and since it was super hard to get anything excet PP and HDPE locally I had to print with them and I had a huge roll of recycled PP that was full of shit so I had to redrill that nozzle to .8mm. Since then I'm used to big nozzles and you can really do a lot with them. If you use multiple nozzles .4 is the worse, it's a nozzle you will most probably never use. My take on nozzles is
                  • I print drafts .6mm nozzle - it is fast, it is strong, it can easily go down to .1mm layer and up to over .5mm (no need to go over .5)
                  • I print large structural parts (parts for printer, parts for cnc, lathe, holders for bike, racks..) I go with .6 or .8mm nozzle - it is super strong, super fast
                  • I print figurines, detailed stuff etc .. I go with .3mm nozzle
                  • I need top details - .2 mm - but this is super rare, I need to drop from .3 if I need to print a business card for e.g.
                  so .6 is for me really the all arounder .. I was normally (till recently) going with dual hexagon and that was 3mm 0.6mm nozzle + 1.75mm 0.3mm nozzle .. that's kinda perfect fit for me, .6mm for infills and stuff, .3mm for outside perimeter, top/bottom..
                    Corexy
                    Cheers again mate, appreciated!
                    I'm pretty familiar with printing ABS in enclosures. It was the first printing I did actually, with UP Plus's fitted with these little locally made enclosures that actually worked quite well. Best heat I ever got into them (or the enclosed Zortrax M200's I got after that) was just on 50degC in the heat of the Australian summer.
                    These were just passively heated by the bed and hot end, with the fan's mixing it up, but it worked quite well for medium size ABS prints. Even PLA in freezing cold overnight prints in winter certainly benefited from have the enclosure at 24-26degC.
                    For this machine I'll most likely start or even stick with the same passively heated approach, but I hope to control an exhaust fan via the Duet board and a PT100/1000 mounted in the cabinet somewhere. I've designed a filter/fan housing that uses cheap generic charcoal face mask cartridges, and will allow me to run a light corrugated hose to an exhaust point outside my workshop.
                    So for now my plan/budget is for a "warm, naturally aspirated" enclosure, but controlled through my board so I can possibly include cabinet temps in my print profiles. I will most certainly allow for upgrading to water cooling at a later date however. Of course if they actually release a water cooled version before I've bought my extruder/hot end......
                    It's a lot of fun procrastinating during the lead up to building in this case. I have no choice at the moment, as if I don't clean up the garage, finish a current home reno and a couple of other projects, the minister for finance (and war) will include a curtailing of the budget allocation in the minutes of the next financial meeting. It's all political sometimes.
                      deckingman @arhi
                      @arhi According to my contact at Slice Engineering, the small change to the V2 mosquito heat break has nothing to do with heat creep. It is merely to add extra support to the top of the very thin wall tube, because they had a small number of users who managed to damage the ends of those tubes.
                      Edit. That's kind of born out by the fact that the V2 simply has a longer copper part above the finned copper heat sink. If heat creep was an issue, then they would have made the heat sink fins larger in diameter or added more of them.
                      undefined 1 Reply Last reply 11 Jul 2020, 16:42 Reply Quote 0
                        arhi @deckingman
                        @deckingman said in Mosquito hot end...yes or no?:
                        Well whatever they do they will have users break it, we all know that 😞 ... didn't you manage to break some of those tubes too 😄 .. iirc you broke the distancers not the feed tube right?
                        they didn't (weirdly) explain why they did it so I assumed what I assumed and looking at the way it is now it is collecting more heat from that thin tube. As I mentioned V1 works like a charm but this upgrade is a welcome one 🙂 ..
                        With regards to those fins, few things are unclear to me there. From what I learn on mechanics unversity (was too long ago and I switched to electronics so ..) copper has better heat conducting properties than aluminium so but aluminium has better heat transfer properties so if I understand properly aluminium heat sink would pull more heat from the steel tube and release more heat to the air, the only thing where copper is better is having the whole heatsink at same temp... and making everything heavier .. it would be awesome if they shown some tests they made with heatsink made out of alu vs copper and how temp inside the steel tube changes depending on that material..
