    G29 G32 😱
    3.2k
      Yes that looks like it should work
      nemecekundefined 1 Reply Last reply Reply Quote 0
      • nemecekundefined
        nemecek @Phaedrux
        @Phaedrux 😕
          I'm afraid the issue is with the calibration and mesh creation being inaccurate due to mechanical issues. Some things software can't correct for.
          • nemecekundefined
            nemecek
            I also tried to lower 40% of the values in the map where I highlighted in the photo above ...
            without success I have not noticed any difference
            • nemecekundefined
              nemecek
              and how is it possible then that without the map doing only the G32 and putting a thickness of paper folded in 2 under the plate I adjust only the height print well😮
                If it's printing well without G29, why use G29?
                The combination of probe offset from the nozzle and effector tilt varying with position can lead to probed points being inaccurate.
                • nemecekundefined
                  nemecek
                  yes I understand but something should change if I change the values of the map manually instead nothing changes ok thanks for everything I keep the thickness of cards under the plate🤔
                    Phaedrux Moderator @nemecek
                    @nemecek said in G29 G32 😱:
                    G29 S1 P "heightmap.csv"
                    Do you have multiple saves heightmaps?
                    Try deleting your current heightmap entirely from the /sys folder
                    Then recreate it with a fresh calibration run and then a G29
                    and then use just G29 S1 to load the default heightmap.
                    • nemecekundefined
                      nemecek @Phaedrux
                      @Phaedrux said in G29 G32 😱:
                      G29 S1 P "heightmap.csv" so delete this from the start?
                        Remove the P"heightmap.csv part
                        • nemecekundefined
                          nemecek @Phaedrux
                          @Phaedrux
                          G29 S1 P "heightmap.csv also delete this from simplify3d start script? bI'm sorry if I write badly I use google translate
                            Just delete the P "heightmap.csv" part from the start script. Leave G29 S1 intact.
                            • nemecekundefined
                              nemecek
                              ok🙂
                              • nemecekundefined
                                nemecek @Phaedrux
                                @Phaedrux nothing has changed😲
                                  Then I'm all out of ideas and we're back to improving the mechanics. That's the limit of my delta insight unfortunately.
                                  • nemecekundefined
                                    nemecek
                                    hello can you tell me if I have to set the offset of my extruder with respect to the center of the effector? maybe that's why the map doesn't compensate well
                                      Do you mean the offset of the probe?
                                      • nemecekundefined
                                        nemecek @Phaedrux
                                        @Phaedrux no my titan aero is not in the center of my effector so the nozzle is not in the center of the effector
                                        • nemecekundefined
                                          nemecek
                                          to make you better understand when I go down the z to 0 leffector and centered on my plate. but I nozzle no
                                            That is interesting. I'm not sure, but I think you could use the G10 tool offset to better define where your nozzle actually is in relation to the center of the effector. This may actually help your G29 performance because the probe offset assumes that it's offset from the nozzle.
                                            nemecekundefined 2 Replies Last reply Reply Quote 1
