    New IR z probe issues
    IR Height Sensor
    3.5k
    • agent0810undefined
      agent0810
      New to 3d printing and have a Duet 2 wifi board on my ender 5 pro. trying to add on my IR probe. it keeps showing red 1000 on the web interface. Been trying to follow this with no luck:
      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mini_differential_IR_sensor_by_dc42
      This is the sensor i bought with cable:
      https://www.filastruder.com/products/mini-differential-ir-height-sensor
      here is my config:
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:26 GMT-0500 (Central Daylight Time)
      M550 P"Schaal3DPrinter" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z800.00 E102.30 ; set steps per mm
      M84 S30 ; Set idle timeout
      M208 X225 Y225 Z300 S0 ; set axis maxima
      M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      M501
        Phaedrux Moderator @agent0810
        @agent0810 said in New IR z probe issues:
        You can try inverting the signal by adding a ! to the pin name like this
        M558 P1 C"!zprobe.in" H5 F120 T6000
        But that seems odd for the IR sensor as I don't think that's normally required.
        Use this test method after to carefully check it works.
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          agent0810
          I did the dynamic test after adding the ! and it failed. The bed was moving up twards the probe and put a paper under the probe to stop it and it didnt stop. i dont see what do to do if that test fails. thank you again!
          The sensor on the web page now shows 5. so that is an improvement i think.
            Can you double check the wiring? It's showing as triggered when it should not be. The Zprobe pin would be suspect.
              jay_s_uk
              These should have the pullup resistor enabled.
              So it would be
              M558 P1 C"^zprobe.in" H5 F120 T6000
                agent0810
                Thanks guys, got the wiring fixed. centered it on the bed and got it where it needed to be, ran the G92 Z0 to tell it that is Z0, then ran lowered the bed and ran G30 S-1 and it keeps stopping before it should. states stopped height 1.274mm or another time 1.255mm or another time 1.320mm. not sure what i am doing wrong on settting the Z0.
                  Is your bed at temp during this? Have you PID tuned the bed? Using bang bang can cause the bed shape to change when the heater is energized and could explain the variation.
                  agent0810undefined 1 Reply Last reply Reply Quote 0
                    agent0810 @Phaedrux
                    @Phaedrux my bed was not at temp, so it was at room temp. i did a PID tune after i installed the new board as well.
                      What is the beb surface? can you test with a sheet of plain white paper?
                      agent0810undefined 2 Replies Last reply Reply Quote 0
                        agent0810 @Phaedrux
                        @Phaedrux its a glass bes with a black material on it. i can throw a piece of white paper on it to see if it makes a difference.
                          agent0810 @Phaedrux
                          @Phaedrux sorry for the delay, same result with the plain white piece of paper, stopped at
                          Stopped at height 1.745 mm
                            Consistently? Does that make sense given the thickness of the glass? assuming the black is on the back side?
                              agent0810 @Phaedrux
                              @Phaedrux im new to this but i dont think so. i thought when we got it level in the middle and sent that code it told the probe where 0 is? shouldnt that be where it stops then?
                                Post your homing files and bed.g.
                                When you do the G30 S-1 procedure to measure the trigger height, is it consistent now?
                                  agent0810 @Phaedrux
                                  @Phaedrux
                                  bed.g
                                  G29 ; probe the bed and enable compensation
                                  ; homeall.g
                                  ; called to home all axes
                                  ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 20:32:27 GMT-0500 (Central Daylight Time)
                                  G91 ; relative positioning
                                  G1 H1 X+250 Y+250 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                  G1 H2 X-5 Y-5 F6000 ; go back a few mm
                                  G1 H1 X+230 Y+230 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                  ;G1 H1 Z305 F360 ; move Z up stopping at the endstop
                                  G1 H1 Z-320 F360 ; move Z stopping at the endstop
                                  G90 ; absolute positioning
                                  ;G91 ; relative positioning
                                  ;G90 ; absolute positioning
                                  ; homex.g
                                  ; called to home the X axis
                                  G1 H1 X+250 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                  G1 H2 X-5 F6000 ; go back a few mm
                                  G1 H1 X+230 F360 ; move slowly to X axis endstop once more (second pass)
                                  G1 H2 Z-5 F6000 ; lower Z again
                                  ; homey.g
                                  ; called to home the Y axis
                                  G1 H1 Y+230 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                  G1 H2 Y-5 F6000 ; go back a few mm
                                  G1 H1 Y+230 F360 ; move slowly to Y axis endstop once more (second pass)
                                  ; homez.g
                                  ; called to home the Z axis
                                  ;G1 H1 Z305 F1800 ; move Z up until the endstop is triggered
                                    Your homing file is configured to use the Z endstop instead of the probe.
                                    So in homeall/homez you'd want to replace this part:
                                    with something like this
                                    G1 X150 Y150 F6000 ; move probe to center of bed
                                    G30 ; probe the bed
                                      agent0810 @Phaedrux
                                      @Phaedrux Changed as requested, and same result. do i need to move the mount holding my probe up a bit?
                                        Maybe? I haven't seen how you have it mounted and even then I'm not an expert on the IR probe. Maybe post a photo?
                                        Also check the lens of the sensor to see if it's dirty or bent or something. It can be cleaned with a cotton bud and IPA.
                                          agent0810 @Phaedrux
                                          @Phaedrux
                                          would a BL touch be a better route?
                                            Well the IR sensor should be a good choice, I'm just not sure what's really going on. Can you provide some more details on the setup as it is now so we can figure out if it's a configuration issues, or an issue with the probe itself. We'll try and cover our bases first.
                                            Post your config.g as it is right now. Confirm you're running fw 3.1.1 by sending M115. Also send M98 P"config.g" and post the results.
                                            Post a photo of your probe as mounted and a close up of it. Also maybe the wiring at the board.