                        undefined 1 Reply Last reply 11 Jul 2020, 17:33 Reply Quote 0
                          deckingman @arhi
                          @arhi I had 6 Mosquito heat breaks screwed into a single, big hot block but without the side plates that normally surround the heat breaks, and without the top plate that normally supports the top of the tubes. That's why the tubes bent when I stupidly dropped the partial assembly.
                          As for the heat sinks on the tubes, if the filament is moving forward as in a normal print, one can print PLA all day long without any heat sink at all. The reason for the heat sink is to dissipate any heat that conducts up through the filament itself when printing for example voroni vases with lots of retractions and very short moves.
                          In an ideal world, the heat break itself should be a low conductor, but the tube above the heat break should be a good conductor so as to dissipate heat to the surrounding air. What we need is a composite tube with Copper butt welded onto Titanium or some such. 🙂
                          As an aside, it is the lower most fins of a heat break that dissipate most of the heat. That's why the Diamond 5 colour is so much worse than the 3 colour for heat creep. Because in order to get 5 heat breaks in the same diameter circle, the lowermost fins are smaller.
                          It would be simplicity itself for Slice Engineering to make those fins bigger so my take on it is that they don't consider it to be necessary. They do have some very expensive thermal imaging equipment, so I guess they know what works.
                          undefined 1 Reply Last reply 11 Jul 2020, 23:20 Reply Quote 0
                            arhi @deckingman
                            Not something I can confirm. Something I read they wrote in a few places, not something I can confirm really. No retractions - no pauses, printing at some decent speed, the small fan blowing trough the heatsink of a mosquito heated the petg 2 cm away from the mosquito so much it lost structural stability and warped. The aluminium frame that's not used as heatsink at all hot so hot (even with fan !!) that it melted the screws out of PETG and released itself. (solved by tapping a 2mm steel plate with 2 M2.5 holes and crewing mosquito into steel plate and steel plate into petg and now it works ok) ... so the hotend does print, and it prints awesome, but I could not confirm all the thermal claims they made nor reproduce all the thermal imagery they shown
                            they, for sure, do a lot of testing and make a lot of imagery but they on the other hand do not share what they do and how they came to what conclusions (for obvious reasons 😞 ) so we have to take their word that they made the best decisions. That's generally not a problem when everything works 1/1 out of the boks but we had to redo a carriage on omni's machine 2 times to deal with heat issues... it was printing non stop, that's not the problem, but not without a fan
                            undefined 1 Reply Last reply 12 Jul 2020, 06:01 Reply Quote 0
                              Corexy
                              Why is it that Slice use a thermistor rather than a PT100/PT1000 for their hot ends?
                              Is there any advantage to using an RTD probe over their standard thermistor with the Duet? What are you all using?
                              undefined 1 Reply Last reply 12 Jul 2020, 04:17 Reply Quote 0
                                arhi @Corexy
                                Why "slice" use it I can't say, but I for e.g. use NTC on most of my printers because
                                • I purchased one time a 300 pieces of the NTC a closed source device was using and 300 was a minimum order Semitec allowed me to make so I still have a bunch of them so I use them wherever I need to measure temperatures up to 350C
                                • precision .. for e.g. 204GT-2 that I have a lot of and use a lot is 10740R at 100C and 186 at 300C so over the "interesting" span it's 10000 ohm difference. Or if we wanna go tight 190-250C for our most used PLA/ABS/PETG/HIPS is 1122 to 383 ohm so still a rather big span. If you compare that to PT100 for the 100-350 it is 138.5R - 229.7R so we'r talking only 91.2R on the whole range, or even worse if we only look at the 190-250 that we wanna be precise in we'r talking span of 22R !!! in noisy envinroment like a 3d printer that's expensive... in order to read PT100 you need amplifier close to the sensor, or you need to run 4 wires (at least 3 but really 4) to the sensor and noone is doing neither, they use either the amp on the board or a super sensitive ADC (expensive) and then they filter out the noise but that kills the resolution big time... so while PT sensor is cool thing to use running a 2 wire sensor trough meters of cable harneses .. just not worth it, nothing you gain really...
