    G29 G32 😱
    3.0k
    • nemecekundefined
      nemecek @Phaedrux
      @Phaedrux
      G29 S1 P "heightmap.csv also delete this from simplify3d start script? bI'm sorry if I write badly I use google translate
        Just delete the P "heightmap.csv" part from the start script. Leave G29 S1 intact.
        nemecekundefined 1 Reply Last reply Reply Quote 0
        • nemecekundefined
          nemecek
          ok🙂
          • nemecekundefined
            nemecek @Phaedrux
            @Phaedrux nothing has changed😲
              Then I'm all out of ideas and we're back to improving the mechanics. That's the limit of my delta insight unfortunately.
              • nemecekundefined
                nemecek
                hello can you tell me if I have to set the offset of my extruder with respect to the center of the effector? maybe that's why the map doesn't compensate well
                  Do you mean the offset of the probe?
                  • nemecekundefined
                    nemecek @Phaedrux
                    @Phaedrux no my titan aero is not in the center of my effector so the nozzle is not in the center of the effector
                    • nemecekundefined
                      nemecek
                      to make you better understand when I go down the z to 0 leffector and centered on my plate. but I nozzle no
                        That is interesting. I'm not sure, but I think you could use the G10 tool offset to better define where your nozzle actually is in relation to the center of the effector. This may actually help your G29 performance because the probe offset assumes that it's offset from the nozzle.
                        nemecekundefined 2 Replies Last reply Reply Quote 1
                        • nemecekundefined
                          nemecek @Phaedrux
                          @Phaedrux ok i will try today. I will let you know
                          • nemecekundefined
                            nemecek @Phaedrux
                            good morning I did not understand correctly. did you tell me about the g10 should i enter the offset here?
                              Yes that is where you can set the tool offset. Or in your case, the nozzle offset from the print head center position.
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_G10_Tool_Offset_and_Temperature_Setting
                              nemecekundefined 2 Replies Last reply Reply Quote 0
                              • nemecekundefined
                                nemecek @Phaedrux
                                ok but in homedelta as well I have to change here?
                                  No, that's a G1 command to move the head to a X Y position, nothing to do with G10.
                                  • nemecekundefined
                                    nemecek
                                    good morning I have not yet solved the problem today I noticed that after correcting the G32 when I go home I start with the correction of the x y axes as you see in the photo
                                    so I was wondering if I had to resume my probe offset starting from the correction? I tell you this because if I do a small survey 100 x 50 with G29 then I print a picture of 100 mm my nozzle is not precise on the survey that I marked with a pen on the plate
                                    • nemecekundefined
                                      nemecek @Phaedrux
                                      here I have to add L2?
                                      • nemecekundefined
                                        nemecek
                                        also my calibration is not centered on what depends?DBBB5AF3-B994-4941-B5E5-22A3A0F28823.jpeg