                                • cabling, I myself for higher temperatures like to use thermocouple and not RTD but with thermocouple you need a long cable made from thermocouple material and you need to measure the "cold joint" temperature where you connect that to the copper cabling going to the TC amp. I did experiment a bit with this by making a cold joint integrated with ntc inside the extruder carriage and that works ok as running a thermocouple wires trough the wire harness does not as all the types I tried do not survive bending long even when put inside ptfe tube and trough cable chain. with duet3 toolboard this might be done easier as you can have toolboard per extruder handling all that but not everyone has toolboard (nor they existed tiill few days ago)
                                So IMHO NTC is way cheaper and easier to use than PTC or TC so I stick with NTC.
                                What RTD probe? NTC and PTC are both RTD. The probe provided by the Slice engineering IIRC goes up to 500C. Most NTC probes don't go over 180C, very few go up to 250C and just a few (that we use for 3d printing) go above 250C and afaik none of them go over 350C. Since Mosquito is certified to print up to 500C and for some materials you need to go that high your solution is to go either with PTC or TC which is, as I already explaind, complex and expensive and inprecise so Slice found a NTC that will go that high, so it will be "cheap" (as in will work in any of your boards like a normal NTC without any need to upgrade/modify) and will go up to 500C... awesome if you ask me 🙂
                                undefined 1 Reply Last reply 12 Jul 2020, 05:43 Reply Quote 0
                                  Corexy @arhi
                                  OK mate...obviously if I knew heaps about it it wouldn't be asking, so please forgive me for thinking that an RTD was the PT100/PT1000 only. Worse things will happen before we die.
                                  While I appreciate your help, that reply has only dazzled me a bit. Thermocouples are out of the question for me, and I don't need 500degC. 350degC would be new territory for me. I do have a PT100 on my existing printer, and I did use 4 wires with it. It has worked well for 4 years, and seems to be accurate and consistent.
                                  In simple laymans terms I am just asking is there any reason I would buy the PT100/1000 instead of the standard thermistor for the Mosquito? I don't mind soldering up 4 wires, and if the PT1000 is worth it with 2 wires that's fine too. If the obvious solution is to just use the standard thermistor that Slice sells, I'll just do that.
                                  Basically expense aside, which is the best for all round use up to 350degC?
                                  undefined 1 Reply Last reply 12 Jul 2020, 13:35 Reply Quote 0
                                    deckingman @arhi
                                    @arhi Did you reach out to Slice Engineering when you had those problems? If not, why not? If so, what was their response?
                                    undefined 1 Reply Last reply 12 Jul 2020, 13:40 Reply Quote 0
                                      arhi @Corexy
                                      RTD == Resistance Temperature Detector
                                      They come as NTC (negative thermal coefficient) and PTC (positive thermal coefficient). PT100 is PTC.
                                      When you have "an amplifier" for PT100 or high precision ADC it works ok. But not all 3d printer boards do. When you have "pt100 input" and you use 4 wires PT100 is more precise than the NTC in general case so in that case it's better to use PT100 as it's more precise.
                                      PT100/1000 is more precise if you have PT input on your electronics (for PT100 you need daughterboard for duet boards, and for PT1000 you can hook it up directly to maestro only iirc)
                                      As for "what's the best" I think it makes no difference in real life. Absolute temperature does vary a lot between probes (up to 3%, even 5% on super cheap PRC stuff) but if you go with temp tower to find the best temp for your setup you don't care much about "absolute values", that is one of the reasons you should always use temp tower and not take numbers you read on the box for granted 🙂
                                        arhi @deckingman
                                        No 😞
                                        It is not my device and not my printer so it was not my place to do so. I did advise that Slice be contacted, but since the solution with metal plate worked ...
                                        My original is "en route" so I'll do extensive testing with thermal images when it arrives with the SEEK camera (don't have anything better 😞 )
                                        undefined 1 Reply Last reply 12 Jul 2020, 14:24 Reply Quote 0
                                          deckingman @arhi
                                          @arhi That's really strange about the surrounding mount part getting so hot. With my experimental design, I used a very similar arrangement to hold the great lump of a hot block which had 6 Mosquito heat breaks screwed into it. When heated to 200+ degrees with an 80 watt heater, the surrounding mount was barely above ambient. I'd hazard a guess with my "calibrated finger tip" that it was about 45 to 50 deg C at most.
                                          undefined 1 Reply Last reply 12 Jul 2020, 18:22 Reply Quote 1
                                          22 out of 43
